...so I ripped it off (quite literally) and taped the fan from my projector (a little "TC" brand screamer, OK at lower speeds though) to a nearby PCI slot, then made a duct from more duct tape. The projector got an old 80mm Nidec Beta SL fan from my old Astec power supply that I took apart. The duct that I made is designed to force air through the heatsink and out the top front. It works quite well and keeps the heatsink cold to the touch even at 5 volts.
Fan died on my video card...
Re: Fan died on my video card...
lol @ taped.... I've done some pretty shoddy things to PC's over the years, but I've never done that!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Originally posted by Elysarian View PostIf it moves and it's not supposed to: Duck tape.
If it doesn't move and it's supposed to: WD40Last edited by goontron; 06-19-2013, 03:04 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.
Nice. I love ghetto modding
We do have a dedicated thread for this
https://www.badcaps.net/forum/showthread.php?t=23719I love putting bad caps and flat batteries in fire and watching them explode!!
Nah, it's sill on the 1st pageI love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by c_hegge View Post^
nah, it's sill on the 5th pageLast edited by goontron; 06-19-2013, 07:11 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Last edited by c_hegge; 06-19-2013, 09:17 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Ah, 5 pages long. 95 more to goI love putting bad caps and flat batteries in fire and watching them explode!!
it should be sticky to.. but it isn't yet.
thinking about reviving it with how i just hacked my dryer to stop squeaking.
on topic: good hack cheapie had to do something similar with the onboard video of my intel mobo.Last edited by goontron; 06-19-2013, 10:16 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
You could get a new fan from Newegg for a few dollars. I have video card that I have put two new fans on. The fans were about ten bucks each. The card was a big AGP card with lots of memory onboard. If this PC had and AGP slot that card would be in it."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod Serling
Originally posted by goontron View Postit should be sticky to.. but it isn't yet.
on topic: good hack cheapie had to do something similar with the onboard video of my intel mobo.sigpic
(Insert witty quote here)
Originally posted by shovenose View PostTape fixes everything!
http://www.youtube.com/watch?v=naJ18PUo55o
Just a heads up, tried that with my old 9800GT after the fan quit working, the tape often comes loose at higher temps and the fan falls off.
Eventually settled on this haha, AMD stock cooler cable tied: http://i.imgur.com/RznzF.jpg
Probably my favourite mod, it hit 45*c max in furmark! Took up like 4 or 5 slots though.
Miss that card, it was already on its way out due to the fan being blocked for god knows how long, reflowed it about 8 times before it was gone for good.Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
Originally posted by cheapie View Post...so I ripped it off (quite literally) and taped the fan from my projector (a little "TC" brand screamer, OK at lower speeds though) to a nearby PCI slot, then made a duct from more duct tape. The projector got an old 80mm Nidec Beta SL fan from my old Astec power supply that I took apart. The duct that I made is designed to force air through the heatsink and out the top front. It works quite well and keeps the heatsink cold to the touch even at 5 volts.
https://www.badcaps.net/forum/attach...1&d=1392224562
