Panasonic TC-P58S2 7 blinking red
  • OneBadxxx
    • Mar 2014
    • 3
    Panasonic TC-P58S2 7 blinking red lights no sound no picture. Manufactured Oct 2010. Tried unplugging and same conditions. If I unplug z-sustain I get 6 blinks. Sorry a newbie here. Asking for a path to hopefully narrow down to a board or 2 to replace with guidance here unless with patience I can go further.
    Please recommend next steps or a source for a service manual, if its here I could not find with a search. Also welcoming a reputable source for replacement parts.
    Thanks in advance.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P58S2 7 blinking red
    7 BLINKS , normally SC/SD/SU related.
    TNPA5175AB , TXNSC1LYUU is the 58" version SC board.
    TNPA5174,TXNSD1LYUU
    TNPA5173 ,TXNSU1LYUU are the 58" SD/SU boards
    Viewing the TV from the back, left side you have SU,SD (Ybuffer boards), SC board(ysus,ymain).
    Right side, SS (xsus,xmain,zsus)
    Panasonic description of 7 blink
    Scan Drive Circuit and Connection between the SC board and SD/SU boards.
    Missing Vsus. Abnormality of the scan circuit output, the 15V_F, the scn_pro, and Vscn circuit. Loose or open Connection between the SC board and the SD/SU boards(SC41, SC42, SC46). Open or loose connection between connectors SC2/P2 Wrong diagnostic by the A board Defective panel.
    To determine which board/s
    1. Remove the 4 VF_GND screws on the SD/SU boards.
    2. Unplug connectors SC41, SC46, and SC42 on the SC board.
    3. Jumper/short pins 1 and 2 of connector SC50 on the SC board.
    Turn on TV, When this is done, the display is completely black (No picture)
    If it turns on with no error, SC board passed, SU,SD at fault.
    If faults, SC at fault, buffer boards should be checked as well in case they have shorted before installing a new Sc board.
    42" guide should be good enough to help here.
    • tw2005
      • Oct 2011
      • 6458
      http://www.moduslinkptstvboards.com/txnsc1lyuu/
      https://www.encompassparts.com/item/...1LYUU/Pc_Board
      • OneBadxxx
        • Mar 2014
        • 3
        tw2005 - many thanks for your quick response.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
          by sam_sam_sam
          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
