I have a Samsung LN52A650. The TV has screen artifacts and will repeatedly power cycles when a input source (any of the HMDI, component, and composite) is selected and active (the source device is powered on and providing input to the TV). When an active input is selected the screen will display video artifacts(see attached pictures) and after approximately 10 seconds the TV will power off and on by itself. When in this state the TV will not respond to input from the remote. After a variable number of power cycles the TV may start to work properly or the TV may have to be shut off by pulling the power cable. If the TV works correctly it will infrequently display the artifacts after some period of working correctly and begin to power cycle.
With no input to the TV (sources disconnected or turned off) the TV powers on and "No signal detected" is displayed on the screen as usual. The TV's menus can be displayed and browsed in this state, the remote works and there is no visual artifacts on the screen. The TV can be left in this state for an extended period and no artifacts appear. As soon as an input source is connected turned on and selected as the source in the TV artifacts will appear and the power cycling will begin.
I took it to a repair outfit in town and their diagnosis was the buffer boards between the Tcon and panel. That doesn't make much sense to me, but I have not tried debugging a TV before. Does the buffer boards explain the symptoms?
