What's the rule for Poly mods? (Half the capacitance?)
  • TheLaw
    • Jan 2011
    • 477
    So my onboard LAN died, so I had to get a new LAN card. It's a decent card. I even outfitted a VGA RAM heatsink on the main chip. The problem I have most with it are these crappy little lytics it has. Capacitor selection has become an obsessive disease lately. Something that I might have considered in the past is now becoming inferior with my new knowledge of capacitors.
    Anyway, just for the hell of it, I want to replace these caps.
    I can't find that thread I think either PCBONEZ or someone else made that had a lot of info on that. Maybe someone could direct me?
    Otherwise, what is the rule for replacing electrolytics with polymers? Half the capacitance?
    The card was only $10, so if it doesn't work, It's not that much off an offset.
    Thanks.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Re: What's the rule for Poly mods? (Half the capacitance?)
    Half capacitance of the lytic is a good rule of thumb, but sometimes its just trial and error.
    I just got done polymodding some GX745's, good trial, no error.....and they should last damn near forever!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • TheLaw
      • Jan 2011
      • 477
      Thanks Topcat!
      By trial and error, you mean: It might actually be closer to the lytic capacitance than you think?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        When I say trial and error, I mean using what you have on hand, as long as you aren't over-volting them. Then seeing how it works, measuring ripple, and the best test of all, seeing how stable the system is afterward.
        Team : 49813
        Join in!!
        Team Stats
        • TheLaw
          • Jan 2011
          • 477
          Oh...Well, maybe I'll just get some Nichicon HZs or something. Should last just as long. Maybe not theoretically, but for its own lifetime.
          How do you measure ripple? O-Scope?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            It's not that easy.
            The 1/2 the uF as a thumb-rule only applies to VRM's and it's based on a tech doc discussing VRM's.
            IIRC it was an application guide for a VRM controller IC chip. Kc8 posted it here a few years ago.
            In essence, he was doing poly mods and I asked him how he knew how much uF to use.
            He answered saying 1/2 the uF and posted that PDF file as the proof.
            The '1/2 the uF thumb-rule' is also based on lowing the ESR more than a little bit.
            There are now some lytics that have lower ESR than some polys.
            That is due to lower grade polys coming into the market since the rule was 'invented' when I asked kc8 for one.
            Any ole poly won't do.
            You STILL have to check specs on new and old just as you do with lytics.
            IOW: The rule -assumes- you are working on a VRM.
            It does not blanketly apply to any application because in some the uF might be critical to the circuit's operation.
            If it's not in a VRM you either:
            - trace the circuit, look up the chips coils and caps, and then do the math.
            - cross your fingers and jump in a blind leap of faith.
            Mann-Made Global Warming.
            - Dr Seuss
            • TheLaw
              • Jan 2011
              • 477
              Originally posted by PCBONEZ
              It's not that easy.
              Thanks for the explanation but I think I'll just use some high quality lytics.
              • c_hegge
                • Sep 2009
                • 5219
                https://www.badcaps.net/forum/showthread.php?t=9466
                I gave two GA-7VA motherboards a FULL poly-mod (replaced EVERY single cap with polys). I used half the capacitance for the VRM caps, but for the others, I reduced it slightly, but not down to half. Where there were originally 1000uF caps, I used 820uF polys.
                • TheLaw
                  • Jan 2011
                  • 477
                  Hmmm...I am intriguing.
                  However, even a bunch of OSTs would be an improvement over whatever rubbish is on this card right now.
                  But VERY nice job on the full poly mod.
                  AH! So confusing. Maybe I'll buy a trial card. (It was like $10 on Newegg) I'll try some polys on those.
                  If I don't burn the card into oblivion when soldering it 6000 times, I might try it for real on the good card.
                  • TheLaw
                    • Jan 2011
                    • 477
                    Shucks...I have a Weller WLC100 station and the stock iron it came with (that I am using), doesn't have a grounded tip. According to the badcaps FAQs, I need. One.
                    Anyway to ground it?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      That's fine.
                      Concern over static on the tip when you are working on caps is rather silly.
                      Caps charge and discharge by design. Static won't hurt them.
                      - Dr Seuss
                      • TheLaw
                        • Jan 2011
                        • 477
                        Ah...Good. Though that Weller isn't considered to be one of their professional units, it still wasn't all that cheap...and to see my investment not be able to do something would make me sad.
                        I'm just curious why that is written up on this website under the Recapping tutorials...Hmm...
                        So let's try to find some decent caps and give it a whirl!
                        Thanks.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          For the same reason you shouldn't use a cell phone in a gas station.
                          We wouldn't want that little Ultra High Frequency "UHF" transmitter [that you hold right against your head] to set the gas on fire, now would we?
                          - Dr Seuss
                          • TheLaw
                            • Jan 2011
                            • 477
                            Liability?
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Well meaning yet clueless 'rule makers'.
                              I the entire existence of mankind there has not been a single instance of a cell phone transmission causing a fire.
                              [Walkie-Talkies either for than matter.]
                              - Know why?
                              .. It's not physically possible for that little bitty x-mitter to put out enough energy to get anything hot or make a spark.
                              - But damned it! - We have a law just in case!
                              - Dr Seuss
                              • TheLaw
                                • Jan 2011
                                • 477
                                I understand.
                                I need a 10uF cap and 4 22uF caps.
                                They are all rated for 25V currently, though my multimeter shows that <5V are running through them at any given time. But I suppose, what's the difference...
                                So for replacements. For the 10uF, I'm looking at a 50V Nichicon PM and for the 22uFs, I'm looking at some 50V Panasonic FRs.
                                Are Nichicon PMs any good for motherboard/PCI card use?
                                The name of the capacitor company on the card is TWBOR. Not sure if you've heard of them. http://www.twbor.com/Enproduct.asp
                                In regards to ESR, the bigger the capacitor, the less the ESR?
                                • yyonline
                                  • Jul 2009
                                  • 692
                                  Nichicon PM are low ESR, but not very low ESR. In other words, they're on the high ESR end of the low ESR range. They may be usable for specific applications, but I wouldn't say they're the best choice in general for motherboard use. See the next point below...
                                  What series is the existing capacitor? With that info, we can look up the specs of the original capacitor to see if your proposed replacement is good enough. You want the same or lower ESR, the same or more ripple. I usually try to keep it with reason...going from a general purpose cap to a low ESR cap with many many times the ripple handling ability and a fraction of the original ESR may cause issues in certain circuits. Generally, I assume the existing capacitors are good enough as far as ratings go. I try to find a replacement with better real-world reliability, which is different than the lifetime spec.
                                  I'm assuming you mean bigger as in larger physical size, as opposed to a larger capacitance rating. Within the same series (and more strictly the same voltage rating, but we'll ignore that for now), this is true. Taking Nichicon PM, since you mentioned that earlier... a large Nichicon PM will have less ESR and more ripple handling ability than a small Nichicon PM.
                                  Comparing size to ESR relations across different series does not work. A large Nichicon PM may have more ESR than a smaller Rubycon MCZ or other ultra low ESR capacitor. (Disclaimer: I did not actually compare the specs, it's just a hypothetical example.)
                                  • TheLaw
                                    • Jan 2011
                                    • 477
                                    Thanks for the response.
                                    There are no markings on the TWBOR capacitors other than capacitance, voltage, and 105C. They are black and grey...Sorry.
                                    Alright, I'll try to see if I can find some capacitor other than the PMs. I can't find any 10uF Panny FRs but I did find a 10uF Panny FC. How about one of thise?
                                    And thanks for clearing up the general theory of ESR/physical size. And yes, I meant physical size.
                                    • yyonline
                                      • Jul 2009
                                      • 692
                                      FC is slightly better than Nichicon PM, but not much. It might be a perfectly good replacement, but without knowing what the originals were, I can't say for sure. FR would likely be an excellent replacement, as it has excellent specs. If you can't find them...what is your location? We may be able to suggest somewhere you can purchase appropriate replacements online.
                                      • TheLaw
                                        • Jan 2011
                                        • 477
                                        New Jersey, USA.
                                        Maybe I'll try to see if I can find some Rubys or continue my search on Mouser. I'm no pro with capacitors yet, though I do have a bit of an understanding.
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
                                        • Raulnn
                                          TD Systems K50DLG12US half black and half white screen
                                          by Raulnn
                                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                          01-20-2024, 04:49 PM
                                        • CapLeaker
                                          Poly VVX-250 VOIP POE problem not booting fix
                                          by CapLeaker
                                          I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                          Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                          11-25-2023, 10:46 AM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
