Post help identifying capacitors here
This is a sticky topic.
  • rattlesnake
    • Dec 2017
    • 78
    • Argentina
    #121
    Re: Post help identifying capacitors here
    " LF 680 e 672 " (e or 0?)
    I think this one is 680uF but what is the voltage? And how do you guess? Diameter is 7.8mm
    • andrewsawesomr
      • Jun 2022
      • 101
      • United States of America
      #122
      Like you said, this is a 680 uF polymer capacitor.
      From the LF and a little bit of searching, we can find out that this is a Nichicon LF series capacitor (datasheet here).
      When we look at the datasheet, on the first page under "Dimensions" we can see a breakdown of the meanings of the markings on the capacitor. From the "voltage" table next to the markings explanation, we can see that an "e" voltage code signifies a 2.5 volt capacitor.
      Now we can look at the second page with "Standard ratings". You can determine the exact capacitor you have by measuring the height with calipers or a ruler. Depending on the dimension, you will be looking for a replacement Aluminum Polymer capacitor with (9mm height) an ESR of 7 miliohms or lower and a ripple current capability of 4800 miliohms or higher or (12mm height) an ESR of 6 miliohms or lower and a ripple current capability of 5700 miliohms or higher. Let me know if you have any additional questions.
      • rattlesnake
        • Dec 2017
        • 78
        • Argentina
        #123
        That's very detailed, thank you very much!
        I couldn't find this datasheet on Google. Did you look for it on a specific website or did you already know LF was related to Nichicon? Any more tips would be appreciated.
        About the ripple current, for computer motherboards, computer PCI cards, etc, is lower ripple the most desirable? I mean, doesn't that give you a cleaner signal?
        Is ripple always related to height? more height = higher ripple?
        Thanks for bearing with me.
        • andrewsawesomr
          • Jun 2022
          • 101
          #124
          I tried "Nichicon LF datasheet" as a search result since Nichicon is a large brand in the Aluminum Polymer capacitor space. However, you would be able to get to the same datasheet by searching "LF Polymer Capacitor Datasheet". The format of the capacitor code also made me think it was Nichicon (you can get an idea of the formatting by looking at the non-FPCAP Polymer Capacitor Datasheets on here [e.g. Nichicon [polymer] CF series.pdf ]).
          The key with ripple current capability is that it is ripple current capability. This indicates how much ripple current the capacitor can handle in the input, not how much ripple current is in the output. Bigger capacitors of the same capacitance and voltage in the same series can generally handle more ripple than smaller capacitors of the same capacitance and voltage in that series.
          Let ne know if you have any further questions.
          • RDRTech
            • Aug 2023
            • 3
            Wondering if anyone can help identify this component.
            It is out of a Yamaha Golf Cart charger JW9-82107-03.
            My best guess is a capacitor of 2200pF, or some sort of varistor. I can not find any info online for the marking. It reads a resistance of 3.5 ohms and causes the fuse to blow when in circuit. It sits across a relay contact on the 120V AC side before the main input capacitor. See Pic.
            Thanks!
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              #126
              Thanks!
              That's a standard 2.2 kohms thermistor . When I say standard , I mean it's difficult to identify the maker , so you need to find a similar maker while putting in search "2.2 kohms thermistor".
              Thermistors cannot be measured because they are thermistors , and they depend on temperatures which is a variable . There is some specialized eq. to test them , but that's another story ..
              • RDRTech
                • Aug 2023
                • 3
                Thanks for the info, I will see what I can find and give it a shot
                • alokoko
                  • Jul 2020
                  • 2
                  • TR
                  #128
                  I need to identify the voltage rating of a surface mount electrolytic capacitor. The PCB is from the handset unit of a cordless phone. There are two capacitors with that form factor on this PCB and they have the following markings:
                  UCL
                  100
                  6v ('v' has a bar on top)
                  330
                  4S.
                  L54
                  I was able to identify the second one using this datasheet: https://cdn.badcaps-static.com/pdfs/...8808eb3b08.pdf
                  As for the first one, I thought it was a Nichicon UCL series capacitor but the markings do not match what is in the datasheet: https://cdn.badcaps-static.com/pdfs/...aa6f7b9d47.pdf
                  The UCL datasheet indicates 'V' is used when the capacitor is rated for 35 Volts but such indication would be next to the capacitance value. If I interpret it as '6 volts', then I can't figure out the significance of the bar above the letter 'v'. This is an old product and maybe there's an older datasheet that describes this particular notation but I couldn't find it.
                  Then I thought "maybe this is also a Panasonic capacitor and UCL is just the lot code" and I went through many Panasonic datasheets (available at the EU Mouser site) but I couldn't find one that exactly matches the "6v with a bar on top" indication.
                  I appreciate any help that anyone can offer at this point.
                  • 1234567v14ada
                    • Oct 2023
                    • 3
                    • Turkey
                    #129
                    Hello, i have a capacitor(?) that is gone in my Lenovo V14 ADA type 826C and i want to know what it is in order to buy a replacement.Thanks.
                      • 21853
                      You havn`t circled or marked anything,so no idea which one you mean.Anyway,you can find it with the schematic and boardview
                      https://www.badcaps.net/forum/showthread.php?t=99843
                      • 1234567v14ada
                        • Oct 2023
                        • 3
                        • Turkey
                        #131
                        my bad, I was specifically looking for this.
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          • USA, Unsure of Planet
                          #132
                          If the reference designator "F2" refers to that component, it is a fuse.
                          PeteS in CA
                          • JonnyKillu
                            • Aug 2021
                            • 2
                            Can anyone help me identify these missing capacitors from this ps4 1200? Thanks
                            • chunk69
                              • Dec 2023
                              • 8
                              • United Kingdom
                              #134
                              Hi friends,
                              I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
                              Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure.
                              The caps appear to be 'Kuang Jin', branded with a 'CS' logo, and has '2200uF 10V +105*C' printed on the side. The only other code shown on the cap is '0303M' - I haven't quite figured out what this means yet.
                              Now, without being able to track down a datasheet, i'm not entirely sure what to replace them with. I found some datasheets here - https://paullinebarger.net/DS/CS%20%...uang%20Jin%5d/ - but i'm struggling to identify which type they are.
                              Appreciate any tips here, i'm fairly new to the capacitor replacement game and keen to learn how to identify appropriate replacements, as I have many others to do.
                              Original thread: https://www.badcaps.net/forum/genera...citor-from-psu
                              K.​
                              • caseysam
                                • Jan 2014
                                • 7
                                Respectfully request help identifying 4 missing components on a 2019 21.5" iMac board. Not worried about the Bios/EFI chip.
                                iMac 19,2
                                A2116
                                EMC 3195
                                MRT32LL/A*
                                Board # 820-01237-A
                                Attached is a photo of missing components.
                                Thank you.
                                • stenio
                                  • Sep 2023
                                  • 10
                                  • Italy
                                  #136
                                  I tried to find the manufacturer of this cap from the logo but I found nothing. Any idea?
                                  Click image for larger version  Name:	20231222_081740.jpg Views:	0 Size:	175.1 KB ID:	3166460
                                  Thanks,
                                  Stenio
                                  • thinkfast76
                                    • Mar 2017
                                    • 46
                                    • italia
                                    #137
                                    Hi all
                                    I have a Macbook Pro A1502 that has orange light on the power connector but no sign of life
                                    Hi, I need to replace the capacitor in the photo (KO 686 16k 519), could anyone identify it and show me a similar one?
                                    Thank you
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3581
                                      #138
                                      68uF, 16V tantalum or polymer. "519" is the date or lot code.
                                      PeteS in CA
                                      • thinkfast76
                                        • Mar 2017
                                        • 46
                                        • italia
                                        #139
                                        Thx a lot , just find on a old macbook motherboard
                                        • udonome
                                          • Jul 2023
                                          • 14
                                          • United Kingdom
                                          #140
                                          pls identify these capacitor, they are all damaged and i need to fix this hikvision board
                                          • varkatope
                                            Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                                            by varkatope
                                            Hey there, retro fans.
                                            I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                                            12-15-2024, 09:48 AM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                          • slybunda
                                            AA and AAA battery charger capacitors?
                                            by slybunda
                                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                            it has inside:
                                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                            2 x 470uf 16v LZ105c branded as G.Luxon
                                            not heard of these brands are they any good?
                                            iv attached photos of the charger and the board inside for an idea on the type of...
                                            12-24-2023, 04:41 AM
                                            Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                            by sam_sam_sam
                                            I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                            This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • Cama
                                            Solar Inverter - SMH-II - 2 missing capacitors
                                            by Cama
                                            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                            My model is : EASUN SMH-II 7 KW
                                            Mother Board : P/N 18947-002401250250
                                            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                            Thank you...
                                            09-12-2025, 02:50 AM
