Intro to bga reworking services
  • xboxhaxorz
    • Jan 2011
    • 196
    I will start this thread to have pertinent information about getting involved with reworking ie; reflow reball
    The company i work for has been in reworking for 3 yrs now, it is the bulk of our business
    The benefit of reworking is fixing things that would otherwise be unfixable or too expensive to replace
    Some examples:
    CPU socket is faulty ie; wont detect CPU you can replace that with a fresh socket or put fresh balls on the socket
    Laptops without power, many laptops have the SB chip which is the main chip on the board that controls i/o functions that will have the solder joints go faulty and by performing reworking on it power is restored
    Note: some power issues are related to QFN chips, resistors, regulators, mosfets etc and in this case a reflow or reball will do nothing
    Mainboard needs to be replaced and it is expensive and will take time to order but the customer needs it now, so simply rework the GPU and not have to worry about ordering parts
    Cell phones have bga related issues as do tablets
    Game consoles, TVs, GPS units, Motor Vehicle Gauges etc;
    Is it worth it:
    That depends on may factors such as cost, time, space etc;
    You HAVE to spend at minimum a grand to get started
    If you wish to talk about griddles, heat guns, ovens, etc; i simply will not offer help or support on that as its an improper repair
    It WILL probably work sometimes but if it does the repair will not last and this is why bga reworking has a bad name
    Those devices above are PERFECTLY fine for small components but NOT for bga components, using larger nozzles etc; is not suitable at all
    Depending on which boards you are going to rework will depend on the machine that you use, if you are going to work on cell phones then a small $300 system will work just fine and i would recommend not going bigger as the boards are very small and you want a small machine
    If you are going to work on laptops and Xbox 360, then a machine with about 3 240 x 60 heaters on the bottom will be suitable i prefer 4 but 3 will do the job since those boards are not as picky
    For PS3 you MUST have at minimum 4 240 x 60 heaters for the bottom as those boards have several layers in the pcb and contain large bga chips plus the board is just huge
    The reason you need proper bottom heating is because of board flex or warpage, if the board is not heated evenly it will bend in certain areas or may not heat the bga chip evenly causing solder ball bridges or shorts
    So with that in mind you can get a decent machine for around $700 that will support 3 heaters or maybe 4
    This is a machine that will work on laptops and Xbox 360s
    http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
    For PS3s this will do
    These are the cheapest machine that you should buy anything smaller or cheaper will not be sufficient and will cost you more in the end
    Now if you buy the smaller machine due to a lack of funds, you are not totally lost because you can upgrade the heaters later and then work on larger boards without issue
    These are german made heaters, you know the guys that make beamers
    If you do upgrade the heaters i recommend new relays or SSR, i bought mine from amazon that were made in USA opto22, relays control the heaters basically without relays the heat will always be on
    IR heaters in most machines are made in china thus they dont last as long as others and they will not provide even heating
    Also these machines are made in china so they do not pass safety inspections and some have reported the wiring catching fire etc;
    Now this is not often but it DOES happen, it hasnt happened to me so maybe i am just lucky
    I personally rewired my machine with thicker gauge so that way it was more efficient and safer
    Next is power issues, UK have no problem you guys have 220 and is best for those in the USA you have a few options buy a 110v machine which i do not recommend it will be a huge power hog, buy a 220v machine with transformer, personally i would not do it since a transformer is another piece of equipment that could go bad and if it does you have to order another, have a 220v line installed in your place
    I did it myself and no i am not a certified electrician so dont take my advice as such i simply used common sense and research
    Basically all buildings have 220 in the breaker box with 3 wires going to an outlet a live, ground and neutral
    The neutral is basically another ground or vice versa
    So get a double pole breaker and connect 2 lives and a ground thus eliminating the extra neutral
    So with 2 lives meaning 110 x 2 = 220 or 120 x 2 = 240 which is still no problem as machines are rated up to work on 240 and that is the power that aussies use
    http://www.youtube.com/watch?v=qdZFXNd2qN8
    I am not responsible if you die, this video is made by a regular guy without a electricians license
    If you hire an electrician, it should cost no more than $200
    Many people use dryer plugs, but check google for that
    You will need some tools and accessories as well
    Flux is a MUST, and there are tons ie; Amtech, Kester, Kingbo, Magic, Super bla bla
    Amtech is SUPPOSED to be the best but there are SOOOOOOOO many fakes out there and if you do get original it will cost quite a bit
    I use Kingbo, but i have all of the above fluxes and that was to do some testing in the end Kingbo was overall the best mainly because it lasted up to 240c in temperature where as most would burn out at 200c which is essentially useless for reworking BUT for soldering is fine
    Alcohol, Acetone, Mek are cleaning chemicals
    I use denatured alcohol most of the time it removes thermal compound pretty easy and cleans residue flux without issue
    Acetone is stronger so i use that if needed and finally MEK is basically Acetone but doesnt dry as quick
    IPA = Alcohol but you need 99% and its either hard to find or expensive, Denatured can be found at a hardware store sooooooooo i use that
    If you get a board in that was previously repaired, which we do often they probably used some weird flux or other goo and it looks so awful so you must clean it off and that is where those chemicals come into play
    Cleaning the heatsinks is also needed
    Supporting the board is CRUCIAL as you could have a million dollar machine if you dont support the board it will bend and flex
    For game consoles there are pre made supports that fit the specific models
    Other boards mainly laptops you can use the included support system that comes with machine since they are not as large or thick as game console boards but that may change
    That is all that is needed for reflow, if you want to reball you will need the following:
    Solder balls
    Rework jig
    Vacuum pen
    Stencils
    Braid
    Buy it pre made, piece it together however you want to do it you need those items
    This is a pre made kit
    Using the machine is not super easy but not super hard and the machines above come with pre programmed profiles
    A profile is basically the heating instructions you give the machine which include the temperature, time and speed
    Speed is easy i just set it to 2 and its safe
    Time is something you need to figure out by how long it takes to get to set point and how long you want it heated at that point
    Temperature is the amount of heat generated at that time, your not going to go from 0 to 280 right away it has to be gradual or you will cause thermal shock
    The pre programmed files should be used as a starting point and you will adjust the values based upon your environment, board type, flux used, machine type etc;
    Most common way to control a machine is with a PID controller, they are also used in cooking and are relatively simple to use by following the manual closely
    The controllers contain advanced features for fine tuning, but its best to leave them be and leave the default values set
    There are then the touch screen controllers which are usually even easier to use but arent required, some of them have built in graphs to view the profile in action, the non touch models tend to offer PC control via serial or usb to start and stop the profile and watch the graph
    YES its cool, but after a mth i stopped using the pc and controlled it from the controller since using a PC was just not needed
    The profile is definitely a very important part of reworking as without proper instructions the machine can not do its job, and a properly set profile decides if you win or loose with repair
    Many people borrow, trade, purchase profiles and this will go on for a while the fact is Joe can not use Bobs profile even if he has the same machine
    His environment is different he may rework in a basement with humidity or by a lake with dry air etc;
  • xboxhaxorz
    • Jan 2011
    • 196
    Re: Intro to bga reworking services
    Now there is no doubt that the profile MAY work, but it will not be optimal because you MUST develop your own and test it appropriately
    Reflow and Reball are essentially almost the same when you heat a chip and the connections are REflowed when you put new balls on a chip you have REballed it hence the terms
    Now there is chip lifting and placing which is the better repair and involves reballing a chip and then reflowing it to the board
    Reflow is NOT bad its simply been given a bad name and most people do not do it right as you must have the solder become liquidous for 30 to 90 sec but this is a problem for many as when the solder is liquidous they start cooling it or if they have improper equipment while the solder is liquid if the heat is not even or not properly bolted or supported it will flex
    Improper equipment means you can not maintain a consistent temperature and with lead solder there is room for error at 200 to 220c but with lead free there is almost no room for error since you are close to the temperature tolerances most bga packages can go up to 250c some only 240c and since you have to hit around 235c to properly melt balls you are very close to danger zone and if your heat is not even the left side may be 245 while the right is 230c which means you may have killed the chip or the left side may be 220c and the right side is 227c so chances are the chip was not properly heated as only half the chip had the connections fixed so while it MAY work and you think you FIXED it and it will probably return to you for warranty purposes
    With the the term reballing you simply do it all the same just lift so if part of the chip is not heated properly then well your going to lift traces and or pads which is EXTREMELY time consuming repair and most of the time not worth it anywho
    This involves using a vacuum suction pen which grabs the chip and allows you to lift it off, these are usually calibrated with the right amount of vacuum but i dont know all the details all i know is it lifts but if there is too much resistance it generally wont allow you too but if you were using tweezers or pliers you would rip that sucker off
    If you happen to get resistance when lifting which means if you lift and it doesnt just plop off then either the solder is not fully liquid or there is epoxy in the way
    Epoxy is horrible and is always on laptops, usually i use some dull tweezers to remove it using an smt station with a small nozzle
    So lets say you didnt lift pads but now you have to put balls on the chip so you clean the board and the chip, but its not that easy
    Cleaning vid
    Lets say you did everything right up until cleaning and you have a radio shack iron there is no way you can clean the way shown above, it will take a lot longer and you may not do a great job, or you will lift pads or damage the solder mask
    Most of the time damage to pads occurs, solder mask damage is not as common and at this point you need a new chip however if this happened on the board you can now tell the customer you ruined there board as you were not qualified to do this repair
    Cleaning is not DIFFICULT but it does require skill and the right tools, i was using a Hakko 937 which was so old and beat up but it worked well i bought it used off ebay just got a new tip and i was fine and for regular soldering it worked so well
    For cleaning it worked but i had trouble and it took a long time to clean, i was able to improve my cleaning by using Kingbo flux and the best BGA braid i could find however i still had lifted pads and trace damage and i was unhappy and since it was MY fault i gave the customer a refurbished board
    I ended up getting a better iron which supported cartridge style tips and this means the heater is in the tip but of course this is a specialty station so the tips and station are pricey but after i was able to clean a board in less time than it takes you to change channels i stopped crying on how much i spent
    So if you did manage to clean it PROPERLY, since you invested time and money into the right tools and knowledge it is time to put balls on the chip
    Get your girlfriend and have her do this part, they are usually better working with the balls, you need a jig and there are 2 types direct heat and non direct heat but i refer to the non as 90mm jigs and then you need direct heat stencils or 90mm stencils along with appropriate size solder balls
    Usually 0.6mm, 0.5mm, 0.45mm, and 0.76mm are most common and it will say the size on the stencil, thank your local china man for that
    Then you ensure everything is top notch clean and proceed to put balls on the chip, after you have it all aligned you heat the chip so the solder balls land on each pad and stay
    With the fresh solder balls on the chip you place it on the board and reheat it after cool down you test and either it works or it did not
    You need to align the chip PROPERLY on the board, there are many ways to do this and usually just by looking you can get it right, some boards have lines so you can position it right and others have so many balls and are huge chips it is an impossible feat and nobody can help you just takes practice
    Now if you want to be a cheater, use this
    I tend to do reflows almost all the time, and only do a reball if necessary which means the flow was not successful or the chip was fried and you need a new chip
    Sometimes customers are smart and request it upfront so we do it at that point
    For repairs at our store reflows last a long time and we offer a 3 mth warranty on the repair but about 2% of customers return for warranty related issues
    The reballs obviously last much longer and we barely get any of those back
    Now in some cases if a reflow returns, we then do the reball and its fixed which means that either the previous repair was not done properly or the solder was just too weak or contaminated or it just wanted to be a pain
    Some boards will arrive previously worked on, and there will be debris underneath the chip so we have no choice but to reball as a reflow will work but the debris will be in the way of the connection causing intermittent issues
    Now just because you can lift chips and reball and reflow doesnt mean you have a great repair as a reball can come back in 24 hrs just as a reflow can due to improper heating meaning the solder did not melt evenly or fully
    Usually if the chip is seated lower to the board it was flown properly provided its even on all sides, if that checks out its possible the chip was dying and when the customer used it the chip finally said bye time to die
    There are tons of machines, tools and accessories out there and you can buy them from China, US, UK, Japan, Chile etc;
    Knowing who to buy from and which brand is a key to success, there are fakes and cheapo products out there
    I have provided my product recommendations which you are free to follow or go on your own venture
    We started with a manual machine, then went semi auto and now fully auto which is mainly the machine we use now
    The manual was Quartz, the semi was IR and the full is Hot Air
    Personally i prefer IR, but some people are vice versa and prefer HA
    In my article below i go into the better details
    Choosing a rework station
    Proper reworking process
    Reball Reflow
    More coming soon, im tired so dont reply yet until i am finished with the important info
    My grammar, spelling etc; is bad i know and is why i repair and do not revise reports
    • smason
      • 1652
      Great post, very interesting, thanks.
      I have nothing to add about any aspect of reballing, but I will say be careful working with MEK (and probably Acetone too) make sure you're in a well-ventilated area. A job I had many moons ago involved using MEK to clean printer parts, and I wound up in bed with the worst headache I've ever experienced (and I was no stranger to migranes/cluster headaches already)
      If I had had a gun, I would have used it on myself.
      Must not make smart-assed comment....
      We're not in VIP, it was a very informative post, must not sully it with childish comment... Arrrgh must resist....
        ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
        This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-12-2024, 03:28 PM
      • CG2
        Janome DC3050 Sewing Machine Pedal Resistance
        by CG2
        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
        04-14-2023, 07:53 AM
      • Geomih
        CPU socket replacement soldering profile
        by Geomih
        Hi All - I am hoping someone can help with some pointers (complete noob here!)
        I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
        My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
        The simple stuff like a small memory module isn't a big deal because there are
        12-11-2023, 11:07 AM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        Hi everyone,
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
      • Stanley1843
        BEST 505 Vs Mechanic Brand Reballing Balls with Lead
        by Stanley1843
        has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
        06-22-2024, 11:06 AM
