usp440m-42lp psu
  • paulstef
    • Dec 2013
    • 724
    Re: usp440m-42lp psu
    Perfect. What's the voltage at the points indicated in the picture?
    • joehezzer
      • Jul 2012
      • 251
      • England
      #42
      Bouncing around 00.3 to 00.7 that looks a bit suss
      • paulstef
        • Dec 2013
        • 724
        Are you sure the fuse is ok?
        You measure AC, right?
        • joehezzer
          • Jul 2012
          • 251
          • England
          #44
          i did a continuity test on it, i took the fuse out of its holder
          • paulstef
            • Dec 2013
            • 724
            Check input voltage directly at the connector. Sure it's there?
            • joehezzer
              • Jul 2012
              • 251
              • England
              #46
              Nothing. Extension lead is fine
              • paulstef
                • Dec 2013
                • 724
                Well, then the problem is somewhere else. I don't have the TV in front of me, just the board. Check the connector/cable etc.
                • paulstef
                  • Dec 2013
                  • 724
                  That's very strange. Is your multimeter working? What if you measure the AC directly at the wall outlet?
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    #49
                    well the extension lead is working as i have just tried my belt sander on it. just going to have a look at a faulty rocker switch and the bit where the kettle lead goes in
                    • paulstef
                      • Dec 2013
                      • 724
                      There is also an EMI filter directly connected to the AC inlet of the TV. Maybe it's faulty. You could measure the output voltage at its terminals.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #51
                        yeah just looking at that now
                        • joehezzer
                          • Jul 2012
                          • 251
                          • England
                          #52
                          gonna have to give it a break tonite, will go over these bits tomorrow.
                          • paulstef
                            • Dec 2013
                            • 724
                            ok. good luck. Shouldn't be hard.
                            • joehezzer
                              • Jul 2012
                              • 251
                              • England
                              #54
                              i have not tested it yet but it does smell a little
                              • paulstef
                                • Dec 2013
                                • 724
                                Ok, keep us posted about your findings. There is not much left to check.
                                In the meantime I will spend another evening on my board
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  #56
                                  will do
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    How did this work out for you? Was it the Filter?
                                    • joehezzer
                                      • Jul 2012
                                      • 251
                                      • England
                                      #58
                                      hi paul not had chance to test it yet, hopefully tomorrow
                                      • joehezzer
                                        • Jul 2012
                                        • 251
                                        • England
                                        #59
                                        ok so i just tested the filter there is no voltage at all at the filter, so have a new filter on order.
                                        • paulstef
                                          • Dec 2013
                                          • 724
                                          Great. Good luck!
                                          • dicky96
                                            Need to buy buck regulator MP2329CGG but struggling to find supplier
                                            by dicky96
                                            Hi guys
                                            I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                            Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                            I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                            Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                            03-05-2021, 08:44 AM
                                          • Faileng
                                            Struggling with a soldering job, need help.
                                            by Faileng
                                            Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                            I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                            I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                            I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                            02-06-2020, 02:07 PM
                                          • rockman97
                                            Need BIOS dump for ASROCK FM2A55M-VG3
                                            by rockman97
                                            Hello guys,
                                            I am struggling to find bios BIN file for ASROCK FM2A55M-VG3 (i had the normal VG3 not the VG3+)
                                            When i download from official website, and put that in EZP2019+ programmer software it says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''
                                            That means that file i downloaded is larger than chip says, even tho chip is 8mb and file is 8mb.
                                            It has the Winbond 25Q64FVAIQ chip what i need to select the prgoram?
                                            I created a backup but when i rewrite its not work.
                                            08-23-2025, 04:31 PM
                                          • Rickkap
                                            Help in identifying a component- ASUS ROG G634J
                                            by Rickkap
                                            I have an ASUS ROG motherboard and it has a shorted/burnt component which I'm struggling to find or identify.
                                            Any information would be greatly appreciated.
                                            If anyone has the schematics/boardview that would really help....
                                            08-23-2025, 01:24 AM
                                          • Dreigas
                                            Laptop, Bios and some phones schematic database
                                            by Dreigas
                                            About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
                                            What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
                                            Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
                                            I plan to host the...
                                            08-20-2025, 09:58 AM
