I have a situation where a battery charger will be destroyed if the battery that it is charging is accidentally connected backwards. So Id like to come up with some kind of circuit that will not allow current to flow from the battery being charged back into the charger if it is accidentally connected backwards. A diode will not work because the voltage drop across the diode is significant enough that the battery being charged will not be charged properly.
I realize that people will question the application and wonder why this or why that, but I've been through all that, I just need to know if there is something out there or some kind of circuit I can apply to this function that will produce the results I am looking for.
I have attached a small simple diagram.
Thank you,
Thank you,
