CFI-S969L Bulged Capacitors
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I'm turning it into a carputer eventually, in fact I've already set it up pretty much.
    Only problem is bad caps, probably caused by the power supply it was on having 2 bulged fuhjyyu capacitors.
    All caps on this board are crap!
    Bulged caps:
    1x CHOCON 1000uF 10v (purple)
    2x CHOCON (can't tell specs)(green, by CPU)
    I've highlighted on an image on Google Images what's bulged.
    Should I replace them all or just the bulgers? And what are the chodecons (lol) by the CPU?
    What is a good series?
    And more important, would recapping the 2 BSODs I've gotten?
    Thank you!
  • c_hegge
    • Sep 2009
    • 5219
    Re: CFI-S969L Bulged Capacitors
    Recap ALL of the choke-cons . Use https://www.badcaps.net/store/produc...roducts_id=164 for the 10V 1000uF caps (and you might wanna order a few hundred of them, since HM are soon to be discontinued )
    Yes, recapping may very well fix the BSoD problems.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      a few hundred? I'm not rich!! Maybe I can get 20. Not 200 :P
      • c_hegge
        • Sep 2009
        • 5219
        I was joking. It's just because they may not be available forever.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I use about 10 caps/year. But it's food for thought.
          • c_hegge
            • Sep 2009
            • 5219
            I easily go through a few hundred a year.
            Back on topic, though, You're gonna have to remove one of those smaller caps if you can't read the specs with it mounted.
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
              by sam_sam_sam
              I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
              This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
            • ctroxtell
              Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
              by ctroxtell
              I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
              01-03-2025, 08:57 PM
