EP 61BXA-M sucess story, but...
  • Mikeluz
    • Feb 2006
    • 27
    Hi!
    I own a EPoX EP-61BXA-M, that used to have bad caps. Actually, the former owner, had a little trouble with this board, on the VRM, near the CPU slot1... a badcap vented and as a "bonus" a MOSFET near the badcap burned out, rendering the CPU -- a P2 350MHz -- dead.
    The badcap was a TAYEH 10v 1000uF, and the MOSFET was a D50N03A. I canibalized a 6.3v 1200uF to put on the place of the 10v 1000uf (didn't have any 10v 1000uF, only a 10v 2200uF, but I didn't tried this one until a later time, further on this post). As I said canibalized a 6.3v 1200uF to put on the place of the 10v 1000uf because this capacitor has the same dimensions as the TAYEH one. I think I can do this, but, any enlightening about the is switch will be welcome. The board works well with this cap, so I guess, I did right, but any warnings/thoughts about long term effects that I could I expect from this replacement, will be much welcome
    About the MOSFET, I went to the local electronics shop and I was told that a replacement for the D50N03A is a Philips BUK455 100A, which according to it's datasheet is a N channel, 100V, 26A(max) MOSFET . I was fooled by the MOSFET name BUK455 100A, as I thought this was a 100A MOSFET, but actually it's only 26A(max)!
    Well I've replaced the burned MOSFET, and the computer work ok, except, that when I run a P3 600 on it, the MOSFET heats a lot, and eventually when I run P95 the MOSFET actually smokes (this is before I shut down the PSU, to prevent this MOSFET to burn out!) I was lead to the conclusion that something was not right! Further searching on the web to a datasheet of the D50N03A leads to nothing! Except a thread on this forum, where, according to kc8adu
    , on this thread https://www.badcaps.net/forum/showth...96&mode=linear, on the 7th post said that the D50N03A (original MOSFET), is a 30v 50A N-channel MOSFET.
    So, I guess I was misinformed about the D50N03A replacement and as a consequence I'm running a BUK455 100A (100v, 26A, N-ch MOSFET) bove it's capabilities, when "Primming95" (P95 drains the max current to the CPU, and I think that slot1 P3 600 CPU drains up to 30A, well above the BUK455 100A max. 28A limit, and below the D50N03A 50A limit). I think I should replace the BUK455 100A (26A Idrain) to another N ch MOSFET with a 50A Idrain (according to kc8adu Super Moderator. I think this is MOSFET fault, as the overheating only happens when the CPU load is high, this is when the current drained is high!
    What do you think?
    Any help from him or any other members will be much appreciated! As a side note I used to think that the overheating of the BUK455 100A MOSFET was capacitor fault, so I switched the 6.3V 1200uF to a 10V 2200V, but this helped nothing. So, after I read the above thread, I think the MOSFET ovearheating problem is due to the 26A limitation of the BUK 455 100A which does not comply with the original (D50N03A) MOSFET specs which were (according to kc8adu Super Moderator), 30V, 50A.
    Sorry for the long post, I think I've explained all that I've done, but if any doubt arises, please feel free to ask me!
    TYA for any replies.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: EP 61BXA-M sucess story, but...
    i would replace the mosfet with the proper type and finish recapping.
    if one cap went all others like it are near death too.this can also cause mosfet overheating.
    • Mikeluz
      • Feb 2006
      • 27
      Hi! Thanks for the reply!
      I'll do that recapping, as soon as I get replacements here at Portugal! Back here is difficult to find Low ESR caps, so I've got the order from outside Portugal.
      I've searched further on the web about the original MOSFET and I came across these links (by the order I've opened them
      http://www.icpart.com/SALESDETAIL/D50N03A.html
      clicked on the PDF icon lead us to:
      http://www.alldatasheet.com/view.jsp?Searchword=D50N03A
      clicked on the first PDF entry lead us to the PDF itself:
      http://www.alldatasheet.com/datashee...50N03-06P.html
      Now, what should I do with this info? Shoul I measure the voltages that I came across when P95? Then go back to the characteristics curve and find out which Idrain is drained? I'm not sure about the way to go. Any help would be appreciated on the MOSFET question.
      TY for the answer!
      Mikeluz
      • Mikeluz
        • Feb 2006
        • 27
        My principal problem is not knowing about the charateristics I should look for on the MOSFET, how should I get a replacement? The BUK455100A that I was told that I could replace the D50N30A original MOSFET, looks like does not meet the original specs of the board, and I can't find any conclusive datasheet about the original MOSFET. I'm not sure of what could happen if I try one of those Vishay ones, because they have different Idrains @ the same VDS, VGS, so I guess that I could fry the CPU if I feed it with current above its requirements. So I'm not sure about what the "correct type" I should search for Any enlight about this, from you or another member will be much appreciated.
        • Rainbow
          • Aug 2005
          • 1375
          Get two logic level MOSFETs (if there are two on the board) that have lower-or-equal Rds(on) and higher-or-equal Id than the original ones. Then replace both MOSFETs on the board so they're same. Then replace all the TAYEH caps to prevent it from blowing again.
          I never buy replacement MOSFETs as I have enough dead boards with proper types
          • Mikeluz
            • Feb 2006
            • 27
            Thank you for the reply! Yes, there are two MOSFET's near each other, located near the CPU slot1. (attached is a aimage showing the relevant zone, at left of the Slot1)
            But, I don't know *for sure* which are the specs of the original MOSFET's, that's is my problem!
            If I don't know *for sure* those specs, then I can't search for a proper replacement(s). (According to Kc8adu, the D50N30A is 30v, 50A, but I want to know *for sure* if that info is accurate! I've searched the web and I've seen D50N03 (not A), that have different Id's ranging from 23A to 100A.
            I must reinforce this thought: not knowing *for sure* the D50N03A specs I can't go any further!
            QUESTION: That is, if I replace the MOSFET with a 50A parts, can I damage the CPU? I don't know how the VRM works, so I'm a bit afraid of doing this. Does the VRM adjusts itself to the MOSFET's?
            Any link pointing me to the datasheet or the specs of the D50N03A (if any of those exists), would be nice.
            TY,
            LP
            • Mikeluz
              • Feb 2006
              • 27
              Care to point me to some of those logic levels MOSFET's, that are compatible to these D50N03A, please? At this point, I can't continue further without any enlight. I don't know how a VRM works, neither how MOSFET works on the VRM, how it figures what is the voltage / current that it has to deliver to the CPU, etc. Is there any tutorial where I can learn how does a VRM work?
              TY,
              Mikeluz
              • gonzo0815
                • Feb 2006
                • 1600
                Best thing for you, look for the VRM controler chip on your board. Than google a little and look if you can find a appsheet or datasheet for the controler. In most cases, you will find a reddily desinged circuit for your exact purpose, usually with all the details abouth the mosfet`s. But i am shure, that any mosfet with low enough RDS on (something under 0,03 Ohm) and logiclevel compatible will suit your needs. I doubth, that there would be more than 12 to 20A supplied to the P3. If you wana be shure, take an 30A rated ones.
                • Mikeluz
                  • Feb 2006
                  • 27
                  Thank you for the reply gonzo0815 The chip you are talking about, I supose it's also called a "driver chip"? And usually there's one near the MOSFET to drive them though I don't know how that driving it's done. (I'd like to know how that driving is done, as a curiosity.) The IC chip on the picture above, near the top MOSFET, is a ALPHA AS1664S (also written is 9740 --but i think this 9740 is the manufacturer year/week, so it's not relevant), so I'll google it as you advice me!
                  About the Philips BUK455100A, according to it's datasheet (, it's a 26A (max) part, so I suppose it should handle the 20A current drain of the P3 (I agree with you on the 12~20A max.) Thought, I'm not sure if this part ( Philips BUK455100A), is a logic level MOSFET that you guys gonzo0815 & Rainbow are talking about?
                  TY for the replies!
                  Mikeluz
                  • Mikeluz
                    • Feb 2006
                    • 27
                    The above link to the BUK455 100A datasheet is not working now, so here's another:
                    • Rainbow
                      • Aug 2005
                      • 1375
                      That BUK455-100A is not suitable for CPU VRM use - Id is too low, Rds too high and it's not even logic level!
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Not shure, at least it will conduct at 5v, but RDSon will probably be even higher than stated in the datasheet. Certainely, not the ideal mosfet for that purpose.
                        • Rainbow
                          • Aug 2005
                          • 1375
                          Exactly - if the VRM controller requires logic level MOSFETs, the Rds(on) will be awfully high and it will smoke and die.
                          • Mikeluz
                            • Feb 2006
                            • 27
                            Hi Rainbow and gonzo0815!
                            Well, I've measured temperatures of the BU455during P95 and the results are:
                            T _P2 350@434 (FSB=124MHz) _ = 95ºC (max)
                            T _P3 450@554 (FSB=124MHz) _ = 105ºC (and raising)
                            so I've decided to limit the CPU to the P2350@ 434, but I continue t think that 95ºC @ room temperature of about 18ºC is way too much! On Summer ambient temeratures go up to 38ºC so BUK455 will probably not survive! Anyway on the computer I'm writing now, a P4 1800A, when Oc'ed to 2.4 (FSB=133MHz) and Priming the temperatures of one of the two "MOSFET drivers also raise to about 95ºC), so I think this is a normal temperature under heavy load, like "Priming95"?
                            Returning to the main subject, the BUK455 MOSFET. What do you guys think that would be a proper replacement for the D50N30A MOSFET that had been replaced for this BUK455? For instance what Phillips type MOSFET would be the one to look for?
                            TY for your repplies guys!
                            Mikeluz
                            P.S. I have an school exam during the next 2 days, so I'll probably won't feedback during these 2 days. Sorry!
                            • Mikeluz
                              • Feb 2006
                              • 27
                              Well, I've measured temperatures of the BUK455-100Aduring Prime95 and the results are:
                              T _P3 450@554 (FSB=124MHz) _ = 105ºC (and raising!!!)
                              so I've decided to limit the CPU to the P2350@ 434, but I continue to think that 95ºC @ room temperature of about 18ºC is way too much! On Summer ambient temperatures here at Portugal go as high as 38ºC so BUK455 will probably fry! (As a side note, on the computer I'm writing now, a P4 1800A, when OC'ed to 2.4MHz (FSB=133MHz) and Priming95 the temperatures of one of the two "MOSFET drivers also raise to about 95ºC, so I think this is a normal temperature under heavy load, like "Priming95"? Maybe the mobo's manufacturer's trend is similar to the trend seen on low end (pricewise) PSU's... to use components above its rated specs...leading to a shorter life of the components and as a consequence of overheat follows that the PSU dies...selling more and more often to increase profit...at expense of quality and longevity of products...)
                              I recall that the original MOSFET (that is, the good one that has left on the motherboard) has voltages VGS~=5V and VDS=~4V, but the BUK455-100A has voltages VGS~=3.8V and VDS~=3V.
                              Mikeluz
                              • Mikeluz
                                • Feb 2006
                                • 27
                                What Id value should I look for? 30A? 40A? It's a Slot 1, P3 600 (Katmai core) that I'll run on it.
                                • Mikeluz
                                  • Feb 2006
                                  • 27
                                  What RDSon value should I look for?
                                  • Mikeluz
                                    • Feb 2006
                                    • 27
                                    How do I determine if I can use logic level MOSFET's? (I can't find the VRM controller datasheet anywhere in the www). OR, in another words, can I use, by default, logic level MOSFET with VRM's? IF the answer is Yes, then I'll buy the couple of MOSFET needed, based on the Id & RDSon that you advice me to. If the answer is NO, what MOSFET's do you advice me to buy (any example)?
                                    TIA,
                                    Mikeluz
                                    • Rainbow
                                      • Aug 2005
                                      • 1375
                                      Look, for example, at CET CEB6030L - these MOSFETs were used on many Slot 1 boards - you need something like that:
                                      logic level, Rds(on) = 20mohm@Vgs=4.5V, Id = 52A continuous, 156A pulsed
                                      Yes, you can use logic level mosfets for all motherboard VRMs.
                                      • Mikeluz
                                        • Feb 2006
                                        • 27
                                        Thank you Rainbow, for the input!
                                        I'll post the results here after I replace both MOSFET's, after school exams
                                        Best luck for you!
                                        Mikeluz
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • redbaron1007
                                          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                          by redbaron1007
                                          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                          09-09-2025, 11:10 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
