Emerson LC320EM2 No power after Kit Replacement
  • David53
    • Aug 2013
    • 36
    After replacing most common shorted components from a shorted (Q600) mosfet and blown fuse I still have no startup. I measure changing voltages at the drain. I also measures 2.7 volts at the gate. Anyone else have any luck repairing these Emerson sets after the repair kit has been installed. D640 the smd has been replaced along with R608, D610, F601, D607, D604, IC601, Q601 and Q600. I have attached the closest schematic I have for the tvs. Bad thing is I have 2 of these sets in the shop needing repaired for the same problem. I have fixed several of the them in the past with the kit I found on ebay, but not this time. Any ideas are most appreciated. I have also read through the other threads on this model tv. Thanks.
    David
  • paulstef
    • Dec 2013
    • 724
    Re: Emerson LC320EM2 No power after Kit Replacement
    What do you mean by changing voltage? At what frequency? Can you post oscillographs?
    • David53
      • Aug 2013
      • 36
      Measuring from hot chassis ground the voltage starts at 0 volts and moves rapidly up to over 20 to 30 volts and cycles over and over. No power light and does not start. We are at full line voltage. You can see the voltages moving from lower to higher and cycling over and over. Thanks for any help. This one has me stumped.
      David
      • paulstef
        • Dec 2013
        • 724
        Look at the attached diagram. I presume you don't have an isolated differential probe to measure on both primary and secondary, right?
        My suggestion: Measure drain of Q600 to hot ground. Then measure pin 15 of T600 to cold ground. Try to relate these two oscillographs and post them here. This will get us started.
        Since your main MOSFET is kind of switching it seems it charges the gate through the 3 startup resistors of 220k but its not enough to create its own power supply then and start oscillation.
        You may have too much load on one of the secondaries (or short) or some problem in the feedback loop.
        Measure also the voltages indicated in the diagram I attached. We need to relate them to the main switching element Q600.
        • David53
          • Aug 2013
          • 36
          I don't have any oscilloscope images to post, but I have the following voltages
          IC601 pin1= 6.94 volts
          IC601 pin2= 5.72 volts
          IC601 pin3= .08 volts
          Ic601 pin 4= .11 volts
          Q600 Drain charges to 14.6 and cycles
          Q600 Gate is 2.7 volts
          Q600 Source 0 volts
          D645 Cathode in Secondary supply 8.26 volts
          Q601 Emitter= 0 volts
          Q601 Base =.08 volts
          Q601 Collector = 2.7 volts
          • paulstef
            • Dec 2013
            • 724
            It' going to be hard without scope.
            What is the voltage at the cathode of D646 (to cold ground)? Does it vary?
            • David53
              • Aug 2013
              • 36
              D646 Cathode to Cold ground 9.5 volts
              • paulstef
                • Dec 2013
                • 724
                Does it vary or is it stable??
                • David53
                  • Aug 2013
                  • 36
                  Very Stable holding at exactly 9.4 volts at present
                  • paulstef
                    • Dec 2013
                    • 724
                    TBH I don't know how to do that without a scope.
                    1. Measure anode of D642 and cathodes of D643 and D660 to cold ground.
                    2. You say on cathode of D609 to hot ground you have almost no voltage?
                    • David53
                      • Aug 2013
                      • 36
                      D642 Anode 3.6 volts
                      D643 Cathode 2.9 volts
                      D660 Cathode 13.9 volts
                      Cathode of D609 to hot ground is .3 volts
                      I have a scope, but it has been rarely used in over 20 years and not sure if I could even get it operational enough to work.
                      • David53
                        • Aug 2013
                        • 36
                        Oops I made a mistake D642 Anode is -3.6 volts
                        • paulstef
                          • Dec 2013
                          • 724
                          Q600 gate is stable at 2.7V? Then why does the drain vary from 0 to 15V?
                          From what I see if the output voltage on the secondary is higher than what it should be (around 24V) the optocoupler IC601 will turn on. Since your voltage is much lower the opto output should be open. If it's open then C609 would be charged through D609 everytime Q600 turn on.
                          It looks like it's something on the primary side.
                          • David53
                            • Aug 2013
                            • 36
                            Gate of Q600 is very stable at exactly 2.75 volts. Any idea what would keep Q600 coming up to the 165 volts? I have tried to measure every component in the primary...but not sure what I should be looking for now? I too do not believe that the secondary is the problem. I have checked all the diodes in the secondary. As usual with these set D640 was initially shorted causing multiple components to be open or shorted. If I can find the problem with these 2 sets I know a lot of others having the same problems. Thanks for staying with me and trying to help..
                            David
                            • paulstef
                              • Dec 2013
                              • 724
                              D640 was initially shorted? That's very bad for everything that comes after that. What's the voltage at the cathode of D640 now?
                              • paulstef
                                • Dec 2013
                                • 724
                                I think there is no way around. You need the scope. If there is voltage on the secondary Q600 must be switching. So its gate cannot be stable. If this is measured with a DC multimeter you may just be reading the average of the pulses at the gate.
                                • David53
                                  • Aug 2013
                                  • 36
                                  D640 Cathode is 6.9 volts and steady. I connected the old scope to the drain of Q600 and Hot chassis ground. The best I can tell it looks like a sawtooth waveform at possibly 450 mv. Here I will show my ignorance of using a scope. On the 50mv scale it is 9 full divisions in amplitude. The top is slightly rounded, then gives the appearance of an upside down sawblade and goes straight up to the slightly round top of the uppermost amplitude. Hope you haven't fell out laughing at my ignorance. All those years ago now I wished I had learned how to use a scope.
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    First of all, you do remember that if this is not an isolated scope then probe ground is connected to AC ground and from there could be connected to AC neutral?
                                    When you are sure your scope cannot damage anything then we can continue taking measurements.
                                    Post the scope pics here. For example the drain of Q600.
                                      If the scope is NOT floated (no safety ground on the scope, dangerous), when he puts the scope probe on the primary circuit ground (not the safety ground), he will see nice spark and may blow up the primary rectifier diode. He should put the DUT on the isolation transformer that has isolated Hot and Neutral but still have safety ground.
                                      What is the ground ref. are you using?
                                      • David53
                                        • Aug 2013
                                        • 36
                                        Working on getting pictures...I put the scope probe on the Drain of Q600 and the ground lead on hot chassis ground. Also checked the gated No loud pops so far. Of course both of you have scared about a years life out of me. :-)
