HP Zbook 15 G2 laptop won't turn off completely
  • RODAKSAN
    • Jun 2022
    • 17
    • Mexico
    Hi everyone, I have a HP Zbook 15 G2 with some issue, it won't turn off completely. Once you turn it off by OS or Manually, the screen goes off, but the fan goes crazy at full RPM and it don't stop until the battery is drained. It is not a OS issue, the laptop does not turn off with or without OS. May be a thermal issue?
    Motherboard:LA-B381P with latest BIOS version, OS works normally, no faulty devices found on HP diags.
    It has new thermal compound and clean fans.
    Found no burned components on visual inspection.
    Holding the power button does not work, it keeps blowing air.
    Please help, I already have the schematics and the tools to do a rework.
    Best regards
  • mon2
    • Dec 2019
    • 14628
    Re: HP Zbook 15 G2 laptop won't turn off completely
    Power down and remove the wifi module and test again.
    • RODAKSAN
      • Jun 2022
      • 17
      • Mexico
      Thank you mon2 ,
      I removed the wifi module, same issue; once you plugged in the Battery charger, it starts to blow air, if you turn it on, the fan works normally until you turn off the book and then goes crazy again
      • mon2
        • Dec 2019
        • 14628
        Do you get the crazy fan spin if running from battery only ?
        • RODAKSAN
          • Jun 2022
          • 17
          • Mexico
          same issue with both only battery powered and battery charger powered (original 120W)
          • mon2
            • Dec 2019
            • 14628
            What is the voltage of pin # 2 (TACH_FAN_IN) on JFAN1 connector when the fan is normal speed ?
            What is the voltage of this pin when the fan is in crazy spin mode ?
            The fan speed is decided by the SMC @ U17. This component sends out the stream (pin 121) of the PWM signal to speed up or slow down the fan.
            • RODAKSAN
              • Jun 2022
              • 17
              • Mexico
              ACH_FAN_IN 3.3v, zbook turned on with no fan movement, it starts to spin seconds later
              ACH_FAN_IN 1.72v, in normal speed
              ACH_FAN_IN 1.72v, fan at full speed (zbook powered off)
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                This happens 'coz your VS lines are not not switched off even after turning off from windows. Check your dc-dc converter for 3V/5V VS .(U45/U46)
                • RODAKSAN
                  • Jun 2022
                  • 17
                  • Mexico
                  Thank you mcplslg123!! I found u45 burned, now I'm looking for a replacement. Once u45 replaced, I will post the result.
                  Best Regards
                  • RODAKSAN
                    • Jun 2022
                    • 17
                    • Mexico
                    Success!! I replaced the U45, brand new part from china (take so long time to get here :p) but the laptop works again normally. Thank you all who helped me, specially to mcplslg123
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • yaya3gmax
                      Laptop Power Issue – Works on Battery, Fails on Adapter Load
                      by yaya3gmax
                      Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                      Symptoms:
                      • Laptop works normally on a pre-charged battery.
                      • Battery does not charge when adapter is connected.
                      • Without battery:
                        • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                        • Speakers “pop” when power cut occurs indicating harsh sutdown.
                        • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                      08-21-2025, 07:16 AM
                    • ahmarzo
                      Acer laptop battery draining issue
                      by ahmarzo
                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                      08-02-2025, 06:39 AM
                    • klopez0017
                      Asus ROG Strix 17 (G733ZX) Laptop Power Issue
                      by klopez0017
                      I've had the laptop for about 2 years now, and lately, it has been acting weird whenever the AC adapter is plugged in. The issue is that when the AC adapter is connected, the charging often gets disconnected. This frequent connection and disconnection interrupts whatever activity I am doing, as it causes the laptop to underclock. At one point, the laptop even stopped charging with the AC adapter plugged in.
                      When I try to use the PD in one of the USB-C ports, it charges just fine. The only downside is that I can only get about 100W of power since that's the maximum it can take, so...
                      10-28-2024, 06:17 AM
                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                      09-06-2024, 09:30 PM
