Dell 1703 FPS Board # 79044120 Dead no life
    • Jul 2011
    • 6069
    This is a monitor that I bought at the Computer Recyclers Center where I live
    for $20.00 US
    • Jul 2011
    • 6069
    Re: Dell 1703 FPS Board # 79044120 Dead no life
    < Please and Thanks for any help that you can give me
    I have power the board with a 12 volt power supply and can get the evey thing to work but it will not power on with the power cord
    I had remove the yellow tranformer when using the 12 volt power supply
    I am real as what to do next
    Any idea what to check next I have replaced the mosfet and still no go
    The Cap near the yellow tranformer has a voltage about 160 volts DC
    • PlainBill
      • Feb 2009
      • 7034
      To repair monitors in a cost effective manner you must not arbitrarily replace components unless you have a good reason to believe they are defective.
      In case of a 'Dead' problem, the first step should be to measure the output voltage of the power supply. If this is 0 volts, the second step is to measure the voltage across the large cap. 'About 160 volts' is interesting for a number of reasons. It is approximately correct, if slightly low. Is it steady, or does it vary? Are you measuring with a DMM?
      If the output is 0 volts, but the voltage across the large cap is correct, the next step is to check the SMPS controller. What is the part number on U850? What is the voltage on Vcc?
      PlainBill
        • Jul 2011
        • 6069
        Here is the Data Sheet for U850 <
        Here is the Part # for U850 <..> SG5841SZ
        How do check U850
        I had check the Q850 which is a mofet on both boards with a meter and got two very different reading on each one so did not know which one was bad or either one was good and the cost of each one was about $2.00 each on Ebay
        I check to see if the gate on Q850 had any voltage which it did about 14 volts DC
          • Jul 2011
          • 6069
          "About 160 volts' is interesting for a number of reasons. It is approximately correct, if slightly low. Is it steady, or does it vary? Are you measuring with a DMM?"
          For most part it steady
          • PlainBill
            • Feb 2009
            • 7034
            Thanks for the link to the datasheet. That saves me a bit of trouble.
            Use pin 1 of U580 as ground. What are the voltages on pins 3 and 7?
            PlainBill
              • Jul 2011
              • 6069
              PlainBill
              I will give you those reading a little later on today
              If I have to replace this chip what is the best way to remove the old one and solder in the new one I have not solder ( 8-Pin Small Outline Package (SOP) type before
              • PlainBill
                • Feb 2009
                • 7034
                PlainBill
                ChipQuik makes removal easy. Clean up the residue using solder braid. Soldering is covered in this video.
                PlainBill
                • mariushm
                  • May 2011
                  • 3799
                  Here's another tutorial about soldering chips and smd stuff... maybe his style of explaining is easier for you : http://www.youtube.com/watch?v=b9FC9...ailpage#t=559s
                  I watched the three part tutorial he made and found it quite good. Basically use flux and quality solder wire...
                    • Jul 2011
                    • 6069
                    PlainBill
                    U850 .........>
                    Both pin 3 and 7 have a voltage between 12 and 14.5 volts DC trying to turn on the monitor make no difference
                    The measurement across the large cap is a steady 166.7 volts DC
                      • Jul 2011
                      • 6069
                      I made a mistake in this post it is not a E1703 it is a E1706 sorry about this
                      I have both model
                      • PlainBill
                        • Feb 2009
                        • 7034
                        PlainBill
                        U850 .........>
                        Not nearly good enough. Let me explain. I do not have the monitor here. I cannot see what readings you are getting. If you are unwilling or unable to give me specific information, you might as well go back to changing parts at random.
                        Pin 3 is the startup input. It is connected to the +166 volt supply by a large value resistor. Pin 7 is Vdd - the supply voltage for the IC There is a startup cap from pin 7 to ground. When the monitor is plugged into AC power the startup cap is charged until Vdd reaches 16 volts. At that point the SMPS controller starts, and provides it's own run power.
                        The voltage on each pin, and the characteristics are critical. If the voltage at pin 7 is jumping around it indicate one problem. If it is steady, it indicates another. If the voltage at pin 3 is too low, it indicates something else.
                        PlainBill
                          • Jul 2011
                          • 6069
                          "If the voltage at pin 7 is jumping around it indicate one problem." <... YES
                          " If it is steady, it indicates another." <...... NO
                          " If the voltage at pin 3 is too low, it indicates something else." <.... The voltage is the same between 12 and 14.5 volts What should this voltage be ??
                          " If you are unwilling or unable to give me specific information, < ... This is NOT the case these are the reading that I am getting
                          " you might as well go back to changing parts at random." <........ I really do not want this way
                          I am trying to give you the messurement that you are asking for
                          Please bear with me on this thanks
                            • Jul 2011
                            • 6069
                            " Pin 3 is the startup input"......> "There is a startup cap from pin 7 to ground. When the monitor is plugged into AC power the startup cap is charged until Vdd reaches 16 volts."
                            It never reaches 16 volts on either pin 3 or pin 7 so what do I need to need to check
                            I do have cap tester how ever I will need to remove the cap to test them
                            You need to let which ones I need to check
                            • PlainBill
                              • Feb 2009
                              • 7034
                              The key is the voltage jumping. It is likely that the startup cap is bad. Another possibility is that the SMPS controller is bad. A third possibility is that one of the outputs is shorted, but that is much less likely.
                              I'd suggest starting by checking the diodes on the output of the SMPS transformer. Since you got the monitor working using an external supply, we know there is no problem with a short on the load. Next, try replacing the startup cap with a known good one and seeing if that fixes the problem. If the output diodes were not shorted, and replacing the startup cap doesn't fix it, you have a bad smps controller. DigiKey doesn't carry them, but they are available on eBay.
                              PlainBill
                              • Rtech
                                • Jul 2010
                                • 1095
                                I have only seen this Board on the Dell FPf series of Monitor, and the SMPS controller is known to fail on a regular basis,so looks like you are on the right track.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Unfortunately for 3sam, the controller is not available from DigiKey. Fortunately he can buy 5 for $10 (including shipping) from eBay sellers in China.
                                  PlainBill
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    PlainBill
                                    Thats where I purchase mine from,and they are used quite regularly.
                                      • Jul 2011
                                      • 6069
                                      The key is the voltage jumping. It is likely that the start-up cap is bad. Another possibility is that the SMPS controller is bad.
                                      I'd suggest starting by checking the diodes on the output of the SMPS you have a bad smps controller. PlainBill
                                      I found the part at Mouser 512-SG5841JSZ .....> SG5841SZ
                                      I put it in today and it came back to LIFE the only problem now is to get a set of CLF tubes that are good to finish this repair
                                      I can only hope .....>
                                      ___________________________________________________________
                                      The reason I do not a good set of CLF tubes I have three monitors that have the same model # and one them the boards worked but one of the CLF was bad on the other monitor had one CLF that did not work but the other one did not and only one that both sets of CLF tube
                                      I did not care about this at the time, because I only had ONE board that work
                                      The Last Board has some real Problem with it one of the resistor that is real tiny rear the U850 is OPEN also there is a problem
                                      with U851 or with U801 or with U802 it work BUT I had to use two power supplys to get it to come on BUT I do not think I want to spend the time on this board I will just CUT the invert board part off of it and use it to check CLF tube with it
                                      PlainBill
                                      I WANT to THANK YOU for all of your help in this matter and helping get this monitor working again I wish I could send you a
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • AdrenalinTL
                                        Dead Dell Board
                                        by AdrenalinTL
                                        Hi Guys,
                                        Back again with more learning to do. I would like to start fresh and not confuse myself by looking through different posts.
                                        I have a Cedar Intel Board that is dead. 13269-1 - Seen a few dead boards here on here.
                                        So pls bear with me and let me know if what I am doing is half right as a starting point.
                                        Pin 1 through to Pin 3 measures 19.68V
                                        Pin 4 measures 0.17V
                                        Pins 5-7 measure 0
                                        This below component as well as the area around it worry me though. Almost looks like it was removed and replaced skew?...
                                        06-25-2024, 02:59 AM
                                      • master3112
                                        Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                        by master3112
                                        I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                        Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                        The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                        07-29-2025, 01:55 PM
                                      • k370
                                        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                        by k370
                                        Hi everyone,
                                        I have a NM-A321 board that is dead, with no power at all.
                                        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                        • +3VALW
                                        • +5VAUX
                                        • 1.2VSUS_PWRGD
                                        • 3VALW_PGD
                                        • 1.05VAUX_PWRGD
                                        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                        09-23-2024, 11:57 AM
                                      • Garret Matt.
                                        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                                        by Garret Matt.
                                        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                                        Thank you in advance for any assistance you can render.
                                        Inductor In question. Buzzes like...
                                        06-20-2025, 01:21 PM
