failure point in Viewsonic VT2230-M
  • kturnerga
    • Apr 2010
    • 20
    I have a VT2230-M TV that displays the Viewsonic bird bitmap then displays no image though you can see the backlit screen (no words readable even if up close) . I cannot turn it off by the power button, which stays lit all of the time. All but one of the caps (630UF 35v) was replaced on the power supply. I think it is the main board. As the main boards are as rare as hen's teeth I wonder if there is a common failure point I can remedy easily or do I just need to wait for a decently-priced board? The caps look good on the main board and they looked good on the power board. This has me puzzled.
    KT
    Re: failure point in Viewsonic VT2230-M
    If you can post the pictures of all the boards, that will help.
    On the main board, I would check the voltages of the regulator IC's first.
    • kturnerga
      • Apr 2010
      • 20
      I did not see any reg chips on the main board (the I/O board) but did see three or four on the power board. The yellow board is the power and the green is what I call the main board.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Not sure if you are saying the backlights stay lit but no picture or backlights go out but can see faint picture. I would replace that last cap ? what brand/series caps did you use for replacements.
        With it all connected up lease check the voltages on the connectors and list results
        eg CN1
        Pin 1 5v Actual 4.9v
        Pin 2 5V Actual 5.1v
        Pin 3 PSOn 1.2v etc etc
        Try and do it once when it has reached its stable not working stage and with a few attempts when it is trying to come on. On the PSON be measuring it when you press the on button and report if it changes. Although low voltages being measured take care as parts of the board could be at 300-400 volts.
        Q30 is a LD1117A Voltage regulator - can you test for shorts (see 2 seconds to black guide link below)and the voltages - use a ground screw for the negative probe and check the 3 pins
        left to right - ignore the fat tab. Post results
        Next as you did get a picture flash can you check the secondary windings on the inverter transformers POwer Off meter on ohms 2000. I m not sure which pins as you have not posted pictures of the bottom of the boards.
        It may be just the 2 pins on their own at the end we cant see or
        IF your transformers look like the one in this picture then it is beteen S1 and S2 If it is neither of these you will need to go around all the pins in turn 1 to 2 1to3 then 2 to3 2 to4 and so on until you have done them all. Unless you can find a part number and datasheet. You are most likely looking for between 400 and 1800 ohms
        Read this (start at post 19)
        Please can you update you profile with country and mains voltage.
        • kturnerga
          • Apr 2010
          • 20
          I get the Viewsonic logo for about five seconds then the backlight stays on with no pic or even a NO SIGNAL. I may test the regs or just replace them. I am leery of testing live gear though techs tend to do that on a regular basis.
          USA; nation
          110V AC
          • retiredcaps
            • Apr 2010
            • 9271
            Q30 is a voltage regulator on your main board. It looks like an LD1117A.
            edit: oops didn't see that selldoor already had it covered in post #4.
            --- begin sig file ---
            --- end sig file ---
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              "I am leery of testing live gear"
              Ok if your not going to do live testing, I can understand that but I think you are on the wrong forum. If you are going to replace parts without testing you may as well just replace the board.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Uh-oh! I see some fake Nippon Chemi-con caps in the PSU which look suspicious, they have X vents instead of the Y vent.
                Muh-soggy-knee
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Great catch. Now that I look again, I should have noticed that.
                  • kturnerga
                    • Apr 2010
                    • 20
                    I'll be sure I'm not alone at home when I test it live should I tangle with the 110v by mistake.
                    I also bought the caps off Ebay (the fake Chemicons). Little did I know.
                    I tested the 1117; it does not have a short and the voltage (may have it bass ackwards) is Pin 1; 2.89v; Pin 3; 5v.
                    There is a mild whine from the area of the power supply as if that is meaningful.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Ok, Im no tech and have 250 volts to contend with.Most of the testing is low voltage - you will usually be told if high voltage is involved.
                      Oddly your PS Board does not seem to be marked with High Voltage area - I have marked them roughly on the picture and you shouldnt touch heatsinks.
                      You could even make a card cap to cover most of it while you are working. Main board has only low voltages.
                      Whilst the caps will need replacing,good spot Ben7, you can continue with some tests.
                      You have not told us what pin 2 measured on the 1117a.
                      I suggest you do the inverter transformer secondary windings next,(see post 4). If they have gone and you cannot find replacements there is little point in replacing the caps.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Good precaution. I normally use insulated aligator clips when measuring something high voltage. That way, I can make the measurements hands free and have everything plugged into a power bar that I can safely switch on and off.
                        It also helps if you have a quality multimeter with some input protection.
                        99% of the caps on ebay are fakes. It takes a trained eye and test equipment to know the fakes from the real ones.
                        Stick with name brand distributors like digikey, mouser, or the badcaps.net store where you are guaranteed to get the real goods.
                        • kturnerga
                          • Apr 2010
                          • 20
                          Both transformers ohm at .2 on p1 and p2 and at 1 on S1 and 2.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            For S1 and S2, you want your manual multimeter set to the 2000 (2k) ohm scale. Report your readings with this new scale.
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • ygorsan
                              LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                              by ygorsan
                              Hi everyone,
                              I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                              🧩 Problem Summary:
                              • The TV keeps scrolling through the menu or selecting items by itself.
                              • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                              • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                              • I
                              07-28-2025, 08:34 AM
                            • jb_Bak
                              by jb_Bak
                              CN6401
                              Pin 01 NC
                              Pin 02 NC
                              Pin 03 "BL_ON": 0V
                              Pin 04 "N/C"
                              Pin 05 "STBY 3.3V": 3.5V
                              Pin 06 "GND": N/C
                              Pin 07 "AC_OFF"...
                              09-27-2021, 04:52 PM
                            • JDC
                              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                              by JDC
                              ONN 100012588
                              Issue: No Power, Then Rebooting After Main Board Change
                              Short answer: replace main board and power board
                              Technical answer: replace main board and Q306 & Q307 on power board.
                              Long answer:
                              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                              07-15-2022, 07:39 AM
