Supermicro P6DGU Retro Build
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Supermicro P6DGU Retro Build
    Started putting it together....This motherboard fit the case like a glove. Every standoff lined up. Motherboard headers didn't even need any modifications. This one is going too easy!
    FWIW, the mfg date on the tag is 7/20/98....I was 24 when this was made.
    Next sunny day (hopefully tomorrow) I'll mix up some 'soup'.
    Still using the test HDD's. Front panel LED's work, and booted normal.
    Yup, so far so good. Momaka, that is FF24.8.1, the last release of ff24. Functions well.
    More later......
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • lti
      • May 2011
      • 2555
      That's a nice system.
      Originally posted by momaka
      I know it's a CD-ROM drive, but I would still actually have tried to fix that Samsung drive of yours.
      It was completely dead, and the main processor got extremely hot.
      The one in my Gateway 1000 had a normal-size AT PSU. Made by PowerTronic, IIRC. Looked well-built on the inside.
      **EDIT** I found two pictures of that Gateway PC. My memory was wrong, it's actually model number P5-100.
      This was a GP5-200. It didn't have that PSU adapter. It also had the cover plate over the rear fan opening.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        The soup....
        Not perfect, but came out good. They never come out 100%, but short of actually repainting the plastics, I'm happy.
        Flash on (the flash always accentuates flaws, making it look worse):
        Flash off (what it looks like normally):
        Yes, I know the drives are crooked....they're just sitting in there loose.
        Getting close.
        Team : 49813
        Join in!!
        Team Stats
        • Drack
          Yup it's me
          • Nov 2016
          • 297
          • Venezuela
          Man I don't know why but I love this kind of builds, I think is just because the parts were built to last, new PC components are just not as exciting yeah you can run everything you might think but that takes a bit of the fun with it.
          For the os XP was just perfect , I still use XP on the computer I use for college (not connected to internet tho) hey another other thing I don't like windows 10 believe it or not but the os that I like the most is windows 8 just because of that tablet like interface... (Off topic ik)
          Congrats on your new build and I'm waiting for the final results!
          • brethin
            • Dec 2008
            • 1907
            If you could just grind off that Gateway emblem and glue on a SuperMicro emblem it would be perfect.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              https://www.badcaps.net/forum/attach...1&d=1539376837
              Don't worry that much. I agree that flash always makes things look worse than they are (and hence why I always try to take shots without). But in this case (pun intended ), the results came out excellent, IMO.
              The only thing that catches my eye is the corroded spots on the bottom of the metal of the case. Any plans for that and any way to stop the from popping back. I have tried spray painting before with store spray paint, but often bad rust spots (especially those from roach and/or bedbug poop) tend to come back right through the paint. Got any tips for that? I tried latex paint on another case recently. Seems to be holding up better and the paint is also a bit harder to nick away than regular spray paint. I did apply it with a brush, though, so it looks... well... not amazing. Not terrible either, though.
              By the way, the oldschool case for the SM build I'm planning to use has only a few rust spots on the bottom (and by that, I mean on the side facing the floor). Yet, it drives me nuts and I really have to sand it off and do something about it. I might try the same latex paint treatment.
              Meh. Didn't notice until you mentioned it.
              I regularly just screw optical drives just on one side when I'm short on screws or the case feels tight enough that I don't thin screws on the other side are necessary (on loose cases, they are, as otherwise you get terrible vibrations.)
              Yessir.
              I use it on a daily basis here. Same goes for Opera 12 - the last version with the *real* Opera engine and not Chrome-plated poop.
              Nah, I think that's part of the charm here.
              However, he could put a small tiny sticker somewhere, saying "powered by SuperMicro" or something like that.
              • brethin
                • Dec 2008
                • 1907
                I was looking through my storage units today and found some really old tower cases I bet Topcat could steath mod. One is a NEC Tower and One is a Speery Univac "Militay only" USNavy ships I somehow saved from the back in the late 1980s when I was in service.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  I usually just clean it up with a scotchbrite pad and leave it at that. If not stored in a humid place, it won't get any worse. If you want to paint/restore it, you have to grind it out (like you would doing body work on a car), down to the bare metal. You'd then have to treat it with rust inhibitor and fill the pits.....then prime & paint. I've done it before, and it looked better than a restored '57 Chevy.....but for a PC case, it's hard to justify...
                  I always save screws when scrapping out total junk...I've got little storage drawers full of them....you can never have too many.
                  Yessir.
                  Opera....I can't even remember the last time I used that.... Never used chrome, and never will.
                  The emblem just pops out, but it would leave a blank in the shape of the 'gateway 2000' logo.
                  I could only imagne what those weigh, shipping would be out of the question.... One of these days I need to take a road trip out your way and pilfer your stash.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • brethin
                    • Dec 2008
                    • 1907
                    The Speery Univac tower weights a ton, it even has 2 8.5" drive bays for the old school floppy drives.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      This one is complete. I filled the 2x fan ports with some fans I scavenged from a junk powmax PSU...if anyone remembers 'powmax', the fans were the only thing in one of these pieces of crap that were good.
                      I reassembled the case....and here we are!
                      POST bliss!
                      This has been a fun one!!
                      Team : 49813
                      Join in!!
                      Team Stats
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #31
                        Man, those Plextor optical drives look awesome!
                        And I see both of them have their lights on. Are you reading something from one and burning it on the other?
                        Of course! PowMax is the reason I found and joined badcaps.net... and also how I got interested in power supplies.
                        Now this might seem a little embarrassing for you, but while we are on the topic, I remember finding this quote from a while back
                        About a year ago I had a Powmax 500 watt power supply incinerate itself... Smoke poured out of the case, and the PC obviously stopped workin...
                        I took the cover off and the switch-mode transistor had burnt beyond recognition, along with everything around it... With that kind of damage I didn't even think to look at the caps... HEH...
                        I've since thrown it away, but I'll keep my eyes open... I frequently recommend and use Powmax supplies!!
                        And the thread can be found here, just so you don't say I made that one up.
                        Yeah, that's the thing - it is fairly humid where I am... and we don't even have a basement! (On that note, when I've picked up PC gear from really humid houses with basements, sometimes even the dust is so humid that it corrodes any metal parts that it touches.) So I do have to do something about rust spots, otherwise they keep growing bigger as the rust picks up more moisture and grows.
                        I've never done any car painting work, so I wouldn't know how to give the case a proper paint job. But as I mentioned, I did experiment on one PSU and one PC case with some latex paint after deeply cleaning the rust spots with sandpaper (I think I got pretty close to bare metal). Hopefully the latex paint will create a rubber-like moisture-proof seal to stop the rust from growing again. It seems that regular spray paint does not do that. Perhaps on the next case, I might try oil-based paint / wood stain. But I don't know. What're your thoughts on this?
                        I did that at some of my previous jobs, so I do have some spare screws too. But like you said, you can never have too many. Just when I think I have enough, some project comes up and gobbles them all up.
                        Well, now that FF24 and Opera 12 are pretty outdated, I find it equally likely/unlikely that a certain website will or won't work on them.
                        For general use (like looking for datasheets on Google or wherever else), I prefer Opera, as it's lightning-fast compared to any FF browser. But it seems that FF24 still has more websites compatible with it than Opera 12. So on a day-to-day basis, I usually have both open.
                        Opera 12 is wonderful for badcaps.net, BTW - especially on PCs with low RAM. I can browse BCN forums all day with over 20 tabs open and never run out of RAM - even on PCs with as low as 384 MB of RAM. Meanwhile, FF24 needs at least 1 GB with XP. And it feels a bit more sluggish too. Opera 12 + instant page redraw in options = lightning-fast loading times.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          No, they're empty....but Plextor being the awesome creatures that they are, they have an 'on/busy' LED (the one that's lit), and another that lights if there's a disc in the drive. The burner has 4 blinky lights....I don't remember off the top of my head exactly what each one is for.
                          You do realize that's 15yrs old? I've learned a few tricks over the last 15 years since that post...mainly, having one go up in smoke and understanding the reasons why. Prior to that, it was solid....live & learn!
                          It probably won't stick. Try some Rustoleum spray with rust inhibitor, that stuff works really well.
                          If you remember that big black double motherboard server tower, that one came with a gigantic bag of screws & hardware...I never understood why it came with all that, I didn't even use half of them....but I guess that's a rarity, the cheapass case makers these days usually don't give you enough.
                          I haven't tried it in ages....I might have to dig it up and tinker...
                          Team : 49813
                          Join in!!
                          Team Stats
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #33
                            Absolutely. (which is also why I included a link to the original post).
                            I just felt like teasing a bit.
                            Hope you didn't mind.
                            Yeah, I have that feeling too. I'm just trying to thin down on the garage stock of old paint stuffs. Will check out the Rustoleum when I go to Home Depot next time.
                            I do remember it. But like you said, that's a special one. Regular store-grade PC cases don't even compare to it.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              Nah....I can totally chuckle at myself when I know I said something dumb....especially looking 15yrs back at it.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                I added the removable HDD racks this morning....it sure earns it some 'cool points' with the look.
                                Now, for all that laugh at the old school Matrox G450....eat your hearts out, one of the first independent-mode dual head GPU's.
                                I was given 5 of these Dell 19" 4:3 A/R monitors. 4 work, one of them had strange streaks across it when any kind of signal was applied, but OSD and internal test patterns were fine....
                                Such a super cool build!
                                Team : 49813
                                Join in!!
                                Team Stats
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #36
                                  Indeed, it looks more complete on the front now.
                                  Yup, Matrox was always known for having innovative GPU features in the workstation world.
                                  I think I have one or two Matrox PCI GPUs as well. One is a Mystique II, IIRC... though that has nothing special about it.
                                  Indeed
                                  Like many of the other systems under your desk:
                                  https://www.badcaps.net/forum/attach...1&d=1550860363
                                  • Topcat
                                    Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                                    by Topcat
                                    Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                                    Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                                    09-29-2024, 03:55 PM
                                  • Topcat
                                    Asus KFN5-D SLI Kinda Retro-ish Rescue / Build
                                    by Topcat
                                    It's been a while since I've done one....this one has been sitting for a while.
                                    I say retro-ish; as this is all circa 2006. Yes, it's been that long ago!! The motherboard to be used is a KFN5-D SLI that was an ebay rescue sometime early this year...had bad caps; the seller knew it.....and was basically selling it for peanuts + the cost of shipping....and it's not a very common board, so I grabbed it. It has a pair of Opteron Barcelona quadcores @ 2.5GHz; the fastest it can take. This board does not support Shanghai cores. I added 64gb ECC RAM, ECC DDR2 is silly cheap these...
                                    12-05-2021, 09:48 PM
                                    Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                    by momaka
                                    I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                    For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                    https://www.badcaps.net/filedata/fetch?id=3591771
                                    https://www.badcaps.net/filedata/fetch?id=3591772
                                    It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                    https://www.badcaps.net/filedata/fetch?id=359177...
                                    03-12-2025, 03:42 PM
                                  • Topcat
                                    That Apevia Case from the Free Scores thread...Another Time-wasting Retro Build!
                                    by Topcat
                                    To anyone wondering what might become of that Apevia freebie from the other thread......hmmm...maybe this will jog your memory:
                                    Yea, that is a temp gauge....and it seems to work. The sensor is just loose in the case....perhaps it was supposed to be stuck in the CPU heatsink....but ohh well.
                                    Nifty door....with magnetic latches...
                                    It currently has a t-bred XP 2600+ setup in it now.....kind of lame & boring......but I've got the cure for that! I was going to stick a Poly VP6 in it.....but something...
                                    04-05-2021, 04:08 PM
                                  • Dobrowol
                                    Dell Latitude 3520 help with bios build/repair
                                    by Dobrowol
                                    Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                    Steps i done and results:
                                    I exported a clean bios from update file via pfs extract.
                                    1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                    Result: Dead
                                    2. Build clean bios with no changes in ME, new PMC, PCH
                                    Result: Dead
                                    3. Build old bios with clean ME, new PMC, PCH
                                    Result: The same
                                    09-22-2023, 02:43 AM
