usp440m-42lp psu
  • joehezzer
    • Jul 2012
    • 251
    • England
    usp440m-42lp psu
    Hi all does anybody have any experience with the said psu, picked up a 42inch plasma the other day, the psu has no power and am struggling to find a replacement cheers
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: usp440m-42lp psu
    anybody know of anywhere i could get one or is interested in trading !!!
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      What tests have you done on it?
      Stby 5v present?
      Have you tried turning the PSU on by sending the PS-On, Vs-On, etc to it?
      What set? PSU may well be fine--could be a Set fault and nothing to do with the PSU at all!
      TELEFIX
      • joehezzer
        • Jul 2012
        • 251
        • England
        i have checked the voltage on the points marked in yellow, nothing at all no standby light nothing. i have done a minimal amount of checks as i was just going to replace psu. there is a big blue block (relay i think ) found a post somewhere saying it might be that, its a bush 42" PLASMA, i do not have model number as of yet
          Fuse is good?
          Early Bush plasma - probably early LG panel - 42V5/V6/V7? If so watch out for sparklies/maldischarge fault.
          I'd check input fuse and bridge rectifier for DC.
          • joehezzer
            • Jul 2012
            • 251
            • England
            Originally posted by tom66
            Fuse is good?
            fuses are good, i will check the bridge rectifiers as soon as i can
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Pics of chassis....?
              --I'll bet that PSU is OK from experience....
              TELEFIX
              • joehezzer
                • Jul 2012
                • 251
                • England
                bridge rectifiers tested good, i will get more pics later
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  Fuse is good?
                  yep you're right tom
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    model number pdp42tv006
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Ha! A V7!
                      First plasma I ever potched with was a V7. Still got an alleged brand-new IPM for one kicking round somewhere....
                      10-1 that PSU is OK. You'll need to check for 5V stdby supply first before going any further.
                      TELEFIX
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        Ok will have a look tomorrow when I finish work. The chap I got it off said they had a power cut and it never came back on
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Thing is--The V7 is pretty long in the tooth now, and only a 480p res, so not worth spending any real dosh on--certainly not investing say 50 quid in a PSU!
                          A few tests will determine whats what...
                          Firstly, with set unplugged, use your meter to check the fuses on Y-SUS and Z-SUS. Any blown and there's a short somewhere....
                          Then check the resistance from each fuse--to chassis metalwork. This should initially 'kick' or read for say half a second as the caps charge, then read a pretty high resistance.
                          TELEFIX
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            just looking for the 5v stby point, i can see 5v ctl
                            • joehezzer
                              • Jul 2012
                              • 251
                              • England
                              they are all ok checked them earlier (fuses), i disconnected the boards y-sus z-sus one at a time to see if it turned on still nothing
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                OK--Thats one of the 5V lines--there's usually a few. Some will be powered, some not when in standby.
                                Check 'em all, post results and the names/references of 'em pref with a pic of the plug you measured them at...
                                TELEFIX
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  ok will do tomorrow cheers matey
                                  • joehezzer
                                    • Jul 2012
                                    • 251
                                    • England
                                    ok so i have measured all the 5v standby and a couple of others and i am still getting no readings at all, they are all marked in yellow
                                    • joehezzer
                                      • Jul 2012
                                      • 251
                                      • England
                                      a bigger picture, the numbers on the pics refer to the first pic then the second and so on, but i think i kinda screwed it up lol
                                      • wills123
                                        • Jan 2014
                                        • 72
                                        • england
                                        i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
                                        http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
                                        it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... priceless
                                        • dicky96
                                          Need to buy buck regulator MP2329CGG but struggling to find supplier
                                          by dicky96
                                          Hi guys
                                          I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                          Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                          I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                          Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                          03-05-2021, 08:44 AM
                                        • Faileng
                                          Struggling with a soldering job, need help.
                                          by Faileng
                                          Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                          I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                          I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                          I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                          02-06-2020, 02:07 PM
                                        • Inverteddragonx
                                          Intel NUC8i3BEH BIOS+EC
                                          by Inverteddragonx
                                          Hi, I'm looking for a BIOS and EC chip for my Intel NUC8i3BEH (motherboard model NUC8i3BEB). I received a faulty unit and am trying to repair it. The previous owner tried to tinker with it and erased the BIOS and EC chips, and I've been struggling with this for several hours (I'm a complete novice at this). I managed to rebuild the BIOS from the NUC8i7BEH, but the unit still doesn't respond to the power button. The board seems to be receiving power normally, as the green LED next to the SATA connector is lit. I would really appreciate if you could check if I rebuilt the bios correctly and provide...
                                          11-07-2025, 07:44 PM
                                        • BadSabre
                                          Bricked Lenovo Ideapad 3 14ACL6
                                          by BadSabre
                                          Hey all!
                                          I updated my Lenovo laptop a couple of weeks ago using Lenovo Vantage and the BIOS update has bricked my computer.
                                          I have a CH341 programmer but have been struggling to fix it.
                                          My BIOS chip is the GD25LR128DSIG.
                                          Latest BIOS update GLCN68WW.
                                          If someone could help with an exact tutorial for this specific BIOS, that would be great!
                                          When I use AsProgrammer to read the IC it comes up with IC model: GD25LQ128C and not the one above.
                                          It also has a lenght of 16777216 where as the below tutortial says to...
                                          11-07-2025, 03:42 PM
                                        • superpj1
                                          Trying to reset CMOS of Packard Bell Easynote LV
                                          by superpj1
                                          Hi everybody. I forgot the password of my BIOS and am now struggling to reset it. I removed the battery for a whole week-end but the BIOS is still password protected. I think I must shortcut 2 pins but I don't know which ones. None is labelled G2201/RTC_RST/RTCRST/JCMOS.
                                          I would be VERY gratful to anyone who can help :-)...
                                          11-04-2025, 10:01 AM
