Philps QLED Q60B Model:QE65Q60BAU
  • bohaboha
    • Nov 2012
    • 1009
    • sweden
    hi all what do you guys think about these symptoms ? so soon as i plug the cord it shows the logon nonstop like in a loop .tries to turn it off with the remote but it does not respond i have to remove the cord to turn it off. a big heavy new TV for which I seek advice from you before I open it.found in the environment cabin in original package with remote control and electric cord maybe transport damage it looks to be unused.
    the screen looks to be ok or what do you guys think?
    Any advice or suggestions are greatly appreciated.
    Can i upload a video here?
  • Diah
    • Feb 2013
    • 6392
    Re: Philps QLED Q60B Model:QE65Q60BAU
    yours photo its look there are issue at LED BL so some of logo dim
    post stable focused video on the front screen at start up
    • bohaboha
      • Nov 2012
      • 1009
      • sweden
      Hi is it possible to post a video here? hope these are better and you can see that it shines brightly behind
      • Diah
        • Feb 2013
        • 6392
        post it as zip but small zise
        • bohaboha
          • Nov 2012
          • 1009
          • sweden
          Hi again Diah don't know how to do it if you want to help it would be perfect
          • lotas
            • Jan 2016
            • 4636
            • Russia
            Model: QE65Q60BAU is a model from Samsung, Philips should have a different designation.
            • bohaboha
              • Nov 2012
              • 1009
              • sweden
              These are the signs that are on the package and on the back of the TV
              • Diah
                • Feb 2013
                • 6392
                yours TV from 2016... find friend to help you to take out the screen apart you have BL issue.
                • lotas
                  • Jan 2016
                  • 4636
                  • Russia
                  The box is not native, it is from Samsung TV. Your model in the photo.
                  • bohaboha
                    • Nov 2012
                    • 1009
                    • sweden
                    Hi Lotas you are very observant and you are right now I see that it is a completely different designation :65PUS6521/12
                    can i change the title so that it is correct for the others . it is a free found television if it is Samsung or Philips most important is to find the problem to enjoy it if possible. want to download a Video to show the behavior on this tv and maybe get some help from you guys to fix the error
                    it's pretty big and heavy to handle but you might give me some clue as to what might be wrong with it
                    • lotas
                      • Jan 2016
                      • 4636
                      • Russia
                      Yes, download the video to see the exact problem.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4352
                        • Italy - Milan
                        Post the correct model code for other one's reference, please, not photo... You probably have bad backlight togheter with bad mainboard, hard battle!
                        • bohaboha
                          • Nov 2012
                          • 1009
                          • sweden
                          Re: Philps QLED Q60B Model: 65PUS6521/12
                          the correct model code is here:65PUS6521/12 but i do not know how to edith in the title
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4352
                            • Italy - Milan
                            no problem, the model can be found on searches, if you are not familiar with software reprogramming you could try an update via usb, few chances, or mb replacement
                            • bohaboha
                              • Nov 2012
                              • 1009
                              • sweden
                              Now I know what happened : those who threw this TV have just bought a SAMSUNG and wanted someone to take care of their old TV because it was really well packed plus the sets look pretty nice I have to thank them. Now back to our problems here are some pictures. Davi.p you think an update might fix the problem? otherwise, Mboard is to be changed. Now it is open and we can invistigate to confirm
                              what would you suggest?
                              • lotas
                                • Jan 2016
                                • 4636
                                • Russia
                                You first need a service firmware for this chassis for recovery, if it doesn’t help, then you will have to look for a working motherboard, since you are unlikely to be able to do anything with an eMMC dump.
                                • bohaboha
                                  • Nov 2012
                                  • 1009
                                  • sweden
                                  Thanks for the reply how to do it if you can explain ?
                                  • nomoresonys
                                    • 12206
                                    • U.S.
                                    funky looking tv, that back center speaker is crazy
                                    • lotas
                                      • Jan 2016
                                      • 4636
                                      • Russia
                                      Find this firmware "QM163E_0.16.56.0_upgrade_loader" under usb. (Its size will be 1.12GB.)
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4352
                                        • Italy - Milan
                                        If you want to test immediately the panel state then jump a 12v to the tcon fuse and disconnect the mb-tcon lvds cables, then turn on
                                          Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-07-2024, 12:10 AM
                                        • cstout
                                          DeLonghi AC Remote only accepts 3V
                                          by cstout
                                          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                          I can't find any schematics...
                                          06-03-2024, 03:53 PM
                                        • Mc_Millian
                                          Toshiba 50lf711u20 fire tv remote not pairing
                                          by Mc_Millian
                                          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                          The Tv model number is: 50lf711u20 Rev B.
                                          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                          I've tried 3 different remotes which should be fully compatible with this TV.
                                          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                          The power button, along with the volume,back,select, and directional...
                                          04-07-2022, 12:15 PM
                                        • edugimeno
                                          HiSense 55A7500F won't obbey to remote after power on
                                          by edugimeno
                                          Hi! I have this TV set that does the following:
                                          1) I press the red power button on the remote
                                          2) The TV turns on normally
                                          3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                          4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                          Then after it's off, it would again accept the TURN ON from the remote and same again
                                          BUT:
                                          -The remote does show the correct IR beam while observed thru a phone camera
                                          -The TV works fine while using the MiRemote...
                                          03-14-2023, 11:22 AM
                                        • tmhobadcap
                                          Pioneer VSX-522-K remote control not working???
                                          by tmhobadcap
                                          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                          12-24-2020, 01:44 AM
