HP R33 no +VCC_GFX
    HP R33 no +VCC_GFX
    I checked PU15 (NCP5911) and it has power on
    Pin1 - BST - 4.89V
    Pin2 - PWM - 1.9V
    Pin3 - DRVEN - 4.89V
    Pin4 - VCC - 5.1V
    Pin5 - Low gate - 0v
    Pin6 - GND - 0v
    Pin7 - SW - 0v
    Pin8 - Hi gate - 0v
    Is this OK for this chip?. But i couldn't find any voltage on PL29.
    Re: HP R33 no +VCC_GFX
    I replaced another chip but i got some different results. There are
    Pin1 - BST - 0V
    Pin2 - PWM - 1.9V
    Pin3 - DRVEN - 1.9V
    Pin4 - VCC - 5.1V
    Pin6 - GND - 0v
    Pin7 - SW - 0v
    Pin8 - Hi gate - 0v
    So which one is correct. This also not produced any voltages on PL29
      The new chip isn't soldered properly I think. Anyway what is the resistance between +VIN_VCC_GT and pin 7, and between pin 7 and 6?
        +Vin_VCC to Pin7 is 300 Kohms, Pin7 and Pin6 is 200 Ohms
          Sounds ok so I would go for a defective/wrongly soldered PU15.
            I replaced PU15 with another one ( I am getting those from scrap boards ) now again it shows
            Pin1 - BST - 4.89V
            Pin2 - PWM - 1.9V
            Pin4 - VCC - 5.1V
            Pin6 - GND - 0v
            Pin7 - SW - 0v
            Pin8 - Hi gate - 0v
            But still i cannot find any voltages on PL29
              Do you have an oscilloscope to check the signal on pin 2 — PWM?
                I don't have oscilloscope. I checked with 3 chips on PU15.
                  Maybe the issue comes from PU10 not outputting the right PWM signal. Your issue looks very similar to https://www.badcaps.net/forum/showthread.php?p=754825 even though the board relatively different.
                    I have doubt on that also. But unfortunately i have only NCP6131 but on this board need to put NCP6132 it is not same. So have to wait until to get new chip.
                      Unfortunately no, NCP6131 is QFN-52 and NCP6132 is QFN-60 package.
                        Today i replaced PU15 and checked again. The following results came.
                        Pin1 - BST - 4.89V
                        Pin2 - PWM - 0V Change found on here
                        Pin4 - VCC - 5.1V
                        Pin5 - Low gate - 5v Change found on here
                        Pin6 - GND - 0v
                        Pin7 - SW - 0v
                        Pin8 - Hi gate - 0v
                          I solved this problem by Flashed the bios with new. Now the laptop working fine. Thanks Piernov for your ideas and help.
                            Could you write the final measurements before and after BIOS flash? It may help others.
                              Sorry I measured only Hi gate Pin 8. It shows 1.03V and Pin2 ( PWM ) Shows only - 0V. Now i handover the laptop to customer.
