Finding replacement bits for a Panasonic Plasma SC board
  • SuperSkippy
    • Nov 2012
    • 58
    • United Kingdom
    I'm trying to fix a Panasonic 42" plasma TV. I've narrowed it down to the SC board, a TNPA4829.
    I've found two shorted components that I think are causing the board to be no good:
    One is a IGBT: 2PG011. Panasonic are eating their own dogfood here.
    You can see the datasheet here:
    Sadly Panasonic don't make it any more, and they have appeared to given up altogether with IGBT.
    Do you reckon something like http://uk.rs-online.com/web/p/igbt-transistors/5411477/, a IRG4BC40WPBF from International Rectifier would do the trick? I don't really feel qualified to spec up a replacement.
    The other part is labelled 30G123. I've no idea what that is.
    It looks like:
    not my photo. It's difficult for me to tell what it is as the one I've removed is doing a very good impression of a 3 way piece of wire, but there is another non-shorted one on the board I guess I could take out if anyone could give me some encouragement that I might be able to spec out a replacement by examining the part.
    AliExpress/AliBaba have some but I don't really want to wait for it to be delivered from China, and I'd rather buy from a quality supplier.
    Thanks in advance for any help.
  • mariushm
    • May 2011
    • 3799
    Re: Finding replacement bits for a Panasonic Plasma SC board
    The last one is a Toshiba GT30G123 , 400v igbt
    See (page 12)
    • tw2005
      • Oct 2011
      • 6458
      Simply replacing the blown IGBTs may not get it going as there can be other parts taken out with the failure. One thing I see diifferent is the max pulsed current at 230A for the panasonic item compared to 160A for your sub.
      I have no idea if that will come into play. I think you'd have to fully insulate the sub when mounting as the IGBTs panasonic uses are fully plastic.
      Could you post a hi-res shot of the board and also the location identifiers for the blown IGBTs.
      • tw2005
        • Oct 2011
        • 6458
        Have you checked out the buffer boards for shorts just in case they're bad too?
        I got ny parts from a supplier in China, turned out ok got 2 of my SC boards going. A couple of parts looked harvested but were all good and fairly cheap.
        I think you may have some suppliers of oem Panasonic local but those IGBTs seem quite expensive doing it that way, China is generally cheaper.
        http://www.ebay.com.au/itm/2PG011-Ma...item1e7666ef87
        http://www.utsource.net/ic-datasheet...3-1905635.html
        http://www.utsource.net/2pg011.html
        Same seller, notice the ebay item is slightly cheaper. They can be quite variable with their pricing, that is they make it up a bit. I have been quoted $1 per unit and $2 per unit for the same Schmitt inverter. The same item if available in RS were only 70c ea. Overall they're cheaper but always do your research.
        A British example. http://www.littlediode.com/components/2PG011.html
        At that price you'd be better buying http://flattvparts.co.uk/index.php?m...ducts_id=14732
        just for the parts. I would'nt trust the description though as I think they have this incorrectly labelled for a 42" but the part number and Rev AB looks to be 50" to me.
        They're cheap but I have had dud parts from them but others have had plenty of success. probably not such an issue for local purchasers.
        • tw2005
          • Oct 2011
          • 6458
          https://www.chsinteractive.co.uk/sea...=B1jadp000004+
          https://www.chsinteractive.co.uk/sea...l?query=2pg011
          • SuperSkippy
            • Nov 2012
            • 58
            • United Kingdom
            Cheers.
            As for the original "replacement" igbt, I was going to get the mica sheets out. Now I look again though I see I can buy all plastic ones in slightly different packaging, but I'm sure if I bent the wires they'd go in. By the time you get to decent replacements, they cost as much as CHS anyway.
            I didn't see CHS had them.
            Since it seems to boil down to £20 for two IGBTs or £30 for an entire board full, I think replacing the board seems like the way forwards.
            • tw2005
              • Oct 2011
              • 6458
              Well, those SC boards sell fast. The link I posted now sold. If you manage to find a SC board maybe keep the old one as a project. Fault find it & Order the bits from china and take your time.
              • SuperSkippy
                • Nov 2012
                • 58
                • United Kingdom
                Yeah, to me :-)
                • tw2005
                  • Oct 2011
                  • 6458
                  Originally posted by SuperSkippy
                  Yeah, to me :-)
                  did you confirm with them it was for the 42"??
                  • SuperSkippy
                    • Nov 2012
                    • 58
                    • United Kingdom
                    No, but like you say, if it goes wrong I can pull the diodes from one and put in the board I've already got.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Well, that's fine in theory assuming you've found all the faulty parts?
                      So if you have not and you harvest the IGBTs into your board and they then blow again say, you're back where you started.
                      The point I was trying to make was if you were insistent of getting the parts OEM from quality sources at the prices I was seeing then yes that board was worth it for the parts.
                      I'll have a look through some manuals and see if I can spot what parts are different. I'm pretty sure someone got caught out with different connectors for the SU/SD boards.
                      I'm pretty sure yours should be TXNSC1EKUU, TNPA4829 rev AD
                      • tw2005
                        • Oct 2011
                        • 6458
                        Connectors at the buffers are different.
                        Transistors appear the same
                        IC16791 modules are different
                        CAPS have differences
                        inductors different values and locations.
                        diodes look the same
                        I expect the resistors will be the same, big list not checked.
                        So if it is the wrong version another alternative would be to transfer all of the above differences from your board to the replacement assuming they send a good one.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Spotted another difference, adjustment pots- 3 on yours, 2 on the 50"
                          So that will probably mean resistor difference(s) , there's at least 4 I can spot at a glance.
                          42
                          VR16600 50K
                          VR16601 5k
                          VR16841 20k
                          50
                          VR16600 50k
                          VR16601 5k
                          • SuperSkippy
                            • Nov 2012
                            • 58
                            • United Kingdom
                            Bump.
                            As you say, it's a similar but wrong board I've got.
                            The fact you can prepare these lists of components suggest you've got service manuals for these boards. Where did you get them from/can I have a copy?
                              I have some linked in my signature. A lot copied from Panasonic's China site when someone leaked the log in to me.
                              • tw2005
                                • Oct 2011
                                • 6458
                                42" Panasonic TNPA4829 AD
                                tc-p42u1, tx-p42s10b, tx-p42s11b, tx-p42u10b
                                46" Panasonic TNPA4829 AC
                                TC-P46U1, TX-P46S10B
                                50" PANASONIC TNPA4829 AB
                                TC-P50U1, TX-P50S10B
                                • masaudio
                                  • 16
                                  • England
                                  I have one of these boards in, and your parts list is a great help as we can order direct from Panasonic, glad someone out there can get onto the manuals..
                                  We have the board with Q402, Q421, Q422, Q661 & D865 all shorted, disconnecting them has removed all shorts from the board, so hopefully replacing them will cure the problem.
                                  (I think the parts list precedes the parts with 16, eg Q16402... ?)
                                  The SC board from Panasonic is £197.28 trade price
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Also check for shorts Q16701, Q16702, IC16773, IC16771, IC16464, IC16465,
                                    Measure resistance on P5V, and P15V line in, check FET driver ICs,
                                    If you get all those from Panasonic, it will be very expensive and good chance it's more than what you've listed and they'll blow again.
                                    Q16402, 2PG0090000R (2PG009) Panasonic IGBT; VCES (V): 510; Ic (A): 40; tf (µs) typ: 0.19; Vce typ: 1.95; Package: TO-220FN
                                    Q16421, Q16422, = GT30G123 (30G123) Toshiba IGBT; VCES (V): 430; Ic (A): 30;(200A Peak pulse); Vce typ: 2.2; Package: TO-220FN
                                    Q16661 = RJP6065DPP-90-T2 RENESAS IGBT; VCES (V): 630; Ic (A): 40; tf (µs) typ: 0.45; Vce typ: 1.8; Package: TO-220FN
                                    RJP63F3A would work. RENESAS
                                    D16865 = RF101L4S TE25, ROHM 400V 1A
                                    Q16701, = MMBTA92 NXP , PNP high-voltage transistor 300V 0.1A
                                    Q16702 = 2SD0601A0L,,2PD601ART, NXP , 50 V, 100 mA NPN general-purpose transistor
                                    Q16501,521,531,551,762, = SANYO, PNP / NPN Silicon Transistor, CPH5524-TL-E
                                    Q16647,607,608,817,818,874 = ROHM , Small switching N-channel MOSFET (30V, 0.1A) 2SK3018T106 (2N7002 will work, watch the package sizes)
                                    IC16771,= TOSHIBA TA78L05F(TE12L,F) , 78L05
                                    IC16464, IC16465 , IC16773 C0JBAB000715 = TOSHIBA TC7SH14F (TE85L), (Texas Instruments SN74AHC1G14DBVR)
                                    • SuperSkippy
                                      • Nov 2012
                                      • 58
                                      • United Kingdom
                                      Re: my original board- I just replaced the shorted transistors and they blew immediately again when I powered the set back on.
                                      I fixed my TV by buying another SC board in the end.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        I've just started working on the same board TNPA4829 AD.
                                        masaudio did you get anywhere with yours? I haven't started pulling components yet but from in-circuit tests it looks to have the same shorted components. Would be good to hear your experience.
                                        tw2005, thanks for all your work and posting on these sc boards. I've been reading your thread and it looks like it's going to be a big help. Will let you all know how I go and will probably have more questions.
