Later Model AT Boards
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I tried to build up a later model AT system tonight:
    -386 era case, very well built and compact
    -PC power and cooling turboslim 300
    -Asus P2B-B
    I fired it up... and the mobo didn't detect half the RAM, my keyboard, or the hdd.
    Given how poorly stored the mobo was, I'm guessing it got static zapped... IIRC all the parts not detected teszted out good (including the HDD cable, it was NOS).
    Anyway... Since I still have a tricked AT case (with 2 serials, a PS2-mouse, a parallel, and 2 usb ports in the back) with a kickass PSU, I'd kinda like to get another mobo to put in it.
    So, what was the latest CPU cores they made AT boards for (that I can get without paying primo)? And better yet, anybody happen to have one sitting?
    PS- I have all kinds of old CPUs... so chances are thats not a problem. Even slot 1 coppermines and Slot A athlons.
    sigpic
    (Insert witty quote here)
  • c_hegge
    • Sep 2009
    • 5219
    Re: Later Model AT Boards
    Last AT boards were for Pentium 2 (Slot 1).
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      So the same series as mine then (it's a PII board with early PIII support, I was using a PIII Katmai 550mhz).
      I swore I saw slot A boards for AT though... I may have to do some ebay surfing (as much as I hate ebaying mobos anymore).
      sigpic
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        In the past, when I was doing a King Canute trying to resist the ATX tide, I hankered after a GA-6VA7+ which was an expensive and hard to find S370 board
        Still have a Slot1 P2-99B running a Celeron 1000 with my modified BIOS - given the quality of Asus from those days it'll probably be around a while longer
        • bigbeark
          • Jan 2010
          • 661
          Every Asus P2B, P2B, P2B-DS that has ever been in my possession has always reported exactly half the actual ram installed.
          All these boards ran perfectly otherwise.
          I never succeeded in finding ram that would cause the Bios to report properly.
          I always installed the max on the P2B-D boards: 4x256 (1GB) which is always reported as 512MB
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I had 2 256's and a 128... But come to think of it I bet the chipset is no good for that much. %^&* you intel!
            edit- it says it will do up to 768mb... Weird!
            Not sure about the keyboard... Could be a bad one, Its half-untested...
            the hdd shouls have ran... I'll try again though.
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              I used to have a soyo slot 1 board with a P3 450 in it. forgot the model, but it was the only one I've ever seen.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                After swapping crap around... I got it to run!
                The keyboard must have been loose... I eventually got it to accept.
                The 40gb HDD it didnt like... it was fine with a 4gb fujitsu and a 20gb WD (what I am using now, had an old ubuntu install lingering).
                (posting from it, actually)
                It runs a pIII 550MHZ... I got it to like (and read) 2 512mb sticks... I bought the board NOS in box (no accessories) at a thrift store for $2 a long time ago... I bet it needs fresh bios (has 1010 on it).
                quirky as hell... but hey, it runs!
                sigpic
                • BigTroll
                  • Sep 2010
                  • 1317
                  • LAMBDA SOND
                  Sound like a great build I got the P2B i will be using for a vintage gaming rig, I bet drivers for windows 98 will be hard to come by but yeah can't wait for pics.
                  My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Other notes:
                    -I installed debian on the 20gb drive... a tad slow and buggy, Not sure why about the latter.
                    - I looked, the 40gb HDD issue is indeed BIOS related...
                    It otherwise has been running well... when I have time I'll shoot some pics.
                    sigpic
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      SY-6bb? I ran it with a 300 MHz Celeron overclocked to 450 MHz, the only time I ever overclocked. There's a BIOS patch for support of 137GB HDs, but apparently it doesn't fix the problem involving false temperature readings for the nonexistent second CPU, which has resulted in the police siren noise and need to reflash the BIOS.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        I do believe that was it. This was back in the late 90's, I never had an IDE larger than that back then. I do remember the police siren temp warning though... I remember the false reading being so high that if it were real, the CPU should start melting.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • sofTest
                          • Aug 2008
                          • 361
                          Other notes:
                          I ran a P2B-S (ATX only) rig for many years, and found the onboard IDE useless (UDMA/33 only). For OS/apps I used SCSI, and for general storage, I had an add-on ATA card (UDMA/100). I also recommend the beta-BIOS. Overall, this was the most stable non-portable rig I've had, until it started to develop issues after many years of 24/7 running. Did everything I could to prolong its use, including a PowerLeap/Tualatin upgrade.
                          Be a mensch
                            HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 05:27 AM
                            HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                            This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          • ugamazing
                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                            by ugamazing
                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                            12-17-2024, 07:05 PM
                            HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                            This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
