bad Advueu LCD monitor, blown capacitor
  • jboker
    • Apr 2006
    • 4
    i was sitting at my computer and could smell something burning... it was my monitor that is out of warranty. i opened it up and found a burned up capacitor and im trying to figure out where to get a replacement, everywhere i've looked doesnt have it. Does anyone have any ideas?
    thanks in advance
  • Rainbow
    • Aug 2005
    • 1374
    Re: bad Advueu LCD monitor, blown capacitor
    It's a ceramic capacitor rated for 3kV. The capacitance value is not fully readable, check the value on the other one (they should be the same).
    • jboker
      • Apr 2006
      • 4
      yeah, it says 18J 3KV, so it's 18pf with a +/- 5% tolerence, correct?
      i've been searching and havent found anything. most caps arent rated with that high a voltage.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        http://www.elfa.se/elfa-bin/dyndok.p...0&dok=4946.htm
        • jboker
          • Apr 2006
          • 4
          i am by no means an electronics person, so excuse my ignorance, but which capacitor would do the job?
          • mbates14
            • May 2005
            • 169
            you can use a 1 nanofarad at 3kv for replacment.
            but you gotta look at the cause of the failure. arcing being a possibility? those ceramics just dont "fail" like that. unless there is a cause.
            • Spyke
              • Aug 2006
              • 13
              This is just the direct output to the CCFL series'd with the capacitor. I don't see how there can be a cause of failure other than a defective part. If you have any cheap CCFL kits that people tend to shove in their towers these days, you'll find the same caps inside the little inverter boxes. Nab one from there if you have one readily available.
              • dm90
                • Apr 2009
                • 3
                i too am looking for the same cap but wth no luck anywhere, any new ideas on where to look
                • PlainBill
                  • Feb 2009
                  • 7034
                  Digi-key has them, their part number P9645-ND. It's a Panasonic KGE series, designed for the 'Ballast circuit of LCD backlighting inverter'. The only problem is you will have to buy 10 of them. With shipping your total cost will be under $6.00 IF you are in the US.
                  PlainBill
                  • NxB
                    • Feb 2009
                    • 1595
                    Burnt pretty bad. I wonder how the transformer and the lamp are doing.
                    • dm90
                      • Apr 2009
                      • 3
                      Thank you very much for the part number, jst finished my order. well it wasnt burt at all, im thnkn one of thm are getting weak maby, becuz the monitor will com on for a breif second and thn goes dark, so i fig it ws a gd place to start
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Ohhh-Kayyy.
                        Well, when you check back because replacing those caps didn't help please feel free to withhold other pertinent information. Parts suppliers need all the orders they can get.
                        PlainBill
                        • dm90
                          • Apr 2009
                          • 3
                          well whn i did a search for the cause of the problem, thts all i cud find for a fpd1730, the 4 amp fuse tht is normally the problem wth tht model is gd. and i have a fdp1530 tht does the same thng. so im open for other suggestions, im jst starting whth wht ive gt so far. i dnt thnk they will gt rich wth my little ol 5 buck order
                          • MeetingIncapable
                            Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                            by MeetingIncapable
                            I am new to repairing computer electronics, so excuse any mistakes I make.
                            A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                            I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                            I wanted to replace the capacitor, but I have two questions:
                            • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                            • How do I determine the rating/value of this capacitor? or something
                            05-04-2024, 09:56 AM
                            by momaka
                            03-15-2023, 10:17 PM
                          • tony359
                            Bipolar capacitor for vintage Apple CRT monitor
                            by tony359
                            Good day all,
                            I have a question about some old monochrome Apple monitors.
                            Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                            A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                            The new capacitor:...
                            08-12-2024, 03:27 AM
                          • wattage
                            AOC AG493UCX 49-inch monitor - Firmware request
                            by wattage
                            Hello Badcaps Community,
                            I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                            07-13-2025, 04:41 PM
                          • ant3202
                            HP 27es - LED monitor - Monitor Flashing On - Off
                            by ant3202
                            Hi Everyone
                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                            https://www.badcaps.net/forum/troubl...lashing-on-off
                            The monitor is HP 27es LED Monitor
                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                            The monitor will randomly blackout and display no signal and will recover again.
                            Sometimes need to power and off again to restore the display but...
                            03-20-2025, 07:30 PM
