I've taken the unit apart and can clearly see at least 4 caps are bulging. I have not replaced those yet because I am curious about an observation I made.
When the ribbon cable to the LCD is plugged in the power light blinks and there is a chirping sound that repeats at each blink (sound like a friendly version of a movie laser blast almost). With the ribbon cable unplugged the power board will turn on solidly. Should I start by replacing the bulging caps or is the chirp problem likely something else?
I'm not sure what voltages, etc to check but I've read the notes from the other E177FPf thread: https://www.badcaps.net/forum/showth...hlight=e177fpf
I'm showing solid voltages across U850 and U802 the amount of which of course depends on which pins are checked.
*If you reference the picture the bulging caps are C864, C869 (470uf 25v), C862 (1000uf, 25v), C1 (220uf, 25v). 864, 869, & 862 are the three barrel caps straight up from the big blue 450v cap. The other is on the left side.
