New bluescreen message...
    So i just set my main monitor here on the dual-PIII to 1400x1050. Like so.
    I shut down the computer and went to the beach, had a few with my friends, then back to the hood, had a few more , and finally back home. I turn the computer on to find a blue screen, PAGE_FAULT_IN_NONPAGED_AREA. I restart it only to find another one, IRQL_NOT_LESS_OR_EQUAL. Now, i know those screens are usually caused by overclocking, and i am overclocking, but it's been perfectly stable so far. So wondered if the problem was caused by my recent resolution change.
    I rebooted in VGA mode, and sure enough, no BSOD. However i couldn't enable the second screen after the VGA mode reboot, so i set the resolution to 1280x1024 on the main and rebooted again. Sure 'nuff, worked fine. I've set the main monitor to 1400x1050 again and disabled the second screen. I wonder if it'll boot fine tomorrow...
    So i propose a new designator for bluescreens: MAXIMUM_RESOLUTION_REACHED
    A working TV? How boring!
    Re: New bluescreen message...
    PAGE_FAULT_IN_NONPAGED_AREA = Unstable RAM. (May be a bad RAM slot.)
    IRQL_NOT_LESS_OR_EQUAL = Unstable core. (You can get this error when Linpack fails.)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      I have seen two "new" BSODs. On one, the screen halves had been switched around (right half on the left side of the screen, left half on the right side). On the other, the computer crashed with several errors at the same time. I watched the text scroll up the screen for a second before it finally stopped. There was also one section of text that appeared twice - once near the top of the screen and once again just before the only visible STOP error code (0x000000c5). There were also sections of text that normally only appear in the IRQL_NOT_LESS_OR_EQUAL message. I would guess that there were at least five errors at the same time.
        I get those even though I know my RAM is definitely stable (couple days of Core Damage and Memtest). I just have faulty drivers for gfx and audio interface on one install (something's messed up). I would just check your drivers. If you know your oc is good, then it may be your board. What gfx card do you have?
          It had nothing to do with the board or RAM. It had purely to do with the resolution and the desktop arrangement - i use EnTech iRotate to get a secondary 17" LCD in portrait mode, because the video driver doesn't have this option by itself. Without the secondary monitor enabled the system booted just fine.
          The video card is a Radeon 9800 Pro 256MB but that's soon to be changed for a HD4650 or 4670. I'm using Omega drivers.
            Looks like the CPU has gotten stable, those look like processor-related errors,
            usually when you OC the core too high or require a Vcore bump.
              I had back luck with those, the first one I got second hand was fine at first, but when I wasn't even in Windows, gave corrupted video and then when I rebooted, also a corrupted BIOS screen!
              And sometimes, moving it around helped! Suspect it's a solder joint problem,
              I have a gut feeling that it could be.
              But, it was junked a long time ago, that was in spring, 2007.
              And I did almost make a 3D Mark test! It seemed to be fine if it didn't even get moved by a 32th!
              It works fine intermittently!
              Could this be a bad BGA solder job?
                Mine was bought second hand too, but i've had it for several years. It's also overclocked and voltmodded... i am using aftermarket cooling though.
                It sometimes displays a colored dot or two when i'm watching a movie and the scene is very dark. It could do with some ramsinks, but i always forget. Otherwise, it's never been trouble.
                  Yep, definitely graphics driver issue then, since you are using Omega+iRotate. It's probably out of spec for the driver or something, something is making it throw a fit. Since you're going to upgrade anyway, might as well just hold out and start fresh with your new gfx card. Is iRotate the same thing as Powerstrip?
                    iRotate is from the makers of PowerStrip, yes. All it does is handle rotation, but compared to the whole package, iRotate is free. And most of the features in PowerStrip i have in ATi Tray Tools anyway, i don't want to run them both at the same time.
                      That computer worked fine after updating the BIOS. There was a bug that caused Windows to crash on a cold boot with a random BSOD or a message saying a certain file was missing. When Windows finally booted, there was the chance that it would crash after running for a few hours.
                        Kind of sounds like my issue with my Core 2 Duo E4500 OC, with load line calibration disabled,
                        it will fail to POST on a cold boot and I have to turn it off then back on again.
                        Even during this, it was stable when in Windows and Linpack passes.
                        It seems to be related to not having enough juice to start the E4500.
                          http://technet.microsoft.com/en-us/l.../cc957625.aspx
                          http://msdn.microsoft.com/en-us/library/ms854226.aspx
                          When you get both at the same time it's almost always bad RAM or a corrupted driver [or system file] that doesn't load right into RAM.
                          Sometimes it's a buggy program that can't keep track of where it puts things in RAM.
                          Mann-Made Global Warming.
                          - Dr Seuss
                            I had that bluescreen when I had the latest radeon driver on a AMD 785 chipset (showed up as a the radeon designation on the device manager), I installed the driver from the MB manufacturer (showed up as AMD 785 on the device manager) and it was never a problem
                            lately the latest radeon driver that designates the integrated vga as its radeon equal has been working just fine, even played max payne 2 on this 880 I built for a customer of mine
                              Omega still makes drivers?
                                http://omegadrivers.net/ Latest ones are dated just a few days ago, so the answer is yes. The 9800 runs on an oooooold version anyway, as ATI dropped support a few years ago.
                                  Last known good driver for my 2900XT is 11.3.
                                  There was series of drivers up untill 11.2 which caused ati2dvag BSOD with the XP drivers and my card, plus older OpenGL games like Jedi Outcast and Academy (Thus including Movie Battles II, which brings my Dual core Athlon 64 and 2900xt down to their knees at 1280x1024 - not bad for a game that runs on a heavily modified 10+ years old Quake3 engine) would crash when they were launched.
                                  11.3 is a bastion of sanctity, sanity, and stability. Anything newer now gives me ati2mtag BSODs.
                                  I've not tried the new 11.7 (Though I think I tried the RC which also gave me BSODs) but I've reached the conclusion that ATI's XP drivers are NOT really UDA (Unified Driver Architecture) to the same extent as nVidia's drivers. If enough people whine sufficiently on their Catalyst forum about the same problem, they *might* fix it (Like we did with Jedi games not working - and they fixed it to their credit). But they are really negligent when it comes to fixing driver issues with older cards. Like when I swap displays from my TV and LCD, under no circumstances will Catalyst remember the resolution of my LCD and forces me to use 1024x768 until I change it manually. Very inconvenient.
                                  Incidentally, I am using the 266.58 nVidia driver for a relatively old GeForce 6600 in XP (And FYI, eventhough nVidia is claiming support for this card in their newer drivers, I can confirm that this is the last driver version that will work at least for the GeForce 6 series in XP).
                                    IRQL-NOT_LESS_OR_EQUAL is almost always a driver issue unless you are overclocking. Try uninstalling your video driver and updating to the latest version. Update the chipset driver as well...this is vital on non Intel AGP systems.
                                    PAGE_FAULT_IN_NONPAGED_AREA can be bad RAM, a bad HDD, or a bad driver stepping on some memory it shouldn't have.
                                      The interesting bit is that it was an one-time thing - i have been booting with both monitors enabled for the past few days and it's been working fine.
                                        Get rid of those Omega drivers...
                                        I don't know what gave you the idea that they're only a few days old... His main page links to ATI drivers, not his own. His actual driver download page only shows two drivers, the XP one dating back to December 2007.
                                        I'm sure you can do better than that.
