Hello all,
Someone give me this mobo with CPU attached to try to help him.
I connect to my known good PS and memory. It does not POST/beep.
When the power button is pressed, the mem light on the mobo will light and the CPU fan will run. If I press and hold the power button, it will shut down in a few seconds. If I press the power button, it will start up again, just won't POST.
The CPU heatsink does get warm if I disconnect the CPU fan.
I ohmed the MOSFETs and they are not shorted. They all have similar ohms when compared to each other. However, I use my IR temp meter and one of the 4 MOSFET remains at room temperature (25degrees). The other 3 runs at about 30degrees. (How do I attach picture?)
I have browsed thru all the posts on "KZG" and Gigabyte and learned that these KZGs although not showing any bulges should be replaced.
Also, do the other two HD series caps (1200/6.3V) seems to have shrunk sleeving?
Finally, I popped off the heatsink and found the CPU in quite good shape (i.e, no burn mark).
Any suggestions before I start with recapping?
