eMachine 19" HDMonitor LE1987
  • adamnp
    • Aug 2010
    • 6
    Hello, I'm trying to repair a monitor for a friend and I'm hoping someone here can point me in the right direction. Here are the symptoms: The backlight will only stay on for 4-5 minutes before going out. Once the lamps turn off, I can get them to turn back on if I power cycle the monitor - but the lamps wont stay on as long as they did from a cold start. Normally just a few seconds after first failure. Also, before the lamps go out the screen will start to flicker. So far I have replaced all the capacitors on the inverter board except two: the 450v 100uF, and a 35v 150uF Lelon. None of the caps were blown or looked even slightly bloated before I replaced them.
    I don't know much about electronics, but it seems to me like something is overheating (mosfets?). However, I see no discoloration on the board. The model number is: ILPI-021 - I will post pictures later this evening.
    Thank you for your help.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: eMachine 19" HDMonitor LE1987
    If you turn down the brightness and contrast to 25/25, does it stay on longer than 5 minutes?
    --- begin sig file ---
    --- end sig file ---
    • adamnp
      • Aug 2010
      • 6
      Hi, I'm sorry it took so long for me to respond. I did what you suggested and turned the brightness and contrast down to 25 but it didn't seem to make much of a difference in the length of time the monitor stayed on. However, I went a step further and turned both down to zero and so far (after a couple hours) it has yet to turn itself off. I also discovered its an LED lit monitor and not a CCFL light I had assumed. I hope this information helps, and thanks again for your assistance.
      • jetadm123
        • 2169
        At this point, you'll need to post some good photos of the entire top and bottom of your board.
        • retiredcaps
          • Apr 2010
          • 9271
          LED. We will definitely need pics. Please use the manage attachment function for your pics (see my sig file).
          • adamnp
            • Aug 2010
            • 6
            I hope these pictures are to your liking. Let me know if you need close-ups of a component.
            Thank you.
            • alexanna
              • Mar 2010
              • 1346
              Are you sure you have a LED monitor, the connectors look the same as a LCD type.
              The only reason I ask is there is another LED monitor being worked on in the forum, I can't tell for sure but it looks like that monitor is using a ribbon cable for the Lamps.
              I haven't had the opportunity to look inside a LED monitor so I am just wondering
              • jetadm123
                • 2169
                I agree with alexanna. It looks like a ccfl power board complete with the inverter transformers and 4 ccfl outputs.
                Also looks like you used general purpose caps instead of low-esr caps.
                Could be a bad solder joint. Try checking for a thermal problem by taking a hair dryer and heating up parts of the board to see if you can accelerate the shutdown process. Hopefully, you can isolate an area and we can go from there.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Looks like a ccfl setup as jetadm123 and alexanna mentioned.
                  We have only seen 1 LED power/inverter board here.
                  • adamnp
                    • Aug 2010
                    • 6
                    Oh, okay. The only reason I thought it was an LED backlit monitor was due to an "LED Mode: Day/Night" setting in the monitor config screen. I couldn't find much, if any, information about this monitor online.
                    Pardon my ignorance, but is this a potentially bad thing? Should I always use low-esr caps for inverter boards?
                    I think what I'll do is leave the brightness and contrast at zero (where it has yet to shut itself off) and heat up a section of the board at a time, while being very careful not to melt it. Thanks!
                    • alexanna
                      • Mar 2010
                      • 1346
                      If this indeed a CCFL monitor, and you do not have any spare good CCFLs to substitute.
                      You could try this; Make sure the metal framework of the panel has a good ground just in case to prevent a shock.
                      Have the brightness turned all the way up and within that first five minutes, gently tap the frame work on the ends where the CCFL wires attach to the bulbs. See if you can recreate or accelerate the flickering or the lamps turning off.
                      EDIT
                      I should have said tap on all four corners of the LCD
                      • adamnp
                        • Aug 2010
                        • 6
                        EDIT
                        I have confirmed that it is indeed a CCFL monitor. I'll give your suggestion a try this weekend and report back. Thank you!
                          by momaka
                          03-15-2023, 10:17 PM
                        • wattage
                          AOC AG493UCX 49-inch monitor - Firmware request
                          by wattage
                          Hello Badcaps Community,
                          I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                          07-13-2025, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
