LG 47LD920 Display (not backlight) blinks off every 8 seconds during brighter scenes
  • Stimpers
    • Dec 2012
    • 37
    Re: LG 47LD920 Display (not backlight) blinks off every 8 seconds during brighter sce
    Originally posted by tom66
    I am almost considering perhaps a software problem?
    How does changing things like the brightness settings affect the problem?
    Does LG have a firmware update available?
    I just deleted a draft response to this Tom, sorry.
    In short; The LD920 is shipped with standard v3.0 software, with no updates available. This is because LG pulled the TV from the shelves to sell to industry (hotels etc) shortly after release.
    The successor, the LD950, has a few updates. One LG USB wiki page suggests that one can use LD950 firmware, but according to 2 users on an AV forum owner's thread, it causes major problems.
    Regardless, my gut says this isn't a software problem. I would be happy to reinstall original firmware just to test, but it's not available anywhere.
      I used to have access to LG's service site with firmware but the trick I used got patched. I'd help you if I could... It may also be possible to use the LD950 main board if the rest of the TV is similar enough.
      • Stimpers
        • Dec 2012
        • 37
        Shame! Ah well. Check that previous post of mine too..
          Interesting that colour affects it. Quite possibly some processor function is having difficulty.
          Have we tried service reset yet?
          MENU key on set and MENU key on remote for 5~10 seconds.
          Then select reset option (may be buried in menu.)
            Also, turn off "XD Engine" and "Sharpness" options, to see if those have any effect.
            • Stimpers
              • Dec 2012
              • 37
              OK, this is weird..
              I can't seem to activate the service menu via any of the 3 standard methods.
              Nothing changes onscreen. I've got another LG, so I know what should be happening..
              Remote batteries are fine. And, by holding down MENU on remote, the OSD does disappear after a few secs, but is not replaced by a service menu.
              Method 1
              Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
              Method 2
              Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
              Method 3
              Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
              • Stimpers
                • Dec 2012
                • 37
                OK, in the meantime I found Factory Reset in the normal menu, but no change.
                This service menu access problem is strange tho..
                Regarding sharpness etc, I experimented with all, on and off. Seems like it's exclusively affected by large amounts of certain mixed colours.
                  Try MENU, 3, 1, 4, 1, 5, 9. People have had luck with that one instead.
                  A geeky LG engineer must have included that one...
                  • Stimpers
                    • Dec 2012
                    • 37
                    MENU, 3, 1, 4, 1, 5, 9.. nothing!
                    what on earth's going on?
                      Have you tried from power on? Unplug TV and hold buttons, then power on.
                      • Stimpers
                        • Dec 2012
                        • 37
                        Tried all 3 methods as suggested, plus MENU, 3, 1, 4, 1, 5, 9. Nothing..
                          I'd say something is up with the firmware or settings then but I wouldn't know how to fix that.
                          • Stimpers
                            • Dec 2012
                            • 37
                            If it's a firmware bug, it only started occurring a few weeks after I purchased it, after it belonged to the previous owner for about 13 months.
                            But admittedly, the fact I can't access the menu is pretty worrying..
                            I found a guide to program a Logitech Harmony remote as an LG Service remote, which has helped a few who had similar problems - I'll give this a try in the morning, along with more heat tests and a more thorough dismantle/connection check.
                            Time for bed now, though.
                            Thanks for your help, Tom. I'll report back tomorrow.
                            • Stimpers
                              • Dec 2012
                              • 37
                              Hi Tom,
                              Been a while, but I've found some spare time. If you don't mind, I have a question. Something happened during my tests this eve.
                              Could a hairdryer be enough to cause a reflow, or to fix a dodgy board?
                              -I put aside some time tonight (and tomorrow) for another diagnosis session.
                              I wanted to prove/rule out your firmware-bug hypothesis, so I ran some more heat tests, this time on the (unknown) board between AV board and T-CON.
                              -Last time, tests appeared to indicate that heating the AV board caused increased blink frequency, so I replaced it. Problem continued.
                              -This time, I wanted to rule out that residual heat may have actually been affecting the nearby (unknown) board between AV board and T-CON, so I tested it with a more focused heat (a hairdryer instead of fat portable heater).
                              -Initially I thought I had success; Blinks every 8s with no heat, frequency increasing to 3.5s after 20 seconds of heat, decreasing steadily to 4.5s after 2 mins with no heat.
                              HOWEVER...
                              I'm currently unable to run further tests - because for the time-being, and for the first time, the problem has completely gone away! All the colourful screenshots I saved, which were previously guaranteed to get the set blinking, are failing to have any effect whatsoever.
                              Its actually frustrating, as I need more demonstrative evidence that this unknown board is the problem. So in the meantime, I wondered if you could tell me whether the heat might have temporarily solved things, as per my opening question.
                              If so, I'll probably order a replacement board at try a reflow with the current one in the meantime.
                              Pic of board attached.
                              EDIT: Just looked at the details on the board, EAX6167901 (3). I'll search for this part now.
                              EDIT: Having trouble finding out what this board is! Google isn't helping. Any idea?
                                Huh. I did not realise this chassis had a second t-con. A picture of the overall layout could have eliminated such confusion.
                                Heat can definitely temporarily repair solder joints, so you can try a proper reflow on that board if the problem returns.
                                I don't know what that board does. I'd take a guess it's some kind of format converter, or perhaps motion interpolation (100/120Hz?)
                                • Stimpers
                                  • Dec 2012
                                  • 37
                                  Post #12.
                                  www.4ourhouse.co.uk got me the AV board last time, hopefully they can trace the mystery board using the EAX number.
                                  Cheers as always, Tom. Thanks for the prompt response, enjoy your evening.
                                    Originally posted by Stimpers
                                    Post #12.
                                    Ignore me. I forgot about that. Hmm, it would definitely point to that board.
                                    • Curtissimo
                                      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                      by Curtissimo
                                      Hi everyone.
                                      I have a HP Elitebook 850 G8.
                                      Serial: 5CG2324XM0
                                      ProdID 6L8D5EC#ABA
                                      It has a Winbond W25Q256JVEN Chip.
                                      I need to remove BIOS Password.
                                      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                      Attached my dump.
                                      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                      What I did:...
                                      08-26-2025, 04:42 AM
                                    • zklgfs
                                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                      by zklgfs
                                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                      08-11-2025, 02:14 PM
                                    • twonk9098
                                      Lenovo Legion 5 high fan spin turns off after 34 seconds
                                      by twonk9098
                                      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                      I have tried a few new bios but exactly...
                                      07-14-2024, 11:19 AM
                                    • Nairolf
                                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                      by Nairolf
                                      I have a Samsung DM32D display.
                                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                      Here’s what I have tried so far:
                                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                      08-24-2025, 03:47 AM
                                    • Strudul
                                      Sharp LC-60LE741E - Horizontal Bands / Stripes
                                      by Strudul
                                      I have a strange problem that appeared suddenly on my SHARP LC-60LE741E 60” LCD television. It has 22 evenly spaced horizontal grey stripes over the entire area of the screen. The stripes only effect dim areas of an image. Blacks are still purely black, and anything brighter than 40% is unaffected. Bright outdoor scenes are fabulous. Dark low contrast scenes ... like all CGI on Netflix are unbearable. It's like your looking through dirty venetian blinds. The grey bars appear above any slightly dark colors. If you look closely, you'll see that there are white pixels mixed in with the correct...
                                      12-20-2022, 06:06 PM
