Aixun T3A overshooting?
  • tony359
    • Oct 2018
    • 264
    • United Kingdom
    I've just purchased an Aixun T3A T245 soldering station and I am pretty happy with it, coming from a Hakko knockoff.
    However, I purchased a genuine JBC tip and the temp massively overshoots with it. I can see a similar behaviour with the Aixun tips but not so horrible.
    With the JBC tip on the thermometer I see the temp more or less stable but slowly dropping. At some point there is a 100% power spike and the registered temp goes +40C from where it was - obviously the display doesn't show anything!
    Is this "expected"? 40C seems quite a lot.
    See a video of what's happening here: https://youtu.be/z6oj99W5PH0
    I am just holding the tip on the thermometer, no wet sponges or anything.
    • 31269
    Re: Aixun T3A overshooting?
    maybe software - is it the lastest version?
    https://aixun-updates.github.io/
    • tony359
      • Oct 2018
      • 264
      • United Kingdom
      it is, you can see 1.34 on the display.
      It does look like a software issue to me. I've reported it to Aixun, also mentioning I am reviewing it, it might get some traction
      The funny thing is that a couple of versions before it said "fixed overshoot on 245"
      Maybe I should try downgrading!
      • tony359
        • Oct 2018
        • 264
        • United Kingdom
        Aixun replied to my enquiry saying it's intentional (of course!).
        It might make sense though: they say it's designed to give the tip a little boost when the solder is being melt, to prevent the tip from dropping the temperature too much.
        I admit that when measuring on a thermometer there is no mass, hence the test is kind of "unfair". On a proper solder joint I'd imagine the overshoot is not as bad.
        Still, with the smaller knife tip that does not happen so... uhm...
          • 31269
          to be fair then, it's probably the tip mass causing a delay between the sensor and heating element thats hard to predict in software.
          • tony359
            • Oct 2018
            • 264
            • United Kingdom
            well... you can see the temperature is creeping down for no apparent reason. I see what you mean and I don't disagree but I feel there is some improvement possible in keeping a more stable temperature when the tip is not doing anything.
            The software should push a tiny little more power in the tip to avoid the temp going below the threshold which likely triggers the "temp has lowered, they must be soldering, let's pump 200W to the tip to compensate".
            Does the station know what type of tip is being connected? I remember watching some reviews (not sure about what station) where it was being mentioned that the reason why the full 100% power was not being sent to a specific tip was because it was too small to take that amount of power.
            Indeed a "high thermal efficiency" tip would require more power than a very small, tiny precision soldering one.
              • 31269
              no, it doesnt know what cartridge it is.
              in theory if you had a menu to tell it the cartridge model it could compensate by having a lookup table.
              one of the cheaper units - maybe quicko or ksger has a tip menu that lets you set different offsets for the temp, so it's possible
              there is a very expensive station that does have an eeprom in the cartridge but thats going to be stupid money.
              i think it may be hakko or weller but not sure - it's not been cloned anyway.
              • tony359
                • Oct 2018
                • 264
                • United Kingdom
                ah gotcha. Then I guess it's kind of understandable even though I still don't understand why the unit is letting the tip cool down to a point where it deserves a 170W boost
                The tip does not cool down instantly so in theory the algorithm has plenty of time to realise it needs to push the power a tad more. Uhm...
                Someone on my video recommended to downgrade to 1.33
                • tony359
                  • Oct 2018
                  • 264
                  • United Kingdom
                  Turned out the issue was already mentioned on EEVBlog forum and indeed downgrading to 1.33 fixed it.
                  Too bad for Axiun who replied with Marketing BS to my query. But hey...
                    • 31269
                    in regard to your comment about 170w boost,
                    soldering stations use PWM driven mosfets.
                    it's either 170w or nothing - it's the duration that counts
                    there is a project to reverse engineer the T3A, they have extracted the firmware and i think created a schematic.
                    maybe they will eventually customise the firmware
                    https://github.com/c0d3z3r0/aixun_t3a_rev
                    • tony359
                      • Oct 2018
                      • 264
                      • United Kingdom
                      Yes, of course it depends on the duty cycle. There is a power indication on the display, it goes up to 87% which of course it doesn't mean it's delivering constant 170W but the duty cycle is adjusted so it's 87% of the max power... you know what I mean
                      ahah, we reverse engineered the reverse engineered one
                      One thing I might have noticed with 1.33 is that the station is noisier? It's buzzing louder.
                        • 31269
                        i didnt know it buzzed?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8349
                          No buzzing in mine.
                          • tony359
                            • Oct 2018
                            • 264
                            • United Kingdom
                            I read online that the new version buzzes more than the old one. Mine says "HW version 1" (or maybe 0?) so not sure. Interesting
                            However I have a much bigger problem.
                            I've used the T3A to do some soldering tonight and noticed the display would say "NO TOOL" every now and then. I thought it was my JBC tip so I swapped it for an Axiun. Same issue.
                            Then I realised it was not the tip. EVERY time I was touching some specific pins on the motherboard I was working on, the station does what you see on the video.
                            The MoBo is disconnected, been off for days, no battery.
                            How is that even possible please and, most importantly, what do I do now?
                            I am incredibly confused.
                            https://www.youtube.com/watch?v=o5JEp6sO9Jc
                            This is what the display says when it "flashes"
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8349
                              Mine doesn’t do that. I even soldered big stuff with that iron that shouldn’t be done with one. I am not even sure what firmware or hardware mine is running, but it is about 10 months old now.
                              Looking at your video, it looks like it’s going crazy as soon the main unit ramps power up close to full tilt, losing juice. Weird. If you just got it and depending where you bought it, warranty it?
                              • tony359
                                • Oct 2018
                                • 264
                                • United Kingdom
                                I don’t think it’s got to do with power, I’m barely touching some specific joints. I’ve done the ‘coin’ test with lots of solder and I can dip the tip in a wet sponge and it doesn’t happen.
                                Yes it’s brand new so o guess I’ll ask for a replacement, wish me luck.
                                Still, I can’t think of what could be sensing that is triggering that behaviour.
                                • tony359
                                  • Oct 2018
                                  • 264
                                  • United Kingdom
                                  I have an update. It's ground.
                                  When the PCB I am soldering is grounded, SOME solder joints will cause havoc.
                                  AND, the handle is buzzing.
                                  https://www.youtube.com/watch?v=8OXDOZTy7t0
                                    • 31269
                                    contact Aixun - it's gotta be a psu issue
                                    my guess is the ceramic capacitor between the primary & seconday is missing or the unit is missing a ground connection between the mains earth input and the handle somewhere.
                                    can you use your meter to check resistance between the iron tip and the earth pin on the back of the unit - earth on the iec connector i mean.
                                    while your at it - check your power cable and your house socket
                                    i'v had a few recent "incidents" with power cords with molded plugs on them!!!!
                                    if you buy anything high wattage with a molded plug - check the plug isnt getting hot while it's running - specially fan heaters from Lidl!!
                                    • tony359
                                      • Oct 2018
                                      • 264
                                      • United Kingdom
                                      Shall do, I did check that the unit was earthed, I believe everything reads full continuity but the tip which is reading some resistance but not much? I'll double check.
                                      Bear in mind that when I touch ground directly with the tip, it does not happen. It only happens when touching SOME solder joints on an earthed PCB.
                                      I'm not sure about the PSU to be honest. The display would show "undervolt" or something like that, like it does for a brief moment when you power it off.
                                      Someone on EEVBlog says this is normal - I can't accept a soldering iron which cannot be used on grounded equipment, would you agree?
                                        • 31269
                                        it makes no sense.
                                        the tip resistance to mains earth should be almost zero
                                        *unless* it's floating for safety - but i dont think they did that.
                                        weller in the past used to connect the tip to mains earth through a parallel resistor and capacitor to limit current incase you accidentally worked on something live.
                                        i modded my t12 the same way - sometimes i can get leds to glow while soldering them now!
                                        • CapLeaker
                                          Anyone tried or got the Aixun T3A with the T245 pen?
                                          by CapLeaker
                                          On the recent sale I've ordered a new Aixun T3A with the T245 soldering pen and it comes with the fancy pen holder. Wonder if anyone has one and if your happy with it? It's got some decent reviews. On YouTube a guy compared it with the JBC and results were pretty darn good fur such a cheap rig.
                                          12-04-2022, 02:12 PM
                                        • tmcw
                                          Drying Oven - Preset Temp Fail
                                          by tmcw
                                          Here's an unusual one...
                                          This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
                                          It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
                                          However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
                                          01-21-2021, 03:11 AM
                                        • foshland
                                          MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
                                          by foshland
                                          Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
                                          Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
                                          External temperature (motherboard temp) is working OK, 27ºC more or less
                                          In windows, all the software I have tested shows correct the Core temps
                                          12-16-2023, 09:08 PM
                                        • mosfetratus
                                          concerning gtx675m vram temp
                                          by mosfetratus
                                          Is 98C vram temp are safe? Less demanding games goes 80ish.
                                          Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
                                          furmark goes about 104C, amperage keeps rising so do temps.
                                          01-30-2025, 08:41 AM
                                        • Sudoer
                                          DIYPHONE Store and AIXUN T420D
                                          by Sudoer
                                          I've seen enough reviews of AIXUN T420D on YouTube and decided to try it. One handle defective from the inside, ruined 3 JBC tips, just destroyed the plastic on the tips. One stand does not work, the soldering handle not drop the temperature. Because the seller refused to return the money, and AliExpress supported him and even PayPal did not help, I can disassemble this piece of shit and see what inside, if anyone is interested. The seller said that the station does not work with JBC handles, but I checked that it works. It's just a pity to connect the original handle to this shit. Beware of order...
                                          05-04-2023, 04:55 AM
