Element ELGFT554 Bad TCON Board or Tab Bond Issue? Advice?
  • jbrukardt
    • Mar 2013
    • 13
    Good evening everyone,
    I have an cheapie Element ELGFT554 (actually my third of the same model, all of which have failed spectacularly within 2 months of purchase or warranty replacement in the following manner:
    http://www.youtube.com/watch?v=smqpIVQRQX8
    Everything ive seen indicates this is a tab bond, or bad TCON board issue.
    I have disassembled my TV down to the bare boards and tab bonds, but need a little advice at this point.
    The problem is very unpredictable and intermittent, sometimes occurring straight for 3 hours, and then ceasing, sometimes occurring every 30 seconds. The one constant appears to be a brief cessation of errors when unplugged for a long period.
    This leads me to believe my problem is heat related. This is to a degree confirmed by the fact that i have had it running, with a signal piped to it without the metal shield and case on it for about 2 hours now, and not a single glitch.
    Enough talk, on to the pictures:
    edit: please see attachment files
    I have some berquist gap pad per this guide: https://www.badcaps.net/forum/showthread.php?t=25371
    But my tab bonds appear to connect differently.
    So, here are my questions:
    1) Where should i place the gap pad on the tab bonds on my set? I will do all the tab bond, although it is likely only one or two that are currently bad.
    2) I looked for bulging caps, did not see any immediately, what else should i check for on the boards. I am proficient with a multimeter and can solder.
    3) How can i tell who made this panel/boards? I know Elements are rebrand for the most part, im thinking it might be a funai, but i cant find any branding
    Any help would be greatly appreciated, and thank you for your patience.
  • jbrukardt
    • Mar 2013
    • 13
    Re: Element ELGFT554 Bad TCON Board or Tab Bond Issue? Advice?
    Just measured the tab bond temps with a laser thermometer, im running a little high, at 130F without the metal chassis on. I imagine when enclosed, that could shoot up to 190-200F
      Please edit your post and use file attachment to upload the pictures instead of posting them in line, it takes a long time to load the page, thanks.
      By the way, do not run the panel without the frame back place since the chips use the frame as heatsink or you damage the chips.
      Those chips can be as high as 155F.
      • jbrukardt
        • Mar 2013
        • 13
        Fixed the attachment files (sorry about that!)
        Turned the panel off. Temps were slowly rising (in the 130s), wont run it without the metal shield again.
        • jbrukardt
          • Mar 2013
          • 13
          Its a samsung panel by the way. Found a hidden sticker
          http://www.panelook.com/LTA550HJ07_S...view_7746.html
          • jbrukardt
            • Mar 2013
            • 13
            Applied gap pad to all the tab bonds, and the display driver chip on the TCON board. Put the whole display back together. Within 20 minutes, its flashing again
            Same frequency and variation as before.
            The fact that i have had three of these sets fail, each with the same mechanism leads me to believe either the bonds are already damaged (why the intermittence then?) or that theres a common part failure on the TCON board on all three.
            Initial visual inspection indicated the TCON and other boards were ok, no obvious damages. High Res images of all boards attached for reference in case anyone is interested in taking a look.
            The tricky thing is, when it was out of the chassis, it ran fine for upwards of two hours. When its in the chassis, failure within 20 mins. This leads me to believe heat is somehow an issue.
            Ideas?
              It looks to me like 12V to T-con is unstable, have you checked that? I would be surprised if the tab bonds caused this.
              • twelgs
                • May 2014
                • 1
                Do you have any of the tv bezels from your 3 tvs....I know slim chance but it is worth a try
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • thelankanguy
                  Sony KD-55X9000F TCON Issue
                  by thelankanguy
                  The TV shows a black screen with no image.
                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                  Later both ribbons were disconnected and TCON voltages were tested.
                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                  There is also a short to ground in this circled inductor.
                  Is this a TCON issue or something else ?...
                  12-13-2024, 12:27 AM
                • cagri
                  BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                  by cagri
                  I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                  PMIC: iML8940
                  There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                  Input 12v, fuse ok
                  DVDD1V2 = 1.2v
                  DVDD1V8 = 1.8v
                  DVDD3V3 = 3.3v
                  VGL = -7v
                  **VGH = -0.3v
                  **VCOM0, AVDD, HAVDD = 0v
                  SWBK1 = 3.3v
                  SW1 = 12v
                  VGH to GND resistance is 500kohm as expected
                  Readings are same after I disconnected the two cables from TCON to panel...
                  07-27-2023, 09:48 PM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • EazyBone
                  Vizio P759-G1, Tcon issue?
                  by EazyBone
                  Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                  Any help appreciated
                  https://youtu.be/tPeV2Q7TXIQ?feature=shared
                  03-22-2024, 03:25 PM
