Macbook Air 820-00165 BIOS
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    clear me bios for this board
  • philsurmac
    • Nov 2016
    • 6
    • France
    Re: Macbook Air 820-00165-A schemati and boardview
    Thanks highpulse
    I'll try next time so
    What is clear me ? Never used one..
    What is it for ?
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      clear me are only used if you have region problems , such as highspeed fans , slow computer , random shutdown , and also remove password on bios
      • philsurmac
        • Nov 2016
        • 6
        • France
        Ah ok thanks I'll have a look theb
        • lorenzo91
          • Sep 2014
          • 5
          • San Marino
          WTF thanks highpulse!
          • sajan gurung
            • Sep 2014
            • 12
            • nepal
            @highpulse is it possible to remove EFI lock in 2013 MBP by reflashing BIOS??? THanx...
            • techman1025
              • Jun 2014
              • 497
              Hi
              A clean me region will not remove efi password...If you have a dump with a efi password upload it and i will remove it and i will tell you whats needed to be done next so the cloud don't reset it again. The other way to remove a efi password is with a donor bios so let say it a 8mb file the top have 4mb is merged with the bottom half of the donor and all you need to do after is replace the serial to match the original. I have a way to do it with out touching the original file i just remove password .
              Techman1025
              • sajan gurung
                • Sep 2014
                • 12
                • nepal
                so... will send u the original dump file.... wait
                • sajan gurung
                  • Sep 2014
                  • 12
                  • nepal
                  @techman1025 so... will send u the original dump file.... wait can i use regular TL866CS programmer to backup the original dump??? thanks...
                  • techman1025
                    • Jun 2014
                    • 497
                    Hi
                    I use the TL866A with the correct adapter .
                    Techman1025
                    • sajan gurung
                      • Sep 2014
                      • 12
                      • nepal
                      and here it is... @techman1025 my dump... couldnt find right adapter and had to jumper pins to get dump
                      • techman1025
                        • Jun 2014
                        • 497
                        Hi ok Password removed butyou need to follow these steps nexted to complete the process and you will be total good no need to do anything else.
                        Make sure to do this steps after reflash: Unpack zip
                        Resetting NVRAM
                        i) Shut down your Apple Mac.
                        ii) Locate the following keys on the keyboard: Command, Option, P, and R.
                        iii) Turn on your Mac.
                        iv) Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
                        v) Hold these keys until the computer restarts and you hear the startup sound for a second time.
                        vi) Release the keys.
                        And after that... reinstall the OS!
                        Techman1025
                        • techman1025
                          • Jun 2014
                          • 497
                          ok file cleaned..follow step after you reflash....if not the cloud will reset it.
                          Resetting NVRAM
                          • techman1025
                            • Jun 2014
                            • 497
                            Hi ok all cleaned ...you need to follow these steps NEXT so the cloud won't reset it self .
                            Steps after clearing P/W
                            1. Shut down your Mac.
                            2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
                            3. Turn on your Mac.
                            4. Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
                            5. Hold these keys until the computer restarts and you hear the startup sound for a second time.
                            6. Release the keys.
                            nexted do clean install on OS
                            techman1025
                            • ytsoc
                              • May 2014
                              • 67
                              • romania
                              techman, can you help me to remove the password from this dump?
                              • djedumolina
                                • Oct 2017
                                • 5
                                I have a MBAir 4,1 which is EFI locked... is it possible to get a help here?
                                • techman1025
                                  • Jun 2014
                                  • 497
                                  Sorry for the late reply follow these steps now and you won't have any problem bios is clean now.Make sure to do this steps after reflash:
                                  Resetting NVRAM
                                  • andrew_puma
                                    • Jul 2018
                                    • 14
                                    • moldova
                                    Resetting NVRAM
                                    Hello, I forgot my efi password. Programmed Your file. Your dump I inadvertently deleted. Now I don't know what to do. Can't install mac os. Hangs on loading.
                                    What to do?
                                    • techman1025
                                      • Jun 2014
                                      • 497
                                      Originally posted by andrew_puma
                                      Hello, I forgot my efi password. Programmed Your file. Your dump I in advertently deleted. Now I don't know what to do. Can't install mac os. Hangs on loading.
                                      What to do?
                                      So are you all good now?
                                      Techman1025
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
