usp440m-42lp psu
  • joehezzer
    • Jul 2012
    • 251
    • England
    #81
    Re: usp440m-42lp psu
    my fault lol still learning . Outter pins read 02.2v dc the inner oned read 03.5v Ac
    • paulstef
      • Dec 2013
      • 724
      disconnect AC. check the two big white resistors. they are probably open.
      • joehezzer
        • Jul 2012
        • 251
        • England
        #83
        R106 and R105 you mean
        • paulstef
          • Dec 2013
          • 724
          yes.
          I will only have the board for a few more days. if we can find out whats wrong today would be good.
          • joehezzer
            • Jul 2012
            • 251
            • England
            #85
            Ok cool going to remove board as I cannot acces it
            • joehezzer
              • Jul 2012
              • 251
              • England
              #86
              taken one out and i got the reading of 5.6ohms both are reading this
              • paulstef
                • Dec 2013
                • 724
                Ok, look. The AC voltage that comes in goes more or less directly to the two middle pins of the bridge rectifier. You have to find out where this path is interrupted. If you cannot measure AC between the middle pins of the rectifier it should be fairly easy to find out.
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  #88
                  Tnr101 and tnr102
                  • paulstef
                    • Dec 2013
                    • 724
                    Tnr101 and tnr102
                    I cannot guess what you want to say. They are in parallel with the AC voltage. You only need to look at what's in series . Which component can cause an interruption from AC in to the bridge rectifier. Just follow the path. Forget the relay, it only jumpers the white resistors, which you said are ok.
                    Simple resistor measurement will get you there
                    AC OFF!!
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      #90
                      AC OFF!!
                      ok, i see what you are saying, it can only be one of the components leading up to the bridge rectifier.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #91
                        So I have decided to change the components leading to the bridge rectifier.
                        • paulstef
                          • Dec 2013
                          • 724
                          Right ok test out put again and got 263v Ac atleast I have a reading this time lol
                          In this post you said you have AC input voltage. So replacing anything between AC IN connector and this point won't help you. There are only the resistors between this point and the rectifier (where you measured nothing).
                          You said the resistors are ok. So I don't see where replacing any parts will lead you.
                          You are either not measuring correctly or there is something else we don't see.
                          When measuring resistance from one of the middle pins of the bridge rectifier to the AC input pins, what do you get?? Then from the other middle pin of the rectifier, what do you get?
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #93
                            I measured the wrong resistors. I had the board the wrong way round, as there are 4 of them, I tested the wrong ones as I was rushing yesterday
                            • paulstef
                              • Dec 2013
                              • 724
                              Ok, so if the two white resistors or one of them is open there are other component that need to be checked. First of all the bridge rectifier.
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #95
                                I have changed the bridge rectifier to a known working one. So will check again later after me dinner
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  #96
                                  Originally posted by wills123
                                  i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
                                  http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
                                  it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... priceless
                                  ok so i gave in on trying to find out what was wrong with psu, and ordered the above psu popped it in this morning it works, for the sake of £30 with free postage i cannot moan cheers all that helped me fault find the old one, cheers paulstef
                                  • dicky96
                                    Need to buy buck regulator MP2329CGG but struggling to find supplier
                                    by dicky96
                                    Hi guys
                                    I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                    Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                    I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                    Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                    03-05-2021, 08:44 AM
                                  • Faileng
                                    Struggling with a soldering job, need help.
                                    by Faileng
                                    Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                    I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                    I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                    I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                    02-06-2020, 02:07 PM
                                  • Inverteddragonx
                                    Intel NUC8i3BEH BIOS+EC
                                    by Inverteddragonx
                                    Hi, I'm looking for a BIOS and EC chip for my Intel NUC8i3BEH (motherboard model NUC8i3BEB). I received a faulty unit and am trying to repair it. The previous owner tried to tinker with it and erased the BIOS and EC chips, and I've been struggling with this for several hours (I'm a complete novice at this). I managed to rebuild the BIOS from the NUC8i7BEH, but the unit still doesn't respond to the power button. The board seems to be receiving power normally, as the green LED next to the SATA connector is lit. I would really appreciate if you could check if I rebuilt the bios correctly and provide...
                                    11-07-2025, 07:44 PM
                                  • BadSabre
                                    Bricked Lenovo Ideapad 3 14ACL6
                                    by BadSabre
                                    Hey all!
                                    I updated my Lenovo laptop a couple of weeks ago using Lenovo Vantage and the BIOS update has bricked my computer.
                                    I have a CH341 programmer but have been struggling to fix it.
                                    My BIOS chip is the GD25LR128DSIG.
                                    Latest BIOS update GLCN68WW.
                                    If someone could help with an exact tutorial for this specific BIOS, that would be great!
                                    When I use AsProgrammer to read the IC it comes up with IC model: GD25LQ128C and not the one above.
                                    It also has a lenght of 16777216 where as the below tutortial says to...
                                    11-07-2025, 03:42 PM
                                  • superpj1
                                    Trying to reset CMOS of Packard Bell Easynote LV
                                    by superpj1
                                    Hi everybody. I forgot the password of my BIOS and am now struggling to reset it. I removed the battery for a whole week-end but the BIOS is still password protected. I think I must shortcut 2 pins but I don't know which ones. None is labelled G2201/RTC_RST/RTCRST/JCMOS.
                                    I would be VERY gratful to anyone who can help :-)...
                                    11-04-2025, 10:01 AM
