I ended up with this board as a freebie, just because it had a bad cap in between the PCI slots (an 820uF 6.3V KZG to be specific). It appeared to be working fine, though in spite of the bad cap. I didn't have very many 820uF lytics on hand, but I have LOTS of 820uF 2.5V polies, most of which are scavenged from motherboards, plus a few new Fujitsu "bumble bee" polies from Topcat.
So, after measuring the voltages on them, I found that only a few of them had 5 or 3.3V on them - most were on the low sides of RAM and Chipset VRMs, so here was my approach. For the 820uF parts which were on the high sides of VRMs, I used the few 820uF 6.3V Ruby MCZ and MBZ caps I had left. The VRM low side caps which had less than 2V on them, I used Fujitsu 820uF 2.5V polies, and for the USB and Audio filtering caps, I used 1000uF electrolytic caps. The Ethernet NIC controller was also missing the cap on its power supply from the factory ( goes to ASUS for that one). I added a 220uF 16V Panny FR there. The best part is, I managed to get all of them in the first time without reverse-polarising any of them.
The board boots to the BIOS reliably still. I haven't installed an OS yet, but hopefully, it will work fine.
EDIT: I didn't touch the CPU VRM on this board. It came with Panny FJs on the VRM high side and NCC PSC Polies on the low side.
