Yamaha HTR-6130 - Blown "front" channel
  • mattpd
    • Oct 2012
    • 302
    Re: Yamaha HTR-6130 - Blown "front" channel
    Originally posted by budm
    The group of 4-pin are the relay contact, the group of 2-pin is the relay coil, so just check the DCV on those two pins when the unit is on.
    Picture of the relays? There will be coil Voltage rating printed on top of the relay.
    Hard to get a pic of the relay tops. They read:
    981-2A-24DS
    3A 125VAC
    5A 50VAC
    SP7 814L
    Using the case as a common ground, I measured the 2 coil pins on each relay.
    I get 11.8v on one pin and -11.8v on the other for relay 101, 103, and 105.
    On relay 104 and 102 I get -11.8v on both coil pins.
    Not sure how to interpret that.
      You have to measure at those two pins of the relay to read the Voltage on the coil, do not use chassis GND, we are trying to read actual Voltage on the coil, the coil is rated at 24VDC.
      relay spec. 981-xa-xx
      • mattpd
        • Oct 2012
        • 302
        Gotcha.
        101, 103, and 105 all have -24v at the coil.
        102 and 104 have 0v.
        From the block diagram it looks like the coil voltage comes from IC101, which is one of those Sanyo amplifier chips. Should I try to replace the IC? It's kind of expensive but worth it if it fixes it.
        • R_J
          • 9623
          On relay RY101,3,5 You have -12 on pin 6 of the relay because it is directly connected to the -12 volt supply, You have +12 on pin 1 because Q121 (ry101) is turned on connecting the +12 volt supply to pin 1 giving a total of 24 volts accross the coil activating it
          On RY102,4 Q122 (ry102) is turned off, so you have -12 on pin 6 of the relay and with no current flowing through the coil there is no voltage drop so -12 on pin 1 also.
          looks like (RY102) HPRY is the "headphone relay" on/off and (RY104) MRYB is the main speakers "B" on/off
          try turning on speaker b and seeif the voltage across ry104 changes, looks like there could also be a headphone on/off in the menu
          Ry101 connects speaker front a L/R to the amp signal, RY104 connects amp signal to headphone jack
            Relay coils are not DRIVEN by the Audio power amp IC, look at the schematic how the relay coils are being driven.
            • R_J
              • 9623
              Looks like the relays are used for signal routing and (maybe not) protection
                Originally posted by mattpd
                Gotcha.
                RY101 is for speaker front A L & R so you should have should have sound on set A speaker L and R. So are you sure RY101 is ON or not?
                • R_J
                  • 9623
                  I would suspect IC101, as long as there is audio signal getting to the ic (not being muted for some reason), a scope would come in handy for this, I would bet -50 and +50 are on the pins 1,2 and 3,8 I would check pins 18,19 & 4.5 they should be 0 volts or very close to 0.
                  If you can find Q103 & Q104, make sure they have around -12 volts on their bases and 0 on e. & c (they are muting transistors by the looks of it)
                  • mattpd
                    • Oct 2012
                    • 302
                    My mistake. I can get 24v on the coils of 104 if I switch speaker selections. But still no sound output even with "test all" tones playing.
                    Still nothing on coil RY102 (head phone) but maybe it's because I don't have headphones connected?? Not too concerned about that.
                    So even when 101 coil is energized, no output out of Front A L/R and with 104 energized no output from Front B L/R.
                    Center and Sur L/R continue to function.
                    • mattpd
                      • Oct 2012
                      • 302
                      I can confirm that RY101 coil has 24v, "test all" test tone is playing, volume is maxed out, speaker is connected to Front A, and still no sound.
                      And nothing front Front B either, when RY104 has 24v at the coil.
                        As RJ suggested, find out if you do have audio going in to the IC or not.
                        • R_J
                          • 9623
                          The audio for front L/R "A" and for front L/R "B" come from the same audio output IC (IC101) Follow the front left signal path in the schematic and you will see that it is supplied to pins 2 & 5 of RY102 & RY104, then it is switched by them to feed either "A" or "B" speakers
                          Find C1002 & C1003 and with the amp on, hold a small piece of bare wire or use a small screwdriver (while touching the shaft with your finger) and touch the - side of the capacitor and see if you get any hum through speakers front L or R
                          • mattpd
                            • Oct 2012
                            • 302
                            IC101 replaced and the problem is resolved.
                            Sorry for not taking the extra steps you guys suggested. I was getting fed up with this thing and just decided to swap IC101.
                            Thank you both!
                              Glad to hear.
                              • petehall347
                                • Jan 2015
                                • 4448
                                • United Kingdom
                                #35
                                good job ..well done
                                • rustinjust
                                  Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                                  by rustinjust
                                  My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                                  The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                                  It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                                  I have to turn the tv off and then on again with...
                                  09-28-2023, 12:23 PM
                                • HelpMeRepair
                                  Yamaha RX-A3010 left channel no signal
                                  by HelpMeRepair
                                  Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
                                  what I did so far ,
                                  factory reset
                                  test all other channel
                                  tone test
                                  dissasemble and look , visual inspection witout full dissasembly
                                  looked at all the mosfet for temperature to see if they eas operating
                                  scratch my head couple of time
                                  thanks in advance all help is appreciated , service manual are welcome too ! =)...
                                  11-14-2024, 02:48 PM
                                • xfreakx
                                  Yamaha XP7000 Crackling in left channel
                                  by xfreakx
                                  Hi guys,
                                  I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
                                  The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
                                  While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
                                  I switched the mono blocks for a test to make sure the error is in the block itself...
                                  06-29-2023, 05:30 AM
                                • cmlewis89
                                  LG 47LB5DF blown power supply board
                                  by cmlewis89
                                  Hi folks,
                                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                  09-03-2024, 07:50 PM
                                • sima112
                                  Marantz pm 6005 right channel not worknig
                                  by sima112
                                  Hi guys,
                                  I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                  01-30-2023, 12:11 PM
