When first recived this tv I had a light blue standby light. Unplugged power removed left side ribbon cable to the t-con board and now no standby light showing. Reset everything back to where it was and checked voltages. Getting all led power 86v. As far as voltages to mainboard pins 1,2,3 19 volts4,5,6 ground pins 7,8 0 volts pin 9-ps on 0v pin 10 0 volts. Checked main board caps getting different readings with same cap values 220uf 25v
LC65lE654u no power
Re: LC65lE654u no power
Originally posted by charlie555 View PostCould it be the caps giving different readings they are the same value should they not be giving similar readings?Never stop learning
Originally posted by charlie555 View PostWhat are buck converters?
