Dell SP2008WFPt no picture
  • kynax
    • Sep 2010
    • 33
    I have a used Dell SP2008WFPt 20 inches monitor with USB hub and webcam that doesn't work anymore.
    When I plug it in, the power button light blinks blue, but pressing it doesn't do anything.
    I disassembled it and took pictures of the two boards. I tested the power supply board (yellow-ish one) with my multimeter and the +5V points do indeed output 5 volts when the power cable is plugged in.
    On the other board, I haven't tested the points because I don't know what any of it does. I did look at all the capacitors and they all seem fine to me.
    Tools I have access to: soldering iron, digital multimeter
    I've attached a few pictures. If they are unclear or if close shots of particular areas are required, I can add some more. I do have access to a flatbed scanner, but since there are some fairly high components, I don't think the picture would be any good.
    I uploaded the full resolution pictures on imgur: http://imgur.com/a/CUTze
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell SP2008WFPt no picture
    If you hookup a working computer with your favourite wall paper, do you see it by shining a flashlight on the lcd?
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      There are voltage regulators on the logic board. I have circled them in yellow.
      Use a ground screw on the logic board for the black probe. Put your multimeter on 20V DC (if manual).
      1) What are the part numbers of each regulator?
      2) What is the DC voltage of each pin?
      • jetadm123
        • 2169
        Is there a legend silk screened next to the wiring harness on the power board identifying voltages, ena, on/off, etc?
        • kynax
          • Sep 2010
          • 33
          Yes, you can see it in the 6th picture. If you check the imgur files, the resolution is high enough to see it.
          The picture is upside-down, but the order is:
          OFF | BRI | ON-OFF | A-EN | A-DET | GND (4) | +5V- RTN | 5V (4)
          I already checked that the 4 5V pins do have 5V compared to the 4 GND pins.
          • kynax
            • Sep 2010
            • 33
            No, nothing at all.
            • kynax
              • Sep 2010
              • 33
              Here are the readings I get:
              • retiredcaps
                • Apr 2010
                • 9271
                Those readings look good.
                I missed one voltage regulator. Report and measure I317 (just above chip labeled 3B72).
                For the future, one good clear focused picture top down view of each board is sufficient. Having the logic board chopped up in 4 quadrants is difficult to view.
                • jetadm123
                  • 2169
                  Many members here avoid (myself included) photos posted on external sites for fear of catching a virus on their computer.
                  Can you please measure the voltages of BRI,ON-OFF,A-EN and A-DET?
                  Also, it looks like you missed a voltage reg (circled in yellow). Measure and report the voltages and part number. There seems to be a number of fuses (circled in red). Check them for continuity. Check around the board for additional fuses. They are generally marked FXXX (XXX=number).
                  • kynax
                    • Sep 2010
                    • 33
                    I don't get anything on any of the pins.
                    It's a 17-33L like the other one.
                    One thing I did notice with the VGA cable plugged into my laptop is that Windows does recognize the monitor:
                    • kynax
                      • Sep 2010
                      • 33
                      BRI: oscillates between 0 and 2.7V every 0.5 seconds
                      ON-OFF: 0.12V
                      A-EN: 0.12V
                      A-DET: 0V
                      • jetadm123
                        • 2169
                        ON-OFF: 0.12V
                        A-EN: 0.12V
                        A-DET: 0V
                        What about the fuses I asked you to check?
                        • kynax
                          • Sep 2010
                          • 33
                          I tested all I could find (over 15) and they all worked fine (continuity).
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Assuming the fuses around that component are all working, then this voltage regulator is bad. You should get some DC voltage readings on the pins.
                            • jetadm123
                              • 2169
                              You should have at least 5V on one of the pins. I would have suspected a bad fuse.
                              • kynax
                                • Sep 2010
                                • 33
                                Is this a component that fails fairly often? As in, is there a good chance that this is the problem?
                                I'm pretty sure I can buy a replacement locally and change it.
                                • jetadm123
                                  • 2169
                                  Regardless of whether it's bad or not, you should still measure the 5V input.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Voltage regulators do fail. How often? I don't know.
                                    You can look for replacements on junk boards and reuse the old ones.
                                    PS. You should retest it one more time.
                                    • kynax
                                      • Sep 2010
                                      • 33
                                      Indeed, I misread your previous post.
                                      Which one is the input pin?
                                      • kynax
                                        • Sep 2010
                                        • 33
                                        That's also what I though.
                                        I still get 0V on all pins.
                                        I compared with the other regulator and that one is still working.
                                        EDIT: Is is possible that this regulator is there for the USB hub, in which nothing is plugged right now, explaining the lack of voltage in there?
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
                                        • timeless
                                          Dell U2518 no picture
                                          by timeless
                                          I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
                                          There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
                                          04-14-2024, 08:30 AM
                                        • YellowJacket
                                          Dell P2416DB - no picture
                                          by YellowJacket
                                          Hi friends,
                                          I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
                                          01-16-2024, 07:45 AM
