Asus X751LD no Power
  • Trailoard
    • 8
    I have no Power no LED´s
    There are 19V before first fet but no voltage (swapping between 100mV and 200mV) on Gate.
    Checked the two dc-in fets with multimeter from Drain to Source and it seems all ok.
    But the fet on the second picture has 30 Kohms in one way and 250 kohms in the other... Is this one shorted?
    How can I check the capacitor marked in picture?
    On bq24735 I have 18V? on VCC, 6V on REGN and 2.6V on ACDET.
    Got 0.4 V on several pins for battery?
    Or is it some other problem?
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Asus X751LD no Power
    The BV and link HD image
    https://drive.google.com/file/d/0B2s...ew?usp=sharing
    • piernov
      • Jan 2016
      • 4439
      • France
      The capacitor must not be shorted and that's all.
      Also check gate-drain and gate-source on both MOSFET (next to the circled capacitor).
      The MOSFET circled in the second picture is for working on battery voltage, doesn't matter here, several kiloohms is not a short.
      On the other hand we can clearly see a burnt mark on resistor marked 100 right next to the circled capacitor. Check the resistance across its leads, but I guess it will need to be replaced.
      • Trailoard
        • 8
        Yes, you are right... The resistor need to be replaced. I measured 2 kohms not 10 ohms.
        I also tested gate-drain and gate-source on both Mosfets... I´m not sure about the second one... I will replace it as soon as possible and post the results here.
        Thanks first for the quick reply
        • booba
          • 8
          • romania
          Check that 10 ohm resistor, it suplies the chrg chip, resistor its blown due a short after it
          • Sephir0th
            • Oct 2020
            • 1289
            Last edited by Sephir0th; 01-18-2021, 09:25 AM. Reason: Overlooked that the IC is working fine.
            FairRepair on YouTube
            • pascalou95370
              • Nov 2022
              • 5
              • France
              On ASUS X751LD the fan does not spin?.
              I'm looking for the fan power diagram.
              thank you
              • mon2
                • Dec 2019
                • 14657
                @pascalou95370, you should start a fresh thread for assistance.
                You have no power to this Asus ?
                • pascalou95370
                  • Nov 2022
                  • 5
                  • France
                  hello,
                  Thank you for your answer, I don't know on which post I should ask my questions?.
                  I am French and I have a little trouble with the English language.
                  The ASUS pc works great, but the fan doesn't spin
                  the computer heats up.
                  I recall that fan works on another pc.
                  • mon2
                    • Dec 2019
                    • 14657
                    It will be easier for future readers to follow if this case is a fresh thread.
                    Goto your bios, can you read the cpu temperature?
                    If the fan is not defective but still off, then the temperature sensor may be defective or unable to measure the cpu temperature.
                    • pascalou95370
                      • Nov 2022
                      • 5
                      • France
                      I want to go to the right topic, but I don't understand English.
                      for the temperature sensor, I don't know where it is, that's why I'm looking for the diagram.
                      this would allow me to follow the power supply of the fan and its temperature sensor.
                      • pascalou95370
                        • Nov 2022
                        • 5
                        • France
                        Asus x751ld
                        I am French and use tranlate to make myself understood.
                        Fan not spinning?
                        It is functional on another PC.
                        I'm looking for the circuit diagram that powers this fan.
                        If anyone could give me some information on this error.
                        The pc works, but heats up and the video becomes unreadable.
                        thank you.
                        pascal
                        • mon2
                          • Dec 2019
                          • 14657
                          What is the cpu temperature in the bios?
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • ShadowAi
                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                            by ShadowAi
                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                            03-15-2024, 10:46 AM
                          • meraklinetx
                            Asus Z97-a power cycle, no boot no cpu voltage
                            by meraklinetx
                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                            05-10-2023, 06:08 AM
