Philips 19pfl3505d/f7 - No Power - Voltages drop
  • caphair
    • Nov 2011
    • 1249
    Re: Philips 19pfl3505d/f7 - No Power - Voltages drop
    Originally posted by R_J
    KEY-IN1 goes from CN102 (4) to CN302 (29) Then to CN3702 (29), R3703 (100ohm) then to IC3301 (AC5) [page 57]
    I think you mixed up CN3702 (pin29) KEY-IN1 with CN3701 (pin29) VCOM-PWM
    I don't know how "this tv" works, but sometimes they turn on the power supply at initial power on to make sure all voltages etc are there and ok, then turn it off again and wait for the power on to be pressed.
    Thanks I mixed it up only with identifying the connector. At cn302 pin 29 I get no voltage and no continuity to cn102 pin 4 where there is 3.3v
    Do you see any component in between the two connectors? I can't find any and if there isn't then it's odd that I'm missing 3.3v at cn302
    • R_J
      • Jun 2012
      • 9624
      If you follow it on the board view [page 64] it does connect directly, maybe inspect the plugs and connectors for a problem, sometimes the foil can break or get folded back on those ribbons, also on cn102, make sure a wire did'nt brake or get folded over.
      It could be that all that is missing is the power on command getting to the micro
      • caphair
        • Nov 2011
        • 1249
        There’s no conintiinty at all from the two points of the PCB even with the ribbon and plug disconnected.
        Should I try soldering a jumper wire?
        • R_J
          • Jun 2012
          • 9624
          I would'nt in case you get the wrong pins. there is a continous trace that connects the two pins, place one probe on cn102 pin 4 then with the other probe check the trace, push the probe tip through the coating to contact the foil trace, then follow the trace along the board probing that trace untill you find the open
          Just to make sure we are on the same page
          • caphair
            • Nov 2011
            • 1249
            Ok this is weird, I ran a jumper from cn102 pin 4 to cn302 pin 29 the exact ones you show in the pictures and with the jumper wire the 3.3v goes away this is with and without mainboard connected.
            Soon as I remove the jumper 3.3v comes up. I double checked to make sure it was the right pins and marked with a marker before connecting the jumper
            • R_J
              • Jun 2012
              • 9624
              Is pin 29 shorted to ground?
              • caphair
                • Nov 2011
                • 1249
                #27
                It's not. I even tried diode mode, positive lead on ground and black lead at the pin and it gives an OL reading
                • R_J
                  • Jun 2012
                  • 9624
                  If its not shorted to ground, how can it kill the 3.3 volts? trace that copper trace on your board, maybe it is different that the service manual?
                  • caphair
                    • Nov 2011
                    • 1249
                    #29
                    It's the exact same. I'll try what you suggested by tracing and scraping the trace. Very odd though when I had the jumper all the other 3.3v remained on cn102 only pin 4 went to 0v
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      Wait a minute I checked pin 29 from underside of the board to ground and it appears shorted. If I measure from the top I get no beep to ground
                      Ok so how can pin 29 be shorted if at pin 4 of cn102 the 3.3v is present and the two pins are tied together?
                        Beeping of the meter does not mean you have shorted circuit, the important information is the resistance reading, beeping means you have continuity between two points, your meter will probably beep with resistance as high as 50 Ohms (see your manual).
                        • caphair
                          • Nov 2011
                          • 1249
                          #32
                          Problem solved!
                          Pin 29 was touching the ground pin near it by a whisker or something. I cleaned it up with soldering iron and then redid my jumper from pin 4 of cn102 and tv powered up.
                          So if anyone has this model check that trace it breaks somewhere. For me I’m just going to solder a wire underneath and hot glue it.
                          R_J thanks a bunch for your help on this one. Appreciate it
                          • R_J
                            • Jun 2012
                            • 9624
                            Your welcome, glad I could help. and glad its working.
                            • Thierry Wolffenbuttel
                              Ps5 with bad standby voltages
                              by Thierry Wolffenbuttel
                              I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                              04-08-2024, 08:04 AM
                            • alro7779
                              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                              by alro7779
                              Hello, guys!
                              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                              09-14-2025, 12:25 AM
                            • jasonbay13
                              Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                              by jasonbay13
                              picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                              am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                              12-01-2023, 09:55 PM
                            • Crystaleyes
                              iMac A1224 PSU, 614-0421 - no standby voltages
                              by Crystaleyes
                              Hi chaps.
                              Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                              I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                              Anyway, this PSU in question had already had someone having a pop at soldering.
                              The current problem is (at the very least) in the primary side.
                              Fuse is ok
                              MOV is ok
                              NTC is ok
                              Bridge rectifier is ok (~380vDC)
                              Fat filter cap is ok
                              10-11-2021, 05:07 PM
                            • zwerw3
                              la-g07jp no standby voltages
                              by zwerw3
                              Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                              05-06-2024, 01:01 AM
