ASUS A8V-MX cap diagram and some experiments
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Next motherboards on the list: ASUS A8V-MX and MSI MS-7184. I got the two from the same seller on eBay. They were listed as “For Parts or Repair”, and seller even noted that one of the motherboards had bad caps (which the ASUS did… more on that in a bit). I wasn't expecting working boards, though, as there were no visible bad caps on the eBay pictures. But the ASUS turned out to work fine and had only one bad cap.
    Some pictures of the ASUS A8V-MX motherboard as it came to me:
    https://www.badcaps.net/forum/attach...1&d=1499309592
    As seen in the images above, this motherboard uses mostly Panasonic FJ caps. For some reason, however, one of them was just slightly bulged (image 2). I don't remember if I ever tested that cap on my ESR meter or not. But other than that bulged cap, the rest were fine and the motherboard was actually working fine.
    I replaced the single bulged Panasonic FJ 6.3 V, 820 uF cap with a Nichicon HZ 6.3V, 2200 uF cap (10 mm diameter cap from an Xbox 360 motherboard). One might question this choice, as I more than doubled the capacitance. But it turns out the free cap spot above that cap is in parallel with it. So most likely, the original design of this motherboard had way more capacitors than what is seen in the pictures. Thus, doubling the capacitance could not have hurt anything (and it didn't ).
    This is the primary reason why I made cap diagram / cap map: I thought about filling in the missing cap spots at some point in time. So here is the cap diagram:
    Normally, I go through all of the various voltage rails in detail. But since I did not really do any kind of serious recapping work here, I will go over only some of these, and much more briefly.
    #1 and #2 are (as always on my cap diagrams) the CPU input and output sides, with the input being 12V and the output being around 1.4V (i.e. CPU V_core), or whatever the CPU uses for its core voltage. Worth noting is that this is *the only* buck-regulated rail on the motherboard. Everything else is linear-land. So when recapping this board (should you have anything different than Panasonic caps, like Chemicon KZG, for example), make sure to use good quality ultra-low ESR caps for #1 and #2. The rest of the rails don't need ultra-low ESR caps. Just regular low-ESR like Chemicon KY/KZE, Rubycon ZL, and Panasonic FR/FM should be good enough.
    #3 and #4 are the RAM V_dimm and Vtt voltages, respectively (2.6V and 1.3V). The bulged cap was connected to a spot for #3.
    #5 is the 3.3V Standby rail, generated from 5VSB by the 1085 regulator below the bottom PCI slot. (Not sure why I labeled it as “SB STBY”, as I don't think the Southbridge is powered in Standby/Soft-OFF mode. Only the LPC Super IO should be.)
    #6 seems to be the Northbridge and Southbridge Vcc, 1.65 Volts.
    #7 is actually the CPU Vtt / CPU<->NB HTT link voltage. Not sure why I labeled it “NB CTRL”. It is 1.3 Volts.
    #8: USB ports… don't think I need to explain that.
    #9 appears to be some kind of a rail that was never implemented. It might have been part of a multi-step linear regulator, to spread out the heat from the regulation more evenly. After all, it was typical for some ASUS motherboards from this era to have very hot-running regulators. This motherboard, however, does NOT have any. So that's probably why the cap and MOSFET for #9 were left out. Thus, no need to fill up spot #9.
    #A: More filter caps for the various 3.3V and 5V rails on the board.
    Unfortunately, I never bothered to fill in those empty cap spots either. Instead, I shoved the motherboard into a spare PC case (back when I actually had more spare PC cases than motherboards, lol ) and built a PC for random hardware testing / experimentation.
    Worth noting is that this motherboard has both an AGP and a PCI-E 1x slot. And what's even more interesting is that the motherboard has a silkscreen (and the holes) for a full PCI-E 16x slot. So, I've always wondered what would happen if I actually installed a PCI-E 16x slot. Would the motherboard be able to take both AGP and PCI-E video cards? At the same time?
    This intrigued me, so I decided to do some testing. But rather than pulling the PCI-E 1x slot and installing a 16x one (which frankly I think is quite a bit of work and probably too much effort for negligible gains, if any), instead I cut the end of the 1x slot, so it could take a full 16x video card. Because PCI-E is adaptive in nature, the video card should just run in 1x mode instead of 16x. – And it did!
    However, here is the twist: in the BIOS, this motherboard only has the option to use AGP, PCI, or onboard IGP as the first monitor output – no option for PCI-E. As such, adding a PCI-E GPU in the 1x slot will show no output on the monitor until after the OS loads and one specifically sets that GPU to output to a monitor. That said, I was able to configure Windows (XP) to have my test PCI-E GPU (Radeon HD 2400) as the primary and sole monitor output in the system. The only small snag is that when the PC is first turned ON, the monitor remains OFF and nothing appears on it until the OS loads. So if one wants to go into BIOS and change some settings, the monitor will need to be connected either to the onboard IGP or an AGP video card for that. And then when the OS loads, the IGP/AGP video will go out and only the PCI-E one will be active. So accessing the BIOS does require some cable plugging and unplugging. But that's only if the PCI-E video card is used for output. It is also possible to use an AGP video card for one or two monitor outputs, and then the PCI-E for another one or two monitors. Thus, this motherboard is actually not bad in that regard.
    The other notable thing is that this motherboard does have an option to change the Base/Host Clock. However, doing any kind of CPU over-clocking in this way (which is actually how it's done with socket 939 AMDs) makes the motherboard completely hang on POST. And the only way to fix the hanging is to remove the CMOS battery and reset CMOS. This happens even when the RAM is set to run at a slower clock and the HT link is set to a lower multiplier. I even tried setting the PCI-E clock to a “Fixed” frequency (there is an option for that as well). But still, the motherboard refuses to over-clock the CPU even by a single MHz.
    Thus, this is clearly not a good motherboard for over-clocking. However, it is perfectly stable at the stock clocks. So if one needs a simple basic socket 939 motherboard that works, this one fits the bill. It has AGP and PCI-E 1x (which can be opened to take 16x cards), so it is possible to have a mutli-monitor setup. Also, ASUS actually did a good job with the CPU fan control, as the CPU fan can be set to run at a slow and reasonably quiet speed when idle. Once a pre-set temperature is exceeded in the BIOS, that's when the CPU fan can kick in harder (it's user-adjustable, which is really nice to see on an old basic board like this). This is something that many 939 motherboards from other manufacturers lack (that is, unless you bought a high-end gaming board or similar).
    So all in all, it's a good motherboard.
  • Wester547
    • Nov 2011
    • 1269
    • USA.
    Re: ASUS A8V-MX cap diagram and some experiments
    So the bulged capacitor in question was FJ and not FJS?
    I remember you first made mention of the failure over three years ago. That might be the slightest bulge I've ever seen a capacitor exhibit - a neophyte could easily miss that. It didn't vent enough to leak at the top, anyway. Capacitors with truly volatile electrolyte seem to vent either quite noticeably or with a vengeance when they go, both at the top and bottom (think Sacon and KZG/KZJ). Of course I'm not saying Panasonic FJ/FJS is impervious to sudden failure - premature failures aren't non-existent.
    I noticed at the end you deemed it a good motherboard, and I wouldn't dissent to that. However, I'm still wondering if, after all these years, the stigma still persists on the forum that ASUS motherboards should be avoided at all costs due to the dreaded "sudden death syndrome".
    Motherboards don't just quite working for no reason even when troubleshooting methods don't yield any results. Perhaps "ASDS" is limited to certain models. But the notion that all ASUS motherboards (made after a certain point) are more-or-less doomed to failure seems silly, nonsensical, unfounded, and comes across as slightly phobic and biased (I'm not applying that comment to anyone, just making a point). Of course I realize your thread isn't about that at all so I'll leave it at that.
    Now let's hope that HZ doesn't decide to bulge anytime soon, since the FJ before it left such an inspiring status quo to live up to.
      • 31304
      enable the hidden options in the bios.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        I disagree
        https://www.badcaps.net/forum/showth...ghlight=p2-99b
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • Wester547
          • Nov 2011
          • 1269
          • USA.
          *quit working
          I recall Topcat said in another thread that he's seen motherboards of that era fall victim to bad caps. Ironic, considering those boards had interchangeably used Chemi-con LXZ, Chemi-con TM (not TMZ / TMV / TMJ), Rubycon YXG, and Sanyo (Suncon) CG / DX, IIRC (in your case YXG), all good series from good brands AFAIK (but then again, unexpected failures can happen such as the exemplified case of FJs which dried up just sitting in storage). I don't remember the brands of the smaller caps as of the moment but I doubt that they would be causing your issues. Due to rubber bung degradation, any capacitor (without a hermetic seal) can eventually go out-of-spec after 15+ years. Still, the issues you were describing probably point to something else.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Yup, FJ.
            I probably had a memory lapse when I posted in that other thread as the capacitors being FJS. Or probably also the fact that I had pulled some FJS capacitors out of another ASUS motherboard for reuse.
            Well, ASUS motherboards did seem to die a lot more "for no reason" than other brands, especially when considering they typically used good Japanese caps. But I would say this was more relevant only for the socket 462/939/AM2 and 478/775 boards. The general notion (or rumor, if you will) was that they always cut corners on ESD protective devices for the ports, which made the motherboards more susceptible to ESD damage, and thus the main cause behind "ASDS". Looking at this board, I can't say the thinking behind that notion is unfounded - after all, look at how many capacitors and other components are missing on the board.
            On the other hand, I think what also needs to be considered is if the board in question was made for an OEM PC maker, such as HP, eMachines, Gateway... etc. I say this, because it seems that a lot of cheaper OEM PC makers tend to instruct ASUS to cut corners in order to build cheaper boards, hence the possible lapse in quality there. You can see the same holds true for the MSI MS-7191 and MS-7184 motherboards I posted.
            Also worth mentioning is that faulty chipsets could have swayed some people to believe that ASUS ASDS is worse than other boards - after all, the M2N variants were very popular. Having bumpgate-affected chipsets surely did not help their reputation. Meanwhile, the ASUS P5Q motherboards were pretty rock-solid.
            Either way, I never really had any particular bias against any one board manufacturer (not even ECS! ) It seems that they all had their strengths and weaknesses.
            That HZ was actually bulged before - it came from an Xbox 360 that someone tried to reflow on the wrong profile and half of the Nichicon caps on it were slightly domed due to the high heat. But what's interesting is that after those caps cooled down, I could push their tops back down with minimal force, implying there was no high pressure inside. Hence, the bulging was likely due to contents expanding under high temperature rather than electrolyte failure / Hydrogen formation. All of them measured fine on ESR and capacitance back then (2012) and still did a few years afterwards when I tested them prior to reforming about a year and half ago. Also not the first time I used bulged Nichicons from that motherboard for a repair. So far, it seems all of them have been holding up fine.
            Lol, now where's that "playing with fire" smiley?
            I guess I will use this one instead:
            How?
            Some online research points to BIOS reflashing (which I am not a big fan of, unless I need it to resolve a problem), while another website suggested pressing "Ctrl" + "F1" or "Alt" + "F1" or "Shift" + "F1" while in BIOS.
            Any clues?
            Originally posted by pfrcom
            Interesting failure there. Not sure how I misted that thread.
            Looks like it might be a bad CMOS chip (not to be confused with a bad BIOS chip!)
            Also, old boards like that almost never failed due to BGA-related issues, so a reflow should have never been done.
            But I suppose it's all a moot point now.
            • Wester547
              • Nov 2011
              • 1269
              • USA.
              Intel allowed many 865-series Foxconn motherboards to die a similar death with the dreaded ICH5 southbridge which lacked ESD protection.
              Yes, particularly eMachines/Gateway, which used the cheapest components possible when building to contract.
              MSI and ECS also made several boards whose northbridges used chipsets that were prone to "bumpgate" failure.
              What an irony that the one which bulged right away soldered (yes, pun intended ) on, but those that bulged later on in storage did not survive. The depolarizers were weak with those ones.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Perhaps I should clarify: the HZs that I had bulge in storage (mind you, only 3 or 4) had a 2005 date code (week 40-something, IIRC), whereas the overheating-induced bulged HZ above has a 2006 date code. So I think that's what makes the difference here.
                In my stash of caps, I also have one Rubycon MCZ 16V, 1500 uF (again, out of an Xbox 360) that I accidentally put in a circuit in reverse polarity. The cap bulged. But due to low currents in the circuit where I had it, it did not vent at all - not until I punctured it. Then, after releasing the excess gas, I pushed the vent back down. The cap still retained its specs even a year after that. Then I decided to hot-glue the vent to seal it a little better. Did that maybe about a year ago. Guess what? - That Rubycon MCZ cap is still in spec in terms of ESR and capacitance.
                And it is not fooling my meter either: I can charge it to 15V and discharge it rapidly on a metal surface with considerable pops and sparks for its capacity (when compared to an equivalent 1500 uF cap at the same voltage).
                Now that's a cap that deserves my respect.
                • Wester547
                  • Nov 2011
                  • 1269
                  • USA.
                  Not sure about that... this eBay listing shows some vented and leaking HZ. Although it's very hard to tell from the picture (I could be wrong, one may need X-RAY vision ), I think early 2006 datecodes are visible on the HZ and HN if you look very carefully. The issue may be that the oxidizers in the electrolyte are not always 100% successful in absorbing excessive hydrogen or precluding water-driven corrosion, which is why some may arbitrarily bloat a la KZG and KZJ.
                  I guess this is why VRM output failures are more commonplace than VRM input failures - the low voltage, very high surge currents and high ripple current applications seem to be killer. The internal heating brought about by high amounts of ripple current is more likely to cause an electrolytic to vent than external heat such as high ambient temperatures, especially considering both reverse polarization and very high ripple current loads form the cathode foil (the latter at a slower rate) which generates hydrogen gas. That said, higher ambient temperatures will still accelerate all such failures.
                  MCZ, despite their sensitivity to heat, are good capacitors. One should not underestimate them. Perhaps my memory is faltering on me, but I recall you said five years ago that one of the 1500uF 16V MCZ you reverse polarized had formed permanent gas inside - IE, it was hard as a rock and you couldn't push the top back down.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Not buying it. :\ (Pun intended, too.)
                    Nichicon HN and HZ caps with 2006 and later date codes are definitely good and you won't see them fail on their own. You'd be hard-pressed to find a board with so many bloated like the above one. Most likely the caps on the above board were overheated due to someone trying the towel "trick" or some equally stupid idea (oven bake ). And given that the Xbox 360 board above comes without anything else, I think we can be certain that some idiot already tried to reflow these and failed.
                    Well in my case, the MCZ vented due to reverse polarity. The only thing that saved it from venting violently was a 10-Ohm resistor that limited the current quite a bit. After running my circuit for a few moments, I noticed that the cap was very hot and just started to bulge. I quickly disconnected power, but the cap continued to bulge until it vented.
                    That was a blue Panasonic GP cap from a TV board. Popped that one in the same circuit that popped the MCZ. After sitting many years on my shelf, that Panasonic cap has finally lost the pressure inside, and if I remember correctly when I last checked it, it was reading okay on capacitance and ESR again.
                    • Wester547
                      • Nov 2011
                      • 1269
                      • USA.
                      Well, only the HZ are bulging on that board. The rest of the capacitors, HN included, appear fine. Boards that are "oven" reflowed (as a whole) for too long usually show more signs of thermal duress, such as severely darkened electrolyte and discoloration on the SMD FET pads (from orange to brown). And there have been sightings of prematurely failed HM made after 2005:
                      https://www.badcaps.net/forum/showpo...69&postcount=4
                      https://www.badcaps.net/forum/showpo...9&postcount=20
                      Of course, only a handful of failures don't mean much.
                      In the duration of the endurance tests at the factory, so as to make certain the peak voltage does not exceed the rated voltage, capacitor manufacturers tend to use 1000Ω resistors in series with the capacitors. They also use such resistors to limit the current during reverse polarity tests (to test the functionality of the pressure-relief vent). The hydrogen gas that escapes quickly enough to rupture the can does get very hot, around 100ºC.
                      Here is the post you made about the 16V MCZ venting. You noted it was hard as a rock. Or was that another one?
                      So it was the Panasonic M 85ºC series? Impressive that there wasn't permanent pressure build-up inside. If it had been a Teapo or CapXon, OTOH...
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3266
                        • Singapore
                        we probably already mentioned this in a pm, but i'd like to state it in public for the benefit of other members and newer members.
                        the reason why overclocking doesnt work is because its a rev1 board from the photos. only asus' rev2 of those via chipsets had working pci/agp/pci-e locks. so even tho the pci-e clock is set to fixed in the bios, it doesnt work... if u run the pci-e clock signal pin through an oscilloscope, i bet it wont show the pci-e clock as running at 100mhz.
                        so if u want an asus via s939 board for overclocking, make sure its rev2 so the frequency lock works and u can overclock to your heart's satisfaction. *starts playing benny benassi's satisfaction song*
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Interesting.
                          I don't recall reading that in your PMs, so definitely good to have this info here.
                          I suppose the only thing I can do with that mobo is look for a more powerful CPU... which shouldn't be a problem. I now have two spare Athlon 64 3500+ chips and one 3700+. If voltage control works with CrystalCPUID, I may be able to get some really cool temps with these CPUs, if nothing else.
                          Ha! Been a while (maybe a year) since I heard that one. Time to play it on my headphones
