Asus ROG Strix 17 (G733ZX) Laptop Power Issue
  • klopez0017
    • Oct 2024
    • 5
    • Qatar
    I've had the laptop for about 2 years now, and lately, it has been acting weird whenever the AC adapter is plugged in. The issue is that when the AC adapter is connected, the charging often gets disconnected. This frequent connection and disconnection interrupts whatever activity I am doing, as it causes the laptop to underclock. At one point, the laptop even stopped charging with the AC adapter plugged in.
    When I try to use the PD in one of the USB-C ports, it charges just fine. The only downside is that I can only get about 100W of power since that's the maximum it can take, so I cannot use the laptop for heavier tasks as I should be able to.
    I was hoping that someone has experienced the same issue as mine and could guide me through the troubleshooting process. I tried changing one of the MOSFETs near the DC jack port, but it only worked for a few tries before the symptoms reappeared.​
  • mon2
    • 14681
    Consider to review the mosfet that was replaced.
    What was the original mosfet part # / topside markings? Which mosfet was used for the replacement? If the mosfet was underrated then the replacement can become defective over time.
    Also review the DCin jack / connector. Perhaps it needs to be replaced if loose.
    • klopez0017
      • Oct 2024
      • 5
      • Qatar
      The original part was a PKCH2BB, as indicated in the schematics for the G533 boards. The replacement I used has the same capacity, but I'll switch it with the original brand once my parcel arrives.
      I can rule out the DC jack as the issue, as I tested the laptop, and it's receiving 20 volts. However, there's no charging indicator, so I believe the problem lies elsewhere.
      • mon2
        • 14681
        Can you link or post the schematics? Do not post here but in the schematics section of the website.
        • klopez0017
          • Oct 2024
          • 5
          • Qatar
          These are the one i followed:
          https://www.badcaps.net/forum/troubl...q25-schematics
          https://www.badcaps.net/filedata/fetch?id=3268552
          • piernov
            • Jan 2016
            • 4439
            • France
            This machine has an AC adapter detection mechanism. Reading 20V is not enough. Also if the machine tries to pull more power than the AC adapter can supply, or if there is high resistance in the DC-in jack, that's what happens. So AC adapter and DC-in jack are still suspects, as always.
            • klopez0017
              • Oct 2024
              • 5
              • Qatar
              Thank you for your advice. I'll attempt to replace the DC jack since the AC adapter seems to be functioning properly; I've tested several AC adapters and they all show the same charging behavior with the laptop. My another suspect is the mosfet that connects to the DE_JACK_DETECT I see some potential burn marks.
              • klopez0017
                • Oct 2024
                • 5
                • Qatar
                Just an update:
                So I have replaced the DC-in Jack as suggested and now the laptop works perfectly.
                Apart from the burned mosfet, never thought that replacing the dc jack has an effect as well.
                  ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                  This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                  09-07-2024, 01:00 AM
                  ASUS ROG Hero II GL504GM-DS74 Gaming Laptop Notebook Strix Specification for Upgrade or Repair
                  This specification for the ASUS ROG Hero II GL504GM-DS74 Gaming Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Hero II GL504GM-DS74 Gaming Laptop boardview and Hero II GL504GM-DS74 Gaming Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-06-2024, 07:00 AM
                • XxMicroSoldering
                  ASUS Rog Strix G17-712LV Laptop Liquid damaged
                  by XxMicroSoldering
                  Hello Guys
                  I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                  10-17-2024, 10:45 AM
                • Technodoc
                  ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                  by Technodoc
                  Asus laptop G614JZ-N3012W Rog Strix with i7
                  Mainboard G634J-PMV-VGT
                  6050A3441302-MB-A01
                  2023-02-10
                  Power button works okay....power light goes on
                  Red "bottom" leds go on
                  Charging led works
                  Fans do not spin, capslock key does nothing, screen stays black
                  I would like to program the bios again, to rule out a corrupted bios.
                  However I run into a size error
                  The bios chip is a Winbond 25R256JVEN
                  Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                  02-24-2025, 04:46 AM
                  ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook 13 Specification for Upgrade or Repair
                  This specification for the ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX331FN-DH51T Ultra-Slim Laptop boardview and UX331FN-DH51T Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                  09-06-2024, 07:33 AM
