Flash mxic mx25l640E with Ch341 not recognized
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Can anyone help me to identify why the programmer is recognized well without
    Introducing the memory... but as soon as I
    Put the (well soldered I think) chip in the programmer as in the picture the red led turns off and not recognized at all....
    Think pin1 is well oriented
    Soft supports the chip and programmer too.
    Does it need a mod to 3.3v or this is nonsense?
    Thanks a lot in advance.
    Marcelo J
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Flash mxic mx25l640E with Ch341 not recognized
    I'm pretty Sure this one works with 3.3V. So what is left... replace the SPI Flash and See whether it helps.
    FairRepair on YouTube
    • Zibbo
      • Mar 2017
      • 205
      • Zimbabwe
      You have inserted the board in the programmer wrongly. Pin 1 is in the opposite direction
      • marce002
        • May 2018
        • 316
        • Argentine
        Hello .. pin 1 in chip soldered to pin 1 on the board why do you say is wrong... look:
        You are prety sure need 2 replace the spi ?? Do not understand... is the only one that i have.why replace?
        Marcelo J
        • diif
          • Feb 2014
          • 6978
          • England
          The chip is on the PCB correctly but the PCB needs rotating 180 degrees.
          • marce002
            • May 2018
            • 316
            • Argentine
            Ok.. saddly rotated like this and does not work... placed ok, on 25L eproms area too... still red led turns off after plugin in usb ... so not detected.
            Marcelo J
            • Sephir0th
              • Oct 2020
              • 1289
              I didn't noticed this before. Good eye @zibbo
              @marce002
              You probably Killed that IC by inserting it in the wrong direction. I believe now you have No other choice than Order an replacement...
              • marce002
                • May 2018
                • 316
                • Argentine
                chip is: MX 25 L 640E ZN I 12 G
                so it is:
                8-WSON 8*6mm 64Mb and 3v
                no need to do anything strange like 1.8v or 3.3 mod or void pin 8 and that stuff right?
                Marcelo J
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  Sephir0th placed back in board and seems to be operating fine because loading OS so do not think it is burned.. any other suggestion ...
                  Macbook a1466 3437 efi of my own. That is what i try to read and write
                  Marcelo J
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    have you tried any other spi with the ch341 programmer ? your programmer may not be compatible.
                    I'm not happy to be so strong. because it's not humanly
                      • 21973
                      Have you checked to see if you need the 3.3V mod https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod .Its also worth resoldering all caps,resistors and pins on the CH341 chip.I have 3 of these and 2 were DOA.
                      EDIT: try it with some alternative software as well
                      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                      https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        Thks sametbey it may not be compatible then.. .. weird thing is that in the specs this memory is listed as compatible.
                        Marcelo J
                        • marce002
                          • May 2018
                          • 316
                          • Argentine
                          yes sametbey I have tried other spi with the ch341 programmer ,,,, i have just read mxic 25L8006E ok
                          thanks SMDFlea I m going to your post to analyse it ..but remember that have No LED after plugin so not a soft issue.
                          Will go 4 the 3.3 mod .thanks again
                          Marcelo J
                          • marce002
                            • May 2018
                            • 316
                            • Argentine
                            Mmmm really If I was succeeded with 25L8006E I wonder why should I do any mod.... they seem to required identical parameters (Volt) to be programmed,,,, maybe I soldered wrong to the board... i will try again. and post
                            Marcelo J
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              I would just like to know WHY the ch341a red led turns off when inserting that specific 25L memory, like if it would shorted..... any other non 8wson works fine
                              Marcelo J
                              • marce002
                                • May 2018
                                • 316
                                • Argentine
                                ok finally red led ok, no short but sitll not detected and forced read only reads nulls,,,,,soft i tried AsProgrammer, CH341A Mini Programmer (Black Edition) By_NSC and colibri
                                end for now, if anyone have another suggestion thks
                                PD
                                Maybe I meed an 1.8V adapter to flash this kind of 8WSON Mxic memory, is it?
                                but data sheet says 2.7 to 3.6 volt for read
                                GENERAL
                                • Single Power Supply Operation
                                - 2.7 to 3.6 volt for read, erase, and program operations
                                Marcelo J
                                • marce002
                                  • May 2018
                                  • 316
                                  • Argentine
                                  Re: Flash mxic mx25l640E with Ch341 not recognized **SOLVED**
                                  ok finally worked fine!!!, forget all the stupid questions regarding mods and the 1.8v adapter since it is a 3.3 vol chip..
                                  PROBLEM WAS : have not wson8 adapter so i had to manage the placement in the adapter that I have, and the CH341 detected the chip fine, read and write ok!!
                                  thanks to all
                                  /closed/
                                  Marcelo J
                                  • chazzo
                                    CH341 programmer advice, including jumpers seemingly reversed
                                    by chazzo
                                    I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                                    [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                                    I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                                    10-12-2025, 08:15 AM
                                  • what_1282105
                                    Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                    by what_1282105
                                    Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                    02-14-2025, 07:27 PM
                                  • ekozeko333
                                    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                    by ekozeko333
                                    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                    🔥 The Problem Started After Suspected ESD/PD Fault
                                    I experienced a power issue or ESD event through a USB-C charger
                                    After that, the NX20P5090 power switch was visibly burned and was replaced
                                    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                    🧠 What I’ve Done So Far
                                    Flashed...
                                    06-21-2025, 02:48 AM
                                  • corrize
                                    Nikon D800 camera - flash don’t work and capacitor don’t charge
                                    by corrize
                                    Hello, I'm stuck in troubleshooting…
                                    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                    10-01-2022, 10:02 AM
                                  • Sparklingx
                                    Everyone is buying the wrong CH341 programmer
                                    by Sparklingx
                                    Everyone is buying the wrong CH341A programmer, I have learned from my mistake. Don't buy the Black one or Green one.
                                    Buy this one in the photo. Most stable and all your common problems (reading but not writing/erasing, software hanging, disconnects after attaching chip, test cable connected but chip not found/ device disconnected) will be gone.
                                    Otherwise you'll have to solder capacitor from GND to VCC if you have those symptoms in your black or green miniprogrammer....
                                    09-11-2024, 02:03 PM
