Advantech PCM-5862 recap & general fixup
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Following on from the "Can't be worse than what's in there right now" I changed the "K.K" caps today on a customers Advantech PCM-5862 SBC.
    (CPU fan had failed & baked it's caps)
    Just as an aside I measured them in-circuit before the swap, ESR meter showed 0.1ESR...
    When I took them out though; LOL, on two sitting on the same side I got no ESR reading at all, nor any capacitance reading!
    For the other pair I got ESR of 50 & 90 respectively, and capacitance around half of what it should have been.
    Are you surprised if I say the bluescreens disappeared after I recapped it?
    Did a 20 minute run of Quake 2 after the recap, before it did not go 5 minutes, now there where no problems
    And let me tell you what a glory that game is in software rendering; 640x480 on a 1MB graphics card, 64MB EDO RAM on a Pentium 100Mhz running in Win2K!
    Just look at those proud new Rubycon ZLH caps and that amazingly heat discolored CPU socket
    Compare the color with the 3-pin fan header at the bottom which I replaced because it fell to pieces due to being too overheated
    There is also a new lithium battery soldered in, top left right above the fantastic SIS 5571 chipset.
    Which doesn't support DMA and whose fantastic Award 4.51PG BIOS hangs with hard drives above 32GB in size!
    So I had to limit the size of the new Transcend TS32GPSD330 SSD in size.
    I hid 58300887 LBA's using HDAT2 making it match the original 12.7mm thick 2.5" HDD which had a giganormous size of 2167MB!
    I don't think ROM-DOS v6.22 nor the Cybelec press brake software will complain about the missing size though.
    It takes up all of ca 5MB or so including the customers programs
    And here is the backside of the same, you can see the caps legs in the centerline of the picture, right by those large yellow capacitors.
    There where also 2x tiny "K.K" 10uF 25v caps that I replaced with Panasonic NHG 10uF 50v caps.
    By these where another lone "K.K" 220uF 16v cap, just like the ones by the CPU slot.
    This is in the area around the Ethernet header so it has not become so hot.
    Capacitance of this one was 220uF as specced and ESR was 2.6
    The tiny caps had correct capacitance and their ESR was 21 & 23 respectively.
    This is how they look on the backside after recapping:
    Perhaps by now your starting to realize I'm posting more for the sake of showing off my new Canon EF 100mm F2.8L Macro lens
    Well it's that and the fact that I've fallen in love with a "no clean" desoldering braid by CRC.
    I've never been able to use braid to much success before but I changed the tip of my soldering iron to one designed for desoldering SMD components.
    It's a huge tip compared to the small needle tip I had before.
    It's simply amazing how well it works!
    Talking out these caps was also a real breeze, since the tip is able to heat both legs at the same time!
    From left to right is my old needle tip which I worn out (tip broken)
    Then one new of the same, and another with a slanted tip that I bought today.
    Finally the SMD tip, I've actually had it for years but never used it, dunno why, it's amazing, nuff said!
    On this board I also used a different technique for installing the caps, normally I always clear all holes with a stainless needle.
    But this one, as you can see have very many SMD components cramped very close together, and the topside is also very cramped.
    I only cleared the hole which the positive leg goes into, leaving the heat-sucking negative holes untouched (only used braid on them)
    So I can put the cap in and then just heat the negative lead and it falls right through, worked really well!
    • 31303
    Re: Advantech PCM-5862 recap & general fixup
    for big harddrives:
    https://code.google.com/p/xtideuniversalbios/
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      As it's for an industrial machine (press brake) thus I was not willing to replace the BIOS, might just cause more problems than it solves.
      I did look at patching the BIOS though, but the BIOS it had did not match the examples I could find, like this one: http://www.ryston.cz/petr/bios/ga586t2_mod.html
      In the end limiting the HDD size is the quickest and probably best solution, customer would not have a need for the bigger size anyways...
        • 31303
        it's not a replacement,
        it's an expansion rom.
        you put it on a network card or some other isa card with a socket.
        i suppose you could merge it into the original if there was space left in the flash - probably not though.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Thanks, for this case it would not be interesting but you never know what you encounter in the future
            • 31303
            good for MEGATOUCH-XL arcade machines,
            they use a 486 board with a crap bios and the harddrives must have specific geometry!
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
              no-name Radeon 9600 XT recap and cooler
              by momaka
              I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
              This one was actually suggested to me by ChaosLegionnaire....
              11-06-2020, 07:54 PM
            • laskr1999
              DFI Lanparty NF3 250GB complete recap help
              by laskr1999
              Hello!
              I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
              I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
              I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
              - 20 x Nichicon 1000uF 6.3v HM 105C
              - 5 x Chemi-con KZG 1000uF 10V
              - 1 x Chemi-con KZG...
              11-25-2025, 03:27 PM
            • varunviolin007
              Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
              by varunviolin007
              Hi guys,
              I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
              I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
              Looking for someone experienced with older PC boards who uses...
              07-29-2025, 11:53 PM
            • vuko
              advantech innocore dpx-w220 bios
              by vuko
              advantech innocore dpx-w220 can you remove or reed bios password,please.I will put the 2 files....
              07-03-2025, 02:45 AM
