sanyo no back ligth
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #141
    Re: sanyo no back ligth
    Off topic a bit - I have a question for Budm Or Tom66. On the bottom of the board (Pic post 70) Pan along the bottom edge t the midpoint hole then up slightly there are two points marked OVP 12v and OVP 5v - OVP means Over voltage protection? but are those actual components or what? Cant see anything to correspond on the top of the board.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #142
      Originally posted by budm
      OK. please check the fusible resistor R322 that feed the B+ to the inverter transformer driving circuit.
      You may as well check the other two fusible resistors at R332 .
      I attach a datasheet for the transformer I am not sure what you can test on it
      Start with the primaries - Power off - meter on 2000 ohms check and post result. Budm or Tom may be able to suggest further tests ( How to check the secondaries)
      • ealequi
        • Dec 2012
        • 212
        • usa
        #143
        I am going to test the transformer to see if there is power going in and coming out
        • ealequi
          • Dec 2012
          • 212
          • usa
          #144
          I am not easy to give-up
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #145
            Dont do that - do resistance test only - did you read the datasheet
            1500 Volts probably wont do your meter any good.
            • ealequi
              • Dec 2012
              • 212
              • usa
              #146
              thank for the advise
                That datasheet for the transformer doesn't look like the correct part. It looks like a conventional 50/60 Hz transformer, not an SMPS one.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  #148
                  GOOD CATCH Tom - I am now fairly sure you are correct (again )
                  I have checked and re googled under the part number PFT24-35 It is even available on Digikey cant think why anyone would save it on a pdf with the part number of this transformer MP-130B. I thought it was a bit easy to find and it did look the same shape/pins etc and the 1500Vrms threw me .
                  The one on the board is probably proprietory and unobtainable.
                  Ealequi - have you tested the fusible resistors?
                  • ealequi
                    • Dec 2012
                    • 212
                    • usa
                    #149
                    which is that one? i still learning.
                      Yes, he tested R322 which is the main fusible resistor in this instance.
                      The fault is probably on the IC which drives the MOSFETs.
                        So is R322 good or bad? I did not see the reply.
                        By the way the BL_ON at 1.7V is OK, I look at the circuit, it is fed by the 3.3V power supply for the switched transistor Q1805 of the main board. So you can splice the BL_ON wire back together and make sure to remove the 1K resistor from CN6.
                        The power supply board uses PFC Voltage booster, so he needs to check the voltage on th capacitor C821, it should have 170VDC when TV is off and about 380~390VDC when V is ON.
                        • ealequi
                          • Dec 2012
                          • 212
                          • usa
                          #152
                          can you give me the location pls.?
                            Please take more pictures.
                              see post 140
                                R322 was tested at 3 ohms. Given the lead resistance from a typical DMM, that seems like a good fusible resistor.
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #156
                                  I wasnt sure about the soldering on that resistor - How about a voltage reading at both ends ?
                                    I trace out the board, R322 is the main fusible resistor that feeds other fusible resistor for the 5V SMPS, and also the 12v SMPS circuits, so it must be OK.
                                      OK, what are the P/N for these two IC?
                                      Per diagram and look at the bottom of your board, check C312.
                                      • ealequi
                                        • Dec 2012
                                        • 212
                                        • usa
                                        #159
                                        • ealequi
                                          • Dec 2012
                                          • 212
                                          • usa
                                          #160
                                          sorry i was not home
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
