MSI K9A2VM Poly-Mod
  • c_hegge
    • Sep 2009
    • 5219
    MSI K9A2VM Poly-Mod
    I got my hands on one of these boards. there's a similar one here (http://static.kupindoslike.com/MSI-K..._O_3013614.jpg). My one came with mostly TK Caps (with the exception of panny FLs on the VRM High side). None were bulged, but I thought it would be a fun experiment. Here's what I used
    330uF 16V Fujitsu on the VRM High
    820uF 2.5V Nich LF on the VRM Low
    820uF 2.5V Fujitsu on the Chipset VRM
    560uF 4V NCC PSA on the RAM VRM (note that there were only 2 1800uF caps there originally, with a blank spot for a 3rd one. I filled the blank spot up)
    470uF 6.3V OS-CON SPEC on some of the USB filtering (others I left with NCC KY Lytics)
    1000uF 6.3V Nichicon FPCAP L8 everywhere else
    The board has been going in memtest now overnight, with no errors yet.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: MSI K9A2VM Poly-Mod
    Nice, it looks great!!! What CPU do you have under there?
    Are you going to memtest it with all the RAM slots filled to see how it does with all of them populated?
    • c_hegge
      • Sep 2009
      • 5219
      That's what I'm doing now. I have four 1GB modules in there for the memtesting, and a Phenom 9750 Quad core CPU. I took those pics when I was just making sure it would POST and not go up in smoke.
      • hasel17
        CH341a can erase and read but can't write and blank check
        by hasel17
        So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
        Code:
        Checking for blank...
        (Press
        10-26-2023, 06:20 AM
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
      • RetroComputingGrotto
        Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
        by RetroComputingGrotto
        I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
        I've uploaded a video of it happening on YouTube:
        I've taken the monitor...
        01-11-2024, 05:37 AM
      • spleenharvester
        Reverse engineering of DoCreate DHJ567 handheld spot welder
        by spleenharvester
        Hello everyone
        I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
        Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
        05-08-2025, 02:52 PM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
