Best forum I have found.
After following the threads on Vizio42L "No Sound and No Picture" I have repaired my TV. The problem turned out to be a bad T-Con which I replaced. After checking all the main board voltages, which were okay and since I had a backlight( the inverters were okay) I replaced the T-Con and it worked.
There is a bad LDO (U9) on the bad T-Con which I would like to replace, to see if it will work.
Numbers on it are R79164A and 15PG9H30W. It is the same size as U33 on the main board. I can not find any reference to these number at Mouser or Digi-Key. I checked the voltages on the good T-Con an they are 3.3,1.6 and 0. The same as on U8 on the main board, but U8 is a fixed output. I think the "A" in the number mean "Auto" but I am not sure.
Would an LD1117a Same as U33 work in this application? The footprint is the same.
Thanks for a good forum, David
