Vizio E470VA Logo lights up white but nothing else comes on
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Vizio E470VA Logo lights up white but nothing else comes on
    Sure haven't Tom. I'm at my parents house visiting for the weekend but I'll try that as soon as I get back home tomorrow.
    So this is the up button the remote; as in the menu navigation buttons?
      Sorry. Wrong thread! I meant to post this in the Sony tibimaki is working on.
      • aaronwt6
        • Apr 2013
        • 855
        • US
        No problem. I'm working on getting another board on the way for it.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Well, I have another update for everyone. TV is up and running!! Got a 2nd main board and good to go. Thanks everyone for the help and advice. On to the next!
            Good to hear. Nice to see it working.
            • Daveleone
              Vizio VO42L, white logo, no backlight, no picture
              by Daveleone
              Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
              From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
              I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
              Main board:
              Continuity across...
              02-20-2021, 04:52 PM
            • crewdog
              Hp 15-dy2087nr white lights blinking
              by crewdog
              Board DAOP5HMB8F REV F
              Model OPSH
              No bios battery on board
              Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
              Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
              and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
              Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
              10-25-2023, 03:08 PM
            • Super360
              Vizio E701i-A3 Vizio logo flashing then turns off
              by Super360
              Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
              07-25-2024, 07:06 PM
            • x_orange90_x
              Vizio V555-G1 stuck on wallpaper; now stuck on V logo
              by x_orange90_x
              I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
              12-28-2023, 06:26 AM
            • JaquesPratt
              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
              by JaquesPratt
              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
              07-16-2024, 01:04 AM
