BenQ T201WA (4H.09C02.A01 power board) doesn´t turn on
  • blackrider1
    • May 2011
    • 28
    Hello,one day ago, when I turnned my pc off, the power led of this monitor stayed orange with no response on pressing the switch.
    I switched it on again and it was working fine, but when I pressed the power switch (of the LCD) instead of turning ON/OFF, it just showed me the bright control panel.
    I disconected the power from the wall, and now, it doesn´t turn on anymore.
    I checked fuse F601 (OK) Bridge rectifier BD601 (OK) and filter cap C605 (OK)
    When checking IC601 (NCP1203P60) I´m getting 10 vcc at pin 6. Is it a normal meassure? Should I get between 16 & 20 vcc?
    This board has these ELLITE crappy caps but all of them seems to be OK.
    I can´t find any schematics for this board although I know it is used in, at least, ASUS VW222S & FP222W BenQ.
    What do you advise me to test now? Remember that the power led doesn´t turn on.
    I can´t test CN701 because I don´t know the pinouts values.
    By the way, I resoldered everything to avoid cold solders.
  • PlainBill
    • Feb 2009
    • 7034
    Re: BenQ T201WA (4H.09C02.A01 power board) doesn´t turn on
    Excellent job of troubleshooting, and the labeled pictures are a big help. Getting really nit-picky, I prefer working with pictures where the board has been flipped left to right rather than top to bottom. The next biggest problem is a few spelling errors. If I were grading, you'd get a high 'A'.
    There are a few points you have missed. It IS possible to measure the voltages on CN701; it would be harder to establish what the voltages should be. Here's a summary, reading from left to right.
    Pin Function
    1 N/C
    2-3 V1 (probably 5 volts) out
    4-6 GND
    7-8 V2 (probably 12 volts) out
    9-12 Inverter and audio amp controls
    10 volts at pin 6 is indeterminate - it's below the startup threshold, but within the operating range. What you neglected to say is if the voltage is steady, or if it changes.
    As a PRELIMINARY diagnosis, IC601 is defective. It generates Vcc for startup internally, SMPS controllers that do this tend to have a high failure rate. Another possibility is the startup cap (C606 or C611). And it might be a short on one of the outputs.
    These are the points to check
    1 Voltage on IC601, pin 6. If it pulses, the IC is probably good.
    2.Voltages on CN701 pins 2-3 and 7-8. If they both pulse, the ouput diodes are probably good.
    3. With power off, check the resistance from V1 to Gnd and V2 to Gnd.
    PlainBill
    • blackrider1
      • May 2011
      • 28
      Thanks PlainBill.
      Well, voltage on pin 6 is, when off, always 10,23 v and no pulses. I say when off because now it´s working again!!!!!
      I reassambled everything, like in the picture and the power switch worked.
      I´ve been able to start it up.Then I´ve turned it off and it keeps on not working.
      I´ve tried to read again the voltage at pin 6 (10,23v) and when trying to switch it on again, it has worked again (weird!!).
      Now the LCD is on, with the green power led on, but not responses when pressing it. It doesn´t switch the LCD off. I´m getting 14,29 v at pin 6 right now.
      Everything works fine except switching ON/OFF.
      May be something related to minimum and maximus working vcc of the IC, that causes IC to be blocked?
      Now is on, so if you want me to check anything else while working, just tell me.
      By the way, resistance between V1/GND and V2/GND was decreassing from 13-14 to cero (I stopped testing at 4 or 3) in about 2 minutes, I mean, slowly.
      • PlainBill
        • Feb 2009
        • 7034
        Thanks PlainBill.
        Strange behavior; it almost sounds like a bad solder connection.
        One point; you misunderstand the function of the power switch. The power supply is on whenever the power cord is plugged it. The power button instructs the GPU (on the signal board) to turn the LCD panel, backlights, and power LED on or off.
        PlainBill
        • blackrider1
          • May 2011
          • 28
          I know it is an strange behaviour. When I get no response of the power button, if I test the 6 pin of the 1203P60 and try the power button again, it works!!!
          For instance, when I´m unplugging the power cord and plugging it again, it is not working ( I mean the power button) but if I use the tester to checking vcc between negative pin of the filter cap and IC 6 pin, it works again, so I think the IC is bad, it can´t get the minimum vcc to start, but with the tester,somehow, it´s getting the neccesary charge to start, or a kind of resetting itself.
          What do you think? Can this behavioour be due to bad caps? Or definitively to a bad 1203P60 IC?
          Right now the button is working fine, is switches ON/OFF.
          Maybe be a deffective button? It sounds ok when pressing it (I mean the click sound) and all the solder points are OK.
          Or maybe due to a protection built desing of this IC?
          Although I think you´ll have its datasheet I´m uploadding it.
          • PlainBill
            • Feb 2009
            • 7034
            The real problem is you have incompatible results. If the power LED is orange, the power supply must be working. If the power supply is working, measuring the voltage on pin 6 should not have any effect on the power supply outputs.
            I am really interested in the voltages out of the supply, both when it is responding to the power button and when it isn't. And if I had it on my bench, the first thing I would do is a complete recap of the power supply.
            PlainBill
            • blackrider1
              • May 2011
              • 28
              Do you mean voltages at CN701?
              • PlainBill
                • Feb 2009
                • 7034
                Yes, the voltages at CN701, especially the voltages on pins 2&3 and pins 7&8. Pins 4-6 are Gnd.
                PlainBill
                • Behemot
                  • 4845
                  • CZ
                  Some guy asked me for help with this display. Before repair attempts, backlight ws not working at all.
                  After replacing all biger caps for Chemi-Cons LXZ, it works, but supposedly is blinking, or to be more precise, showing moving lines. Problem is reduced by setting frequency to 75 Hz, but still present. I am not really sure what could that be, any idea? Input cap should be fine acording to Atlas.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • kotel studios
                    Corshair RM750 - doesn't allow for board to turn on
                    by kotel studios
                    While back I got this Corshair RM750 PSU from a friend which said it was broken. Plugged it into my bulb protection and turned it on. Was greeted with two 60w bulbs turning on (barely at max with PSU generating the voltages. I thought it was the APFC needing more current so I removed the bulb protection and plugged into my wall socket.
                    All the rails were fine, all generating the correct voltages when turned on.
                    Now, I have plugged in an known good board (intel i7 0th gen with iGPU, nothing else) and pressed the power button. Nothing happened besides the 5vsb LED onboard...
                    07-20-2025, 05:02 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • howardc64
                    by howardc64
                    Today, 05:17 PM
                  • brzostos
                    HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                    by brzostos
                    Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                    After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                    Original HP 150W power supply, the diode in the power socket lights...
                    10-01-2024, 01:34 AM
