BenQ T201WA (4H.09C02.A01 power board) doesn´t turn on
  • blackrider1
    • May 2011
    • 28
    Hello,one day ago, when I turnned my pc off, the power led of this monitor stayed orange with no response on pressing the switch.
    I switched it on again and it was working fine, but when I pressed the power switch (of the LCD) instead of turning ON/OFF, it just showed me the bright control panel.
    I disconected the power from the wall, and now, it doesn´t turn on anymore.
    I checked fuse F601 (OK) Bridge rectifier BD601 (OK) and filter cap C605 (OK)
    When checking IC601 (NCP1203P60) I´m getting 10 vcc at pin 6. Is it a normal meassure? Should I get between 16 & 20 vcc?
    This board has these ELLITE crappy caps but all of them seems to be OK.
    I can´t find any schematics for this board although I know it is used in, at least, ASUS VW222S & FP222W BenQ.
    What do you advise me to test now? Remember that the power led doesn´t turn on.
    I can´t test CN701 because I don´t know the pinouts values.
    By the way, I resoldered everything to avoid cold solders.
  • PlainBill
    • Feb 2009
    • 7034
    Re: BenQ T201WA (4H.09C02.A01 power board) doesn´t turn on
    Excellent job of troubleshooting, and the labeled pictures are a big help. Getting really nit-picky, I prefer working with pictures where the board has been flipped left to right rather than top to bottom. The next biggest problem is a few spelling errors. If I were grading, you'd get a high 'A'.
    There are a few points you have missed. It IS possible to measure the voltages on CN701; it would be harder to establish what the voltages should be. Here's a summary, reading from left to right.
    Pin Function
    1 N/C
    2-3 V1 (probably 5 volts) out
    4-6 GND
    7-8 V2 (probably 12 volts) out
    9-12 Inverter and audio amp controls
    10 volts at pin 6 is indeterminate - it's below the startup threshold, but within the operating range. What you neglected to say is if the voltage is steady, or if it changes.
    As a PRELIMINARY diagnosis, IC601 is defective. It generates Vcc for startup internally, SMPS controllers that do this tend to have a high failure rate. Another possibility is the startup cap (C606 or C611). And it might be a short on one of the outputs.
    These are the points to check
    1 Voltage on IC601, pin 6. If it pulses, the IC is probably good.
    2.Voltages on CN701 pins 2-3 and 7-8. If they both pulse, the ouput diodes are probably good.
    3. With power off, check the resistance from V1 to Gnd and V2 to Gnd.
    PlainBill
    • blackrider1
      • May 2011
      • 28
      Thanks PlainBill.
      Well, voltage on pin 6 is, when off, always 10,23 v and no pulses. I say when off because now it´s working again!!!!!
      I reassambled everything, like in the picture and the power switch worked.
      I´ve been able to start it up.Then I´ve turned it off and it keeps on not working.
      I´ve tried to read again the voltage at pin 6 (10,23v) and when trying to switch it on again, it has worked again (weird!!).
      Now the LCD is on, with the green power led on, but not responses when pressing it. It doesn´t switch the LCD off. I´m getting 14,29 v at pin 6 right now.
      Everything works fine except switching ON/OFF.
      May be something related to minimum and maximus working vcc of the IC, that causes IC to be blocked?
      Now is on, so if you want me to check anything else while working, just tell me.
      By the way, resistance between V1/GND and V2/GND was decreassing from 13-14 to cero (I stopped testing at 4 or 3) in about 2 minutes, I mean, slowly.
      • PlainBill
        • Feb 2009
        • 7034
        Thanks PlainBill.
        Strange behavior; it almost sounds like a bad solder connection.
        One point; you misunderstand the function of the power switch. The power supply is on whenever the power cord is plugged it. The power button instructs the GPU (on the signal board) to turn the LCD panel, backlights, and power LED on or off.
        PlainBill
        • blackrider1
          • May 2011
          • 28
          I know it is an strange behaviour. When I get no response of the power button, if I test the 6 pin of the 1203P60 and try the power button again, it works!!!
          For instance, when I´m unplugging the power cord and plugging it again, it is not working ( I mean the power button) but if I use the tester to checking vcc between negative pin of the filter cap and IC 6 pin, it works again, so I think the IC is bad, it can´t get the minimum vcc to start, but with the tester,somehow, it´s getting the neccesary charge to start, or a kind of resetting itself.
          What do you think? Can this behavioour be due to bad caps? Or definitively to a bad 1203P60 IC?
          Right now the button is working fine, is switches ON/OFF.
          Maybe be a deffective button? It sounds ok when pressing it (I mean the click sound) and all the solder points are OK.
          Or maybe due to a protection built desing of this IC?
          Although I think you´ll have its datasheet I´m uploadding it.
          • PlainBill
            • Feb 2009
            • 7034
            The real problem is you have incompatible results. If the power LED is orange, the power supply must be working. If the power supply is working, measuring the voltage on pin 6 should not have any effect on the power supply outputs.
            I am really interested in the voltages out of the supply, both when it is responding to the power button and when it isn't. And if I had it on my bench, the first thing I would do is a complete recap of the power supply.
            PlainBill
            • blackrider1
              • May 2011
              • 28
              Do you mean voltages at CN701?
              • PlainBill
                • Feb 2009
                • 7034
                Yes, the voltages at CN701, especially the voltages on pins 2&3 and pins 7&8. Pins 4-6 are Gnd.
                PlainBill
                • Behemot
                  • 4845
                  • CZ
                  Some guy asked me for help with this display. Before repair attempts, backlight ws not working at all.
                  After replacing all biger caps for Chemi-Cons LXZ, it works, but supposedly is blinking, or to be more precise, showing moving lines. Problem is reduced by setting frequency to 75 Hz, but still present. I am not really sure what could that be, any idea? Input cap should be fine acording to Atlas.
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
                  • maxim2511
                    LG 55EC930V OLED - swich on swich of no screen
                    by maxim2511
                    My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                    Then I get an idea to take it apart and clean boards from dust.
                    In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                    Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                    05-14-2021, 02:21 AM
                    Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                    by sam_sam_sam
                    I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                    This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                    After all of...
                    07-13-2024, 08:14 PM
