LG 50PG3000-ZA help needed please.
  • krislgnovicve
    • Feb 2012
    • 7
    Firstly thank you for providing such a huge site of knowledge!
    I have been looking round the internet for some time today looking for information on my problem and most of the searches i came across lead me here.
    So anyway here is my problem..... (common problem from what I've read)
    Yes you guessed it... No picture but I have sound.
    It is just out of warranty but LG agreed to fix it if the problem was under £250. An engineer called today to tell me I needed a new Y-SUS board and 2 Scan Modules (he must be good as he didn't even take the back of the unit off!), he then went on to say that he would be unable to repair it as it would cost £380.
    I have had a look round the site and I'm now here.....
    1. I have taken off the back cover and located all the boards
    2. Power up shows green power light on both front panel and rear control board.
    3. Fuse ok on PCB and heat syncs are all warm after 30 mins.
    4. Fuse ok on ZSUS and heat syncs are all warm after 30 mins.
    5. Fuse ok on YSUS but heat syncs are cold after 30 mins.
    6. The fuses I have checked are the obvious ones that look like glass fuses.
    7. No bulging caps etc (well that I can see anyway)
    8. The outputs of the Va & Vs are as follows... Va: 58.3v Vs:184.8v
    Now that's where I'm up to.
    Oh forgot to mention that the TV man offered me £20 to take the TV away if I didn't want it repairing, I said no obviously
    Any help would be great.
    Thanks in advance.
    Re: LG 50PG3000-ZA help needed please.
    The TV tech is probably right, though the buffers may be okay.
    Try disconnecting just one of the buffers and seeing if the picture comes back on half the screen.
    • krislgnovicve
      • Feb 2012
      • 7
      Thanks for the quick response Tom
      Quickie tho.. Do I need to disconnect the whole board or just the ribbon?
      also what about the small cable that connects the two together?
      • krislgnovicve
        • Feb 2012
        • 7
        UPDATE:
        Ok I removed the top buffer and and still no picture, replaced top buffer and removed bottom buffer and now I have half a picture?
        Although top half of picture has a few black lines through it.
          Originally posted by krislgnovicve
          UPDATE:
          If removing the bottom buffer fixes it, then the bottom is failed, and that is all you should need to replace. Buffer boards are usually pretty cheap used on eBay or TV repair websites.
          The lines are likely caused by a loose connection between the buffer and plasma panel (which you may have made while removing a board.)
          It is only usually necessary to disconnect it from the sustain board. The electrodes in a plasma panel are isolated from each other and only come into play when power is applied. Disconnecting the ribbons is a pain, because you can often mis-seat them when reconnecting causing lines on the screen.
          The small cable is a sync cable and should ideally be disconnected as it may carry power between the boards.
          I've written some guides on this:
          Lines on screen: https://www.badcaps.net/forum/showpo...40&postcount=3
          No picture: https://www.badcaps.net/forum/showpo...42&postcount=4
          • krislgnovicve
            • Feb 2012
            • 7
            So all in all I don't need to replace the YSUS just yet just the bottom buffer?
            Sorry to be a pain.
              Sorry to be a pain.
              Yes, as that's the board that when removed restores the picture. It is shorted, which means it is stopping the Y-sus board from working. (On older plasmas the failure of a buffer used to kill the Y-sus board too, necessitating a repair of that, but newer ones are better.)
              What is the part # on that board?
              • krislgnovicve
                • Feb 2012
                • 7
                The lower buffer which i removed has part number: EAX50051401
                  Lowest price I can find on eBay is ~£55 (http://www.ebay.co.uk/itm/BRAND-NEW-...item2a191a1637), which is a rip off, but at least it's cheaper than £380.
                  • krislgnovicve
                    • Feb 2012
                    • 7
                    Thanks for all your help Tom, I will have to wait till Payday (Friday) before I can get a new part. Seen this tho, would this work? http://digitalcityelectronics.ecrate...ve-eax50051002
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Boy, that just reeks of let's take advantage of the customer.
                      --- begin sig file ---
                      --- end sig file ---
                        If the part # is the same and it looks identical, probably compatible.
                        But since the part # doesn't match, I wouldn't risk it.
                          I agree but if you think about it, he's probably playing from the same song sheet as LG, so will actually replace all three boards which might cost him £200 total. But it's still a big margin for him.
                          • krislgnovicve
                            • Feb 2012
                            • 7
                            Managed to order the part for £42.59 inc VAT, downside 7-10 days delivery.
                            Will let you know how it goes. Thanks again Tom.
                            • Grant6000000
                              • Mar 2012
                              • 1
                              • United Kingdom
                              Hi, where did you order the part from, as I need exactly the same part.
                              Grant
                              • nex91
                                • Nov 2012
                                • 37
                                • Austria
                                Hello i have a same problem... I got LG 50PG3000 plasma tv as a gift from my brother because he bought a 3D tv... TV worked fine for him and when i brought it home,i have no picture...I just said .I cant believe that it is broken because transport was 30 minutes long... Sound works... I followed this instruction above and i removed back panel,removed one of buffers,first the bottom one-nothing... Then i removed the top one and i get the picture but just lines only... What should i do? It is just strange situation... I will upload a pictures... Thanks in advance!!!
                                Sorry for my english,i am from Austria...
                                  Your English is fine -- better than my German!
                                  Since you have a lit up screen with messed up picture on bottom half, your top buffer board is likely bad.
                                  Y-sustain, Z-sustain, control board, power supply, main board and bottom buffer are likely OK.
                                  • nex91
                                    • Nov 2012
                                    • 37
                                    • Austria
                                    sto when i buy top buffer i will solve the problem and tv will work good? its that the only thing i should buy? can i buy this one?
                                    http://www.ebay.de/itm/Y-Buffer-f-LG...#ht_500wt_1180 Thanks!
                                      Assuming that is the top buffer (and not the bottom one), that is all you should need.
                                      • nex91
                                        • Nov 2012
                                        • 37
                                        • Austria
                                        So one more question,sorry for anoying... Is this (half) screen that i get ok? i cant get normal half picture? that part from ebay,is THAT that i need ? i ask because i dont want to buy and tv not to work again,because i am a student too thanks so much
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
