HP R33 no +VCC_GFX
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    HP R33 no +VCC_GFX
    I checked PU15 (NCP5911) and it has power on
    Pin1 - BST - 4.89V
    Pin2 - PWM - 1.9V
    Pin3 - DRVEN - 4.89V
    Pin4 - VCC - 5.1V
    Pin5 - Low gate - 0v
    Pin6 - GND - 0v
    Pin7 - SW - 0v
    Pin8 - Hi gate - 0v
    Is this OK for this chip?. But i couldn't find any voltage on PL29.
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: HP R33 no +VCC_GFX
    I replaced another chip but i got some different results. There are
    Pin1 - BST - 0V
    Pin2 - PWM - 1.9V
    Pin3 - DRVEN - 1.9V
    Pin4 - VCC - 5.1V
    Pin6 - GND - 0v
    Pin7 - SW - 0v
    Pin8 - Hi gate - 0v
    So which one is correct. This also not produced any voltages on PL29
    • piernov
      • Jan 2016
      • 4438
      • France
      The new chip isn't soldered properly I think. Anyway what is the resistance between +VIN_VCC_GT and pin 7, and between pin 7 and 6?
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        +Vin_VCC to Pin7 is 300 Kohms, Pin7 and Pin6 is 200 Ohms
        • piernov
          • Jan 2016
          • 4438
          • France
          Sounds ok so I would go for a defective/wrongly soldered PU15.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            I replaced PU15 with another one ( I am getting those from scrap boards ) now again it shows
            Pin1 - BST - 4.89V
            Pin2 - PWM - 1.9V
            Pin4 - VCC - 5.1V
            Pin6 - GND - 0v
            Pin7 - SW - 0v
            Pin8 - Hi gate - 0v
            But still i cannot find any voltages on PL29
            • piernov
              • Jan 2016
              • 4438
              • France
              Do you have an oscilloscope to check the signal on pin 2 — PWM?
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                I don't have oscilloscope. I checked with 3 chips on PU15.
                • piernov
                  • Jan 2016
                  • 4438
                  • France
                  Maybe the issue comes from PU10 not outputting the right PWM signal. Your issue looks very similar to https://www.badcaps.net/forum/showthread.php?p=754825 even though the board relatively different.
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    I have doubt on that also. But unfortunately i have only NCP6131 but on this board need to put NCP6132 it is not same. So have to wait until to get new chip.
                    • piernov
                      • Jan 2016
                      • 4438
                      • France
                      Unfortunately no, NCP6131 is QFN-52 and NCP6132 is QFN-60 package.
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        Today i replaced PU15 and checked again. The following results came.
                        Pin1 - BST - 4.89V
                        Pin2 - PWM - 0V Change found on here
                        Pin4 - VCC - 5.1V
                        Pin5 - Low gate - 5v Change found on here
                        Pin6 - GND - 0v
                        Pin7 - SW - 0v
                        Pin8 - Hi gate - 0v
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          I solved this problem by Flashed the bios with new. Now the laptop working fine. Thanks Piernov for your ideas and help.
                          • piernov
                            • Jan 2016
                            • 4438
                            • France
                            Could you write the final measurements before and after BIOS flash? It may help others.
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              Sorry I measured only Hi gate Pin 8. It shows 1.03V and Pin2 ( PWM ) Shows only - 0V. Now i handover the laptop to customer.
                              • Lvsitano
                                Asus X532FL 3.2V at source and gate
                                by Lvsitano
                                I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                First...
                                06-26-2024, 02:13 PM
                              • howardc64
                                Macbook Dust-Gate Preventive Cleaning
                                by howardc64
                                Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                                Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                                https://www.ifixit.com/Guide/MacBook...leaning/177920
                                10-09-2024, 10:10 AM
                              • irfan karatela
                                MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
                                by irfan karatela
                                I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
                                I havent found any shorts on the board.
                                I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
                                On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
                                01-20-2025, 07:15 PM
                              • netgearnetgear
                                D747m_1v3 logic board for remote gate
                                by netgearnetgear
                                Good day,
                                My remote gate stopped working. The company said the main logic board needs replacement. After examining and running a couple of tests, I discovered what looks like a shorted zener diode. Tracing the path on the board it appears to be across a voltage regulator chip (78m05). After reviewing the datasheet for the voltage regulator I thought that it was being used with a zener diode as a voltage boost regulator. However, looking at the layout of the board the "shorted diode" is not connected as in the datasheet. The diode does not have a markings so I am not sure what...
                                06-22-2024, 03:28 PM
                              • wagivem657
                                Sharp LC-55LE643U, bad gate drivers?
                                by wagivem657
                                Just received a busted Sharp 55" Aquos (LC-55LE643U) from a coworker. He tried swapping all three boards (power, main, TCON) to fix the problem, but it had the same issue. He was kind enough to give me the TV and both sets of boards for free, so I can try to get it working for myself.
                                Unfortunately, I think I may have made the problem (much) worse, but I'm interested to see if the original problem was fixable at all regardless...
                                Pictures show the issues:
                                1. shows what happens when you first turn the TV on. Well, kinda, the white column wasn't there at
                                01-29-2021, 08:13 PM
