LG 47LD920 Display (not backlight) blinks off every 8 seconds during brighter scenes
    Re: LG 47LD920 Display (not backlight) blinks off every 8 seconds during brighter sce
    No need to re-test PSU, and you can check that fuse voltage on the V=20 range (not 200) to get more digits.
    • Stimpers
      • Dec 2012
      • 37
      Cleaning results:
      No change.
      (Unfortunately, the only ribbon ends I couldn't clean are the pair seen to disappear in the top of this pic.
      It would require alot more dismantling in order to gain enough access to release/refasten the catches safely).
      F1 fuse test results:
      Left side = 11.95 to 11.97. Jumps to 12.15 during blink.
      Right side = 11.94 to 11.95. Jumps to 12.13 during blink.
        This seems like a t-con fault (the board you tested the 12V on), as the voltage goes up, it indicates it draws -less- power.
        • Stimpers
          • Dec 2012
          • 37
          Thanks Tom,
          So just to confirm - it is based on my results from earlier, in your opinion, that the biggest suspect is the power board (t-con), and the spike (drain) detected on the 20v?
          Results:
          8/7 - 5v = 5.2, no change during blink
          10/9 - 5v = 5.2, no change during blink
          14/13 - 12v = 12.3, no change during blink
          18/17 - 20v = 21.1 to 21.2, jumps to 21.3 during blink
          I have sourced a new power board for this rare TV at £130 a pop and 2-3 week delivery time, but I'm happy to spend that if it's very likely to fix it.
          Let me know if you think I should give anything else a try before parting with my cash
            No, I suspect the T-con. The PSU is fine, the slight voltage change is probably OK.
            • Stimpers
              • Dec 2012
              • 37
              Right, derp - so that board is the T-con, and 12v was read off the F1 fuse. Gotcha.
              That's good news, replacement T-con (p/n 6870C-4100D) is more readily available than PSU and AV boards, at only £20 second hand - I'll order one and report back.
              Can't thank you enough man. Selldoor too. T-con arrives Thursday, I'll post back.
              • Stimpers
                • Dec 2012
                • 37
                Hi Tom and all, hope youre well. Any chance you are online?
                I installed the new T-con a few moments ago. No change. How utterly gutting.
                Any thoughts on my next move? I'm pretty desperate to fix this mother asap, by any means necessary.
                A reminder of the PSU results, and the slight drain detected on one pin:
                PSU Results:
                  The change in the 20V is so very slight, and unlikely to be significant.
                  Have you tried heating the AV board with a hairdryer in case it gets worse with heat?
                  My next suspect would be the AV board unfortunately...
                  • Stimpers
                    • Dec 2012
                    • 37
                    Hello.
                    Ah well, at least the AV board is available. Even at £130 ill be happy if it works.
                    Regarding heat, certainly the problem only occurs after te TV has been on for a few mins.
                    Also the time between blinks is precisely the same each time around. I have previously sat there with a lap timer and measured 3.9s, 3.9s, 3.9s etc..
                    On another occasion it will be 8.0s. Seems odd.
                    Heat test in progress..
                    • Stimpers
                      • Dec 2012
                      • 37
                      YES, Tom. Success. Heat does appear to aggravate the problem.
                      On a file that normally threw up 3 or 4 blinks, I just clocked a dozen when pointing an electric heater a small distance from the AV board.
                      I'd like to think this makes it almost definitely the AV board, but is there anything else I should try before chucking £130 at the problem?
                      (The board between the AV and T-con, for example, would also have got quite warm during the test)
                      And I am guessing there's no AV board tweaking I can do for a temp fix in the meantime?
                      Lastly, do you happen to know of any LCD part retailers who might have a 2nd hand board in stock?
                      I have sourced the part new, but its £130 and a 3 week wait. Have also tried calling around, eBay, EMOS, and Reclaim247.
                      Sorry for all the queries, thank you.
                        There is a quick fix you can do if you want to get the TV to last a few months. It is known as a reflow. Used to repair Xbox 360 / PS3 consoles. It is worth a shot. The most common technique is about 2 minutes in the oven at 230C to allow the solder to reflow. If heat is causing a problem, it is most likely a BGA failure (which reflows can fix); this is due to the use of lead-free solder, which is unreliable compared to leaded stuff.
                        I use flattvparts occasionally, and eBay for the rest. Also, are you using the "EAXnnnnnnn" number, or just your TV model? Check around the local area for similar TVs with smashed screens -- boards may be harvested.
                        • Stimpers
                          • Dec 2012
                          • 37
                          Yeah, I've been searching both 'eax62109301', and 'LD920'.
                          Thanks for flattvparts - theyre oos too unfortunately. A rare TV, this one. LG pulled it from retail after 2 months to sell exclusively to hotels, and replaced it with the LD950. Making that that £130 call to LG now!
                          Oven sounds dangerously tempting. Since I have a smaller backup TV, I'm blatantly going to do it, immediately.
                          So, I've preheated oven to 230c. Should I place it inside with tall screws on the corners to keep the board from touching anything (upside down so solder is on top?) , and leave it in for exactly 2mins, before it turns golden brown?
                            Board facing upwards, main processors pointing upwards.
                            230C is best, it is the commercially used reflow temperature. 250C may be too high.
                            2 minutes maximum, some people have experienced warping at 5 minutes and melted puddles at 30 minutes.
                            • Stimpers
                              • Dec 2012
                              • 37
                              lol; 30 minutes.
                              230C, board upwards, 120 seconds. Noted.
                              Christmas cooking take 1. Here goes nothing..
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                Suspense is killing me - got the marzipan and icing ready?
                                • Stimpers
                                  • Dec 2012
                                  • 37
                                  Hi selldoor,
                                  Tom's recipe was an exciting one, so I'm gutted to report that it didn't work!
                                  But as a Christmas consolation prize, the only further damage caused was to my vocal chords. My 'new' second hand TV has been the light at the end of the tunnel of a hectic and mammoth house refurbishment, which I need to complete in the next couple of days. The live crash course in diagnosis and repair has been incredibly useful - but I've set myself back a few days with the refurb, and the stress has been gradually mounting.
                                  Basically, when the TV blinked again a few moments ago it was the straw that broke the camels back, and I let out an anguished inhuman roar, loud enough to scare the noisy kids next door into silence. Perhaps you heard me.
                                  10 minutes later and things are much calmer It won't arrive until mid January, but I've got the replacement AV board on order with option to cancel if I find a second hand one sooner.
                                  • Stimpers
                                    • Dec 2012
                                    • 37
                                    Hi guys,
                                    Happy new year to you.
                                    I guess the AV board isn't the problem. My replacement arrived today. I installed it just now. The problem remains.
                                    So far I've purchased replacement T-con and AV board.
                                    Any ideas?
                                    Yours,
                                    Depressed.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      Well - Happy new year - as you have replaced both boards all I can come up with quickly is that you should try and dismantle further to get at the other end of the ribbon cables.
                                      Thing is I dont know if when you get there they are the sort you can take out and clean or
                                      if they are permanently attached. At least it will be one possible problem less. Its been an
                                      expensive new hobby for you so far
                                        I am almost considering perhaps a software problem?
                                        How does changing things like the brightness settings affect the problem?
                                        Does LG have a firmware update available?
                                        • Stimpers
                                          • Dec 2012
                                          • 37
                                          Hi Tom, Selldoor, sorry for the delay and thanks for responding.
                                          I needed to work on other stuff for a few days, but I'm back.
                                          I've come too far to give up now!
                                          Apologies for the long message, I've been running a few tests and have info I think will be useful.
                                          I previously thought that brightness/frame complexity were affecting blinks. Well, it doesn't. It's colour.
                                          I took a screenshot during a troublesome scene, and by playing around was able to ascertain the following:
                                          • [1] Blinking never occurs when colour is turned down to zero.
                                            As soon as I nudge colour on at all, even at 1%, the blinking starts again.
                                            [2] Blinking always occurs during frames which contain a mixture of colours.
                                            [3] Blinking never occurs on a screen saturated with one colour;
                                            blue, red or green, black or white. Even with brightness etc maxed.
                                            [4] By moving a troublesome colourful screenshot partially off screen in any direction, against a plain background, I can completely prevent the blinking.
                                            [5] Pauses between blinks are identical. However, the pause can be made to vary depending on how high the colour setting is cranked. eg,
                                            -At 1% colour, blink frequency = Every 7.8s precisely
                                            -At 100% colour, blink frequency = Every 4.8s precisely
                                            -Blinks continue at this frequency as colour is turned down, but stop immediately at 0% colour
                                            [6] When blinking occurs, the OSD menu disappears too. But the plain grey menu can be enough to prevent a blink occurring.
                                            [7] A portable heater pointed at the AV board previously led us to believe that the AV board was at fault, as it appeared to increase blink frequency.
                                            However, I am now thinking that I was either
                                            a) wrong about the freq increase, or
                                            b) that the heater was affecting another component.
                                            The TV is currently remounted, but I will take it down again tomorrow and run heat tests on other areas. I will also take the opportunity to check all connections, including the two recessed T-con ribbons which I couldn't reach last time.
                                          In the meantime - what do you think? Tell me I'm not running out of 'next steps'.
                                          See attached photos of scenarios described.
                                          thumbs up = working
                                          thumbs down = blinking
                                          Code:
                                          [ATTACH]55271[/ATTACH]
                                          [ATTACH]55272[/ATTACH]
                                          [ATTACH]55273[/ATTACH]
                                          [ATTACH]55274[/ATTACH]
                                          [ATTACH]55275[/ATTACH]
                                          [ATTACH]55276[/ATTACH]
                                          [ATTACH]55277[/ATTACH]
                                          [ATTACH]55278[/ATTACH]
                                          [ATTACH]55279[/ATTACH]
                                          [ATTACH]55280[/ATTACH]
                                          • Curtissimo
                                            HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                            by Curtissimo
                                            Hi everyone.
                                            I have a HP Elitebook 850 G8.
                                            Serial: 5CG2324XM0
                                            ProdID 6L8D5EC#ABA
                                            It has a Winbond W25Q256JVEN Chip.
                                            I need to remove BIOS Password.
                                            I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                            Attached my dump.
                                            I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                            I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                            What I did:...
                                            08-26-2025, 04:42 AM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            08-11-2025, 02:14 PM
                                          • twonk9098
                                            Lenovo Legion 5 high fan spin turns off after 34 seconds
                                            by twonk9098
                                            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                            I have tried a few new bios but exactly...
                                            07-14-2024, 11:19 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • Strudul
                                            Sharp LC-60LE741E - Horizontal Bands / Stripes
                                            by Strudul
                                            I have a strange problem that appeared suddenly on my SHARP LC-60LE741E 60” LCD television. It has 22 evenly spaced horizontal grey stripes over the entire area of the screen. The stripes only effect dim areas of an image. Blacks are still purely black, and anything brighter than 40% is unaffected. Bright outdoor scenes are fabulous. Dark low contrast scenes ... like all CGI on Netflix are unbearable. It's like your looking through dirty venetian blinds. The grey bars appear above any slightly dark colors. If you look closely, you'll see that there are white pixels mixed in with the correct...
                                            12-20-2022, 06:06 PM
