dell 172fpt 23v but no 5v
  • alexanna
    • Mar 2010
    • 1346
    I have a dell 172fpt.Initaly there was no sign of life.D815 a transient voltage suppressor was in a real bad way, It has been replaced
    .I have 165v across the big cap c823.I also am reading 23v on the 35v 470uf caps in the c831 area.
    I am calling the 5v rail 0v although sometimes I will see about a voltage of 3.5 v to 4v that is very unsteady. Most of the time its 0v
    .On the back of the power supply there is a 14 pin ic #i801 Three numbers are on it #1 Lta201p---#2 4e843343 #3—h603421.
    I have been probing around checking voltages. And one thing I have noticed on pin #4 of L817 optocoupler I see 12v most of the time but sometimes the voltage goes down to 5v and at this time the voltage somewhat comes back to the 5v rail but it is low and unsteady.
    Direction on this would be welcomed.
    Thanks Al.
  • PlainBill
    • Feb 2009
    • 7034
    Re: dell 172fpt 23v but no 5v
    Thanks Al.
    Replace C834, C835, and C837.
    PlainBill
    • alexanna
      • Mar 2010
      • 1346
      Would Nichicon KT series be acceptable? I have some of those.
      Al
      • PlainBill
        • Feb 2009
        • 7034
        Al
        They might work for a test, but I wouldn't trust them for long term use.
        PlainBill
        • alexanna
          • Mar 2010
          • 1346
          Well The test did not work, I tried them.Also this time with power on my 23v rail was down to 20v powering down and hooking up logic board 23v came back.Was the test with the kt valid?I will order some fm series those are just some I had on hand?
          • alexanna
            • Mar 2010
            • 1346
            Well I tried some thing I hooked up a 1157 automotive bulb to the 23v rail and it will not light. testing the bulb and socket with a 12v power supply it dose light.Should the 23v rail have enough current to light the bulb?
            Al.
            • PlainBill
              • Feb 2009
              • 7034
              Al.
              Probably not, it depends on how you hooked it up. An 1157 bulb is a dual filament bulb rated at .6A and 2.1A. If you hooked the two in parallel that would be a total of 2.7A at 12v. If you use only the smaller filament, the power supply should have the capacity of lighting it - at least for a few seconds before it burns out. I would suggest hooking the smaller filament to the 5V output - that's the one that is regulated.
              You mentioned replacing D815. Obviously something BAD happened in that area. R852 also looks like it may have overheated, even though there is no sign of damage to the PC board.
              PlainBill
              • alexanna
                • Mar 2010
                • 1346
                I just used one filament to hook up to the 23v It would have been the one that would be brighter, drawing more amprage.I thought possibly since I was also seeing the 23v line go low with no load possibly a power supply was not flowing enough current.I will check R852 and get back to you .
                thank you Al.
                • alexanna
                  • Mar 2010
                  • 1346
                  R852 has About 156v on both sides.It is red-purple-silver-gold .27ohms?And its reading so close to 0 with my meter.
                  Al.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Al.
                    Probably a load sensing resistor.
                    PlainBill
                    • alexanna
                      • Mar 2010
                      • 1346
                      I would like to learn what is going on here,I have the larger size fm series caps I could install if need be.I guess what I am wondering if the reading on the volt meter is fooling me.Is the voltage there but not enough amprage? or what would be a good way to diagnose this?
                      Al.
                      • alexanna
                        • Mar 2010
                        • 1346
                        Just for infomation I powerd the lamp with a 12v battery charger The amprage of the bulb was 1.7amps larger filament.And 500ma on the smaller filament. The 23v rail will not light up the smaller filiment.I hooked it up ground to low volt board ground and positive lead to center lead of the schottky diode.I would not even light it much less burn it out. I agree.something bad must have happend to the board.Is there a way to test these schottys in circut?Or am I even thinking right?
                        Al.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Al.
                          The best way to test the diodes is out of circuit, or better yet by replacement.
                          One point - are you doing this with a known load on the 5 volt supply? The design of the SMPS is very straightforward. It regulates the 5Volt supply; the other supply (usually 12 volts) will vary depending on the load on it and on the 5V supply.
                          PlainBill
                          • alexanna
                            • Mar 2010
                            • 1346
                            I some times have a hard time explaining my self.All I have done is use the bulb like a simple automotive test lamp.The 5volt is not working so i could not test it.The 23volts was there so with the board powerd up ,one lead connected to the low voltage board ground and the other lead touched to center leg of the yg902c2 diode,The voltmeter reads 23v, but it will not light the smaller filiment of the bulb. I do not know if this is even a valid test.
                            Al.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Al.
                              It isn't a valid test. Please answer a simple question - do you have any load (the logic card, a 10 ohm or smaller resistor, or a light bulb) hooked to the 5 volt supply?
                              This is a schematic of a Dell (Benq) monitor. Scroll down to the point where a line that begins i believe that the following is the schematics is at the top of your screen.
                              This is a poorly drawn schematic, but it illustrates the basics of what happens with your power supply.
                              T601 is the SMPS transformer, the winding betwwen pins 7 and 9 is the primary while Q601 is the power FET and IC601 is the SMPS controller.
                              At start-up IC601 gets it's power through Q602 and the associated resistors. When the voltage across C606 hits the startup threshold, IC601 turns on Q601, sending a pulse of electricity into the primary of T601. That produces proportional pulses in the secondaries 2-3; 6-5, and 12-11. Those pulses are rectified by by diodes D7021, D701, and D604, and the DC voltage stored by C707 & C708( 5V); C703 & C704 (inverter power); and C606 Vcc for the SMPS controller.
                              The next thing of interest is R616. It reduces the drive pulse if the current through T601 and Q601 goes too high.
                              Now look at IC702 and IC602 (the optocoupler). When the 5V output reaches 5 volts the LED in IC602 begins to emit, causing the SMPS controller to reduce the duration of the output pulse.
                              Something that is important to remember. The inverter output is not regulated. The more energy the SMPS controller has to dump into the transformer to maintain the 5V output, the higher the inverter voltage will go. And I am suspicious; the inverter voltage you measured seems very high.
                              Back to your monitor - remember, the function is identical, the part numbers are different. Have you checked the output diode of the 5V supply? Have you checked the capacitors? The condition of the board around D615 etc really bothers me. Are you sure you replaced D616? with the correct part?
                              PlainBill
                              • alexanna
                                • Mar 2010
                                • 1346
                                The logic card is hooked up to the power supply with A d sub cable and a powerd up computer.
                                The capacitors for the 5v have been changed with panasonic fm series.
                                I know your not going to belieave this,After I read your last post I went back to verify voltages,I was reading 11.83v at d820.Unpluging power cord and pluging back in the 23v came back, This is not B.S. it is realy changing.
                                I will stand down at this point and follow your directions, I would realy like to understand how the smps works.
                                I will check the of the points of interst in the afternoon
                                Thanks Al.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Thanks Al.
                                  That kind of change indicates a bad solder joint. I would suggest 'touching up' all the solder joints in the area of the SMPS and the secondary. I've outlined the general area, and numbered some that I consider suspect.
                                  I've been unable to locate a datasheet for the SMPS controller. Have you been able to find one?
                                  PlainBill
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    Something realy strange is going on here.I have double checked all voltages.Today I am reading 2.5 vto 3.2very unsready on the center leg of d813.And 23v on the center leg of d820.
                                    I am doing my best to ask the correct questions so thanks for staying with me.
                                    You say check the 5v output,Is that going to be on the hot side of the board.
                                    I do not know If it is imporentent or not but on pin 4 of the octocoupler I am reading 10v this is on the hot side of board.
                                    I will touch up solder joints as recomended.
                                    You did ask if I replaced the correct diode that was damaged,I beleave so It was d815 and the markings on it were p6ke130a, and it was replaced with mouser part#
                                    576-p6ke130a.I am not good at adding links yet.
                                    D816 has been removed from board and tests ok.
                                    C829 the brown cap has been replaced with on from annother board
                                    Thank you Al.
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      PlainBill
                                      No on the datasheet.
                                      Well Is any body else having trouble opening the attachement?
                                      Or did i do some thing wrong?
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        PlainBill
                                        I have done a bunch of resoldering.But I am unable to open any atatchments to see your suspect ones.May be tommrow?
                                        Thank you Al.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
